    602 Posts 67 Posters 2.4m Views 68 Watching
    • Cr4z33C
      Cr4z33
      @shbatm what if I want to use VLC instead of omxplayer?
      I am going to move to a different SBC called Rock Pi 4B and we know that omxplayer is for the Raspberry Pi family only.
      Would it be quite simple to edit the scripts or does it need a good programming knowledge? :smiling_face_with_smiling_eyes:
      Right now I am using a VLC window in my VMware Debian 8.x based MagicMirror testing session, but it’s not really what I want… :confused_face:
        shbatm Module Developer
        @citizendevpi I started looking at VLC as an alternative to OMXPlayer but didn’t make it very far (honestly, just not enough time).
        The most promising looked to be webchimera.js with VLC built for hardware acceleration, but the original repo for webchimera.js is marked abandoned. It looks like at least 1 fork is still active, but I didn’t get as far as testing anything.
        If you have the capability to pursue it, I’d love some help. From what I have looked at, it should be a close-to-drop-in replacement for the FFMPEG version of this Module, and if that works, I could eliminate all of the OMXPlayer references (read: headaches).
        References I’ve found:
        https://thepi.io/how-to-compile-vlc-media-player-with-hardware-acceleration-for-the-raspberry-pi/
        https://github.com/limoragni/WebChimera.js
        Cr4z33C 2 Replies Last reply
        • Cr4z33C
          Cr4z33 @shbatm
          @shbatm unfortunately I am not skilled enough for that sorry. :slightly_frowning_face:
          Anyway it came out that VLC was not a good idea when using a Rockchip based SBC.
          Its VPU can be used only if using gst-launch-1.0 like ie.:
          gst-launch-1.0 uridecodebin uri=file:///usr/local/test.mp4  ! rkximagesink
          That way 4K streaming/playing looks good too.
          • Cr4z33C
            Cr4z33 @shbatm
            @shbatm I’ve encountered a new issue.
            While using a profile switching solution when I get to the profile that uses MMM-RTSPStream omxplayer displays the video at full screen! :face_screaming_in_fear:
            The major problem is that no keyboard or mouse control can be used until I switch to a different profile that is not using your module.
            Can you please fix this?
            • BKeyportB
              BKeyport Module Developer
              That’s sounding more like the profile switcher’s issue - unless you’ve config’d this player to be full screen.
              Cr4z33C 1 Reply Last reply
              • Cr4z33C
                Cr4z33 @BKeyport
                @bkeyport nope I didn’t set omxplayer anywhere but in this module. ;)
                Also profile switching is only ‘telling’ modules to show or hide.
                Nothing else.
                It’s done by voice command through MMM-AssistankMk2:
                      "CHANGE_PROFILE_1": {
                        moduleExec: {
                          module:[],
                          exec: (module, params, key) => {
                            var modules = ["YOUR", "MODULES", "TO", "SHOW", "FOR", "PROFILE1"]
                            if (modules.indexOf(module.name) >= 0) {
                              module.show()
                            } else {
                              module.hide()
                      "CHANGE_PROFILE_2": {
                        moduleExec: {
                          module:[],
                            var modules = ["YOUR", "MODULES", "TO", "SHOW", "FOR", "PROFILE2"]
                              module.show()
                            } else {
                              module.hide()
                  shbatm Module Developer @Cr4z33
                  @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  Please post your PM2 logs when this happens so I can try and troubleshoot. (Run pm2 logs in an SSH terminal, or post the excerpt from the files in ~/.pm2/logs/).
                  • Cr4z33C
                    Cr4z33 @shbatm
                    @shbatm here you go. ;)
                    • Cr4z33C
                      Cr4z33 @shbatm
                      @shbatm you there mate? :hushed_face:
                        @cr4z33 Hey, sorry, I’m out of town and don’t have access to test anything related to this module (no easy access to cameras or a RPi) for the next few weeks.
                        There is definitely a glitch in the calls to stop and restart the streams, but I can’t test right now. You can try backing up to a previous version and see if it was the latest updates to cause the problem: try using git checkout f583553
                        I will take a look as soon as I can, and on a side note, there is now official support for VLC w/ Hardware Accelerated Decoding on Raspbian, I am planning to see if it would be better to abandon OMXPlayer in favor of VLC.
                        • Cr4z33C
                          Cr4z33 @shbatm
                          @shbatm alright mate thanks for letting me know and sorry if I was insisting, but I thought you didn’t see my previous reply. :smiling_face_with_open_mouth_cold_sweat:
                          Gonna try to revert now.
                          Update
                          I can confirm that reverting back to that version gets rid of the issue. :thumbs_up_medium-light_skin_tone:
                            @Cr4z33 No problem, sometimes I need a little prompting…
                            Glad the revert works. I’ll troubleshoot more when I’m back.
                            • Cr4z33C
                              Cr4z33 @shbatm
                              @shbatm cheers. :heart:
                              • BKeyportB
                                I’d support trying VLC over OMXPlayer - OMXPlayer barely works - and crashes so much, I had to switch to FFMpeg(?) – and even that crashes on my Pi 3+
                                • richland007R
                                  richland007
                                  @shbatm @Cr4z33 Hello guys and let me first wish you happy holidays and say thank you to @shbatm for this module.
                                  I too am using MMM-RTSPStream to stream my TV tuner to the mirror (the streaming is done from a media server running VLC in my network where the TV tuner is installed). Here is whats happening in my case :
                                  Everything is working “fine” per say meaning:
                                  If i go on my Rpi that my MM is installed and on the terminal i type
                                  omxplayer rtsp://192.168.1.254:8554/vlc
                                  I can see my TV programming playing just fine with minimal resources used on the pi …however when i try to watch it on MM after launching it, it does not work it just displays a gray quadrant!!
                                  If i go on the MM config.js and i change the url on MMM-RTSPStream module from the above to one of my cameras who have a username and password than MagicMirror displays them as expected and beautifully on the assigned page.
                                  So both my MM config of the RTSPStream module and my actual stream work …separately however, but not together!!!
                                  Does MMM-RTSPStream has to have a username and password for it to work???
                                  What do you think is happening in my case??
                                  Any help is always greatly appreciated
                                  Denis
                                  • richland007R
                                    richland007
                                    Found it myself what it was causing it …it needed “udp” protocol on MM config.js for MMM_RTSPStream …why, i have no clue but i figured that parameter would be the only one that may make a difference and it worked :)
                                    D
                                      djuscha
                                      Hello
                                      I have two same hikvision cameras with the same settings so my config looks like.
                                          module: "MMM-RTSPStream",
                                          position: "bottom_bar",
                                              autoStart: true,
                                              rotateStreams: false,
                                              rotateStreamTimeout: 10,
                                              moduleWidth: 1152,
                                              moduleHeight: 400,
                                              localPlayer: 'omxplayer',
                                              remotePlayer: 'none',
                                              showSnapWhenPaused: false,
                                              remoteSnaps: true,
                                      		moduleOffset:{ top: 32, left: 32 },
                                              stream1: {
                                                  url: 'rtsp://******:********@192.***.178.160/Streaming/Channels/102',
                                                  frameRate: 'undefined',
                                                  snapshotUrl: 'rtsp://******:*******@192.***.178.160/Streaming/Channels/2/picture',
                                                  snapshotType: 'url',
                                                  snapshotRefresh: 10,
                                                  width: 480,
                                                  height: 300,
                                              stream2: {
                                                  url: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/102',
                                                  snapshotUrl: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/2/picture',
                                                  width: 480,
                                                  height: 300,
                                      The Problem is that one camara is showing a Picture and the second once does not Show any Picture on the screen.
                                      What am I doing wrong?
                                        shbatm Module Developer @djuscha
                                        @djuscha If you switch the order, does the opposite one show up? You may need to change the CPU/GPU memory split in your Pi – sudo raspi-config find the “Memory Split” option and increase from 64 to 128.
                                          djuscha
                                          When I switch the order I see the picture from the other camera.
                                          with change from the “Memory Split” I see no Change :(
                                            @djuscha Try 256, and make sure you restart the Pi after each adjustment.
                                            Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                                            D 1 Reply Last reply
                                            • 10
                                            • 30
                                            • 31
                                            • 8 / 31
