    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 83.1k Views 19 Watching
      shbatm Module Developer
      @michael5r Awesome looking module! Extremely professional looking.
      When I get time I’m definitely going look at integrating with my MMM-ISY module to render on top of the Floorplan (my ultimate goal is to use a MagicMirror instance as a web-based home control interface-slash-ISY/Hass.io/Hue front-end on my mirrors, tablets, etc).
        dazza120 @michael5r
        @michael5r Thanks for sharing :)
          dazza120
          Hi is it possible to do a hide light or group that you don’t want to be seen rather than adding all the ones you have? As my hue stuff is in its infancy and it’s always having more bulbs added I would rather that it populated new bulbs rather than input the name in the model, I don’t even know if this is possible with your module? But it’s staying on my mirror thanks again for a beautiful module 👌🏾
          michael5rM 1 Reply Last reply
          • michael5rM
            michael5r Module Developer @dazza120
            @dazza120 said in MMM-Hue-Lights - new module for your Philips Hue lights!:
            There wasn’t the option to do so previously, but there is now.
            If you pull the latest version of the module, you’ll find a new setting called hideFilter. It works exactly the same way as the displayFilter setting, but in reverse - any names you add to hideFilter will be hidden on your mirror.
            Like this:
            hideFilter: ['living room'],
            Any lights or light groups named living room will now be hidden.
            Check it out and see if it works for you.
            D 1 Reply Last reply
              dazza120 @michael5r
              @michael5r said in MMM-Hue-Lights - new module for your Philips Hue lights!:
              Like this:
              Works brilliantly i missed the brackets [ ] as i thought it didn’t need it, but put them in and boom works like a dream now home-away mode won’t bug me lol. Thanks again
                PhiDeltDexter
                Would you have any idea as to why I am showing multiple identical groups? I thought it was coming from one of my other connected apps to Hue, however I went in and disabled all the other apps and it still shows up. I cant seem to find a way to use hide or show since they have identical names.
                P 1 Reply Last reply
                  PhiDeltDexter @PhiDeltDexter
                  As a work around to this, I went into my Hue app and renamed all my rooms with a 1 on the end, and hid all the ones with that 1. I am not sure where it is pulling the groups from if not the Hue App.
                  • michael5rM
                    michael5r Module Developer @PhiDeltDexter
                    @phideltdexter This is most likely due to you having Entertainment Areas set up on your Hue system as well.
                    Open up the Hue app, click Settings, then Entertainment Areas and see what’s in there.
                    If that’s not it, let me know and I’ll do some more debugging on my end.
                      PhiDeltDexter
                      I also thought about that. I had 2 entertainment areas setup already. One in living room and another generic one. I removed them just to make sure, it removed one duplicate of Living Room, but not the others.
                      In addition when I disable all the filters I have a list of groups that takes up almost my entire screen. The majority of which are not in the Hue App, which is why initially I thought it had to be pulling from somewhere else besides the Hue App.
                      P michael5rM 2 Replies Last reply
                        I also only have 2 formulas installed in Hue Labs. 1 of them is candlelight, so that is where that one comes from. The others, I am still not sure. I also went in and changed the names of all my rooms in my SmartThings environment which didn’t change anything either.
                        • michael5rM
                          @phideltdexter said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                          Ahhh … I think I know what this is - I think these are multisource groups and lightsources. Give me a minute to come up with a fix that ignores them from the group list.
                          Reply Quote 2
                            PhiDeltDexter @michael5r
                            @michael5r
                            Here is what it shows for Type. I didn’t even think to check. But perhaps if you are filtering out group types, you could add a category for Rooms in the future? Otherwise it shows them as a LightGroup.
                            • michael5rM
                              @michael5r
                              Yeah, that confirms my assumption.
                              My intention with the groups was just to show rooms, though - I just don’t have any of these multisource groups myself, so I never realized they were also being shown.
                              I pushed an update to the module that filters out anything that doesn’t have a type of room - if you pull it, your list should shrink to a more manageable size :)
                              If you’d like to have the ability to filter these groups - just in case you do want to show ones marked LightGroup - just post it as an issue on GitHub and I’ll build a real filtering functionality.
                              • michael5rM
                                Just wanted to announce that there’s a new version of this module out!
                                I added functionality to support Paviro’s MMM-PIR-Sensor module meaning that this module can now be suspended & resumed based on movement detected through a PIR sensor (or whatever else you’re using for motion detection).
                                Check out the release notes here:
                                https://github.com/michael5r/mmm-hue-lights/releases/tag/1.3.0
                                  dazza120 @michael5r
                                  @michael5r I’m having a issue with the hue lights and MMM-Remote-Control, when viewing it from that app the hue module comes up with an error, it says
                                  Hue API Error: Error: read ECONNRESET
                                  it still changes when you turn on a bulb but would go back to the Error shortly after. When I use VNC to view it as long as I haven’t used mmm remotre control to view it, it works perfectly any ideas?
                                  • michael5rM
                                    @dazza120 That seems odd - let me check it out & see if I can replicate.
                                      Christian
                                      I installed the module today with my Deconz gateway (not Hue).
                                      Everything works fine but I´m not able to use my defined groups.
                                      Lights are working great but the Hue bridge uses rooms and not groups, I think thats my problem.
                                      The Deconz gateway uses only lights and groups.
                                      The module MMM-Hue works great with the Deconz gateway but it´s basic. The new module looks much better.
                                      Is there a way to fix this problem?
                                      Regards,
                                      Christian
                                      • michael5rM
                                        michael5r Module Developer @Christian
                                        @christian said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                                        Regards,
                                        Christian
                                        Sure - open up the mmm-hue-lights.js file and go to line 670.
                                        You’ll see a comment saying for the groups, let's immediately filter out anything that doesn't have a type of 'Room' and a code block that looks like this:
                                        Object.keys(data.groups).forEach(function(key) {
                                            var itemType = data.groups[key].type.toLowerCase();
                                            if (itemType !== 'room') {
                                                delete data.groups[key];
                                        If you delete or uncomment that code block, it will no longer filter out anything that isn’t a room.
                                        C 1 Reply Last reply
                                          Christian @michael5r
                                          @michael5r
                                          Ok, thank you for the fast reply. That’s working for me.
                                          Regards,
                                          Christian
                                            Christian
                                            is there a way to get lights or groups sorted by name?
                                            Regards,
                                            Christian
                                            • 1 / 5
