    602 Posts 67 Posters 2.4m Views 68 Watching
    • Cr4z33C
      Cr4z33 @shbatm
      @shbatm here you go. ;)
      • Cr4z33C
        Cr4z33 @shbatm
        @shbatm you there mate? :hushed_face:
          shbatm Module Developer @Cr4z33
          @cr4z33 Hey, sorry, I’m out of town and don’t have access to test anything related to this module (no easy access to cameras or a RPi) for the next few weeks.
          There is definitely a glitch in the calls to stop and restart the streams, but I can’t test right now. You can try backing up to a previous version and see if it was the latest updates to cause the problem: try using git checkout f583553
          I will take a look as soon as I can, and on a side note, there is now official support for VLC w/ Hardware Accelerated Decoding on Raspbian, I am planning to see if it would be better to abandon OMXPlayer in favor of VLC.
          Cr4z33C 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @shbatm
            @shbatm alright mate thanks for letting me know and sorry if I was insisting, but I thought you didn’t see my previous reply. :smiling_face_with_open_mouth_cold_sweat:
            Gonna try to revert now.
            Update
            I can confirm that reverting back to that version gets rid of the issue. :thumbs_up_medium-light_skin_tone:
              @Cr4z33 No problem, sometimes I need a little prompting…
              Glad the revert works. I’ll troubleshoot more when I’m back.
              • Cr4z33C
                Cr4z33 @shbatm
                @shbatm cheers. :heart:
                • BKeyportB
                  BKeyport Module Developer
                  I’d support trying VLC over OMXPlayer - OMXPlayer barely works - and crashes so much, I had to switch to FFMpeg(?) – and even that crashes on my Pi 3+
                  • richland007R
                    richland007
                    @shbatm @Cr4z33 Hello guys and let me first wish you happy holidays and say thank you to @shbatm for this module.
                    I too am using MMM-RTSPStream to stream my TV tuner to the mirror (the streaming is done from a media server running VLC in my network where the TV tuner is installed). Here is whats happening in my case :
                    Everything is working “fine” per say meaning:
                    If i go on my Rpi that my MM is installed and on the terminal i type
                    omxplayer rtsp://192.168.1.254:8554/vlc
                    I can see my TV programming playing just fine with minimal resources used on the pi …however when i try to watch it on MM after launching it, it does not work it just displays a gray quadrant!!
                    If i go on the MM config.js and i change the url on MMM-RTSPStream module from the above to one of my cameras who have a username and password than MagicMirror displays them as expected and beautifully on the assigned page.
                    So both my MM config of the RTSPStream module and my actual stream work …separately however, but not together!!!
                    Does MMM-RTSPStream has to have a username and password for it to work???
                    What do you think is happening in my case??
                    Any help is always greatly appreciated
                    Denis
                    • richland007R
                      richland007
                      Found it myself what it was causing it …it needed “udp” protocol on MM config.js for MMM_RTSPStream …why, i have no clue but i figured that parameter would be the only one that may make a difference and it worked :)
                      D
                        djuscha
                        Hello
                        I have two same hikvision cameras with the same settings so my config looks like.
                            module: "MMM-RTSPStream",
                            position: "bottom_bar",
                                autoStart: true,
                                rotateStreams: false,
                                rotateStreamTimeout: 10,
                                moduleWidth: 1152,
                                moduleHeight: 400,
                                localPlayer: 'omxplayer',
                                remotePlayer: 'none',
                                showSnapWhenPaused: false,
                                remoteSnaps: true,
                        		moduleOffset:{ top: 32, left: 32 },
                                stream1: {
                                    url: 'rtsp://******:********@192.***.178.160/Streaming/Channels/102',
                                    frameRate: 'undefined',
                                    snapshotUrl: 'rtsp://******:*******@192.***.178.160/Streaming/Channels/2/picture',
                                    snapshotType: 'url',
                                    snapshotRefresh: 10,
                                    width: 480,
                                    height: 300,
                                stream2: {
                                    url: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/102',
                                    snapshotUrl: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/2/picture',
                                    width: 480,
                                    height: 300,
                        The Problem is that one camara is showing a Picture and the second once does not Show any Picture on the screen.
                        What am I doing wrong?
                          shbatm Module Developer @djuscha
                          @djuscha If you switch the order, does the opposite one show up? You may need to change the CPU/GPU memory split in your Pi – sudo raspi-config find the “Memory Split” option and increase from 64 to 128.
                            djuscha
                            When I switch the order I see the picture from the other camera.
                            with change from the “Memory Split” I see no Change :(
                              @djuscha Try 256, and make sure you restart the Pi after each adjustment.
                              Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                              D 1 Reply Last reply
                                djuscha
                                @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                pm2 Status
                                pi@raspberrypi:~ $ pm2 status
                                │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                                │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.6 MB   │
                                │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
                                │ omx_stream2 │ 2  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.7 MB   │
                                /home/pi/.npm/_logs/2018-12-25T13_58_40_969Z-debug.log
                                1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                2 info using npm@6.4.1
                                3 info using node@v10.14.2
                                5 info lifecycle magicmirror@2.5.0~prestart: magicmirror@2.5.0
                                6 info lifecycle magicmirror@2.5.0~start: magicmirror@2.5.0
                                7 verbose lifecycle magicmirror@2.5.0~start: unsafe-perm in lifecycle true
                                8 verbose lifecycle magicmirror@2.5.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                9 verbose lifecycle magicmirror@2.5.0~start: CWD: /home/pi/MagicMirror
                                10 silly lifecycle magicmirror@2.5.0~start: Args: [ '-c', 'sh run-start.sh' ]
                                11 silly lifecycle magicmirror@2.5.0~start: Returned: code: 1  signal: null
                                12 info lifecycle magicmirror@2.5.0~start: Failed to exec start script
                                13 verbose stack Error: magicmirror@2.5.0 start: `sh run-start.sh`
                                13 verbose stack Exit status 1
                                13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
                                13 verbose stack     at EventEmitter.emit (events.js:182:13)
                                13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                13 verbose stack     at ChildProcess.emit (events.js:182:13)
                                13 verbose stack     at maybeClose (internal/child_process.js:962:16)
                                13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
                                14 verbose pkgid magicmirror@2.5.0
                                15 verbose cwd /home/pi/MagicMirror
                                16 verbose Linux 4.14.79-v7+
                                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                18 verbose node v10.14.2
                                19 verbose npm  v6.4.1
                                20 error code ELIFECYCLE
                                21 error errno 1
                                22 error magicmirror@2.5.0 start: `sh run-start.sh`
                                22 error Exit status 1
                                23 error Failed at the magicmirror@2.5.0 start script.
                                23 error This is probably not a problem with npm. There is likely additional logging output above.
                                24 verbose exit [ 1, true ]
                                • A
                                  AxLed Module Developer @evroom
                                  @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                  Next thing I am trying to use MMM-RTSPStream for, is streaming sat-tv from a Dreambox & VU+ receivers.
                                  I am able to stream a channel using:
                                  omxplayer --vol -3000 --win “0 0 480 320” --live http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                                  @evroom
                                  Maybe my new module is something for you:
                                  MMM-Dreambox
                                  Regards
                                  AxLED
                                  Cr4z33C evroomE 2 Replies Last reply
                                  • Cr4z33C
                                    Cr4z33 @AxLed
                                    @axled woah gonna try it now! :thumbs_up_medium-light_skin_tone:
                                    • evroomE
                                      evroom @AxLed
                                      @axled
                                      Interesting. Will give it a try.
                                      MagicMirror version: 2.37.0
                                        djuscha @shbatm
                                        @shbatm
                                        @shbatm> Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                                        what am I doing wrong?
                                          barnosch
                                          i have the same problem like @djuscha
                                          The second stream does not show up.
                                          Can it be a layering issue? Maybe its underneath the other one and just needs to moved down via a
                                          or something?
                                          As soon as i turn autorotate=on i can see both streams , but the delay between the switch is useless. I see 10 sec the stream1 than for 10 sec black and then for 10sec the other stream2.
                                          (if i watch the pm2 status while in rotate mode, it stops the whole stream, thats why it takes forever to load, i guess. shutdowndelay option seems not to change something)
                                          I would like to see them in parallel if possible.
                                          Any idea or suggestion?
                                            @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                            I agree, unfortunately this is a an OMXPlayer problem – it takes anywhere from 5-10s to actually open and play a stream, so rotating the streams with OMXPlayer is limited unless you’re willing to accept the delay. I’ve played with everything I can think of to leave a stream open in the background–but nothing worked. The shutdown delay option only affects FFMPEG.
                                            @djuscha For some reason only 1 stream is being started (the PM2 status is showing STOPPED for the other stream). I think I must have broken something in one of the last releases, try reverting back to an old version and see if it works:
                                            cd ~/MagicMirror/modules/MMM-RTSPStream
                                            I will work on troubleshooting and see what I broke.
                                            D S 2 Replies Last reply
                                            • 10
                                            • 30
                                            • 31
                                            • 8 / 31
