    602 Posts 67 Posters 2.2m Views 68 Watching
    • richland007R Offline
      richland007
      @shbatm @Cr4z33 Hello guys and let me first wish you happy holidays and say thank you to @shbatm for this module.
      I too am using MMM-RTSPStream to stream my TV tuner to the mirror (the streaming is done from a media server running VLC in my network where the TV tuner is installed). Here is whats happening in my case :
      Everything is working “fine” per say meaning:
      If i go on my Rpi that my MM is installed and on the terminal i type
      omxplayer rtsp://192.168.1.254:8554/vlc
      I can see my TV programming playing just fine with minimal resources used on the pi …however when i try to watch it on MM after launching it, it does not work it just displays a gray quadrant!!
      If i go on the MM config.js and i change the url on MMM-RTSPStream module from the above to one of my cameras who have a username and password than MagicMirror displays them as expected and beautifully on the assigned page.
      So both my MM config of the RTSPStream module and my actual stream work …separately however, but not together!!!
      Does MMM-RTSPStream has to have a username and password for it to work???
      What do you think is happening in my case??
      Any help is always greatly appreciated
      Denis
        richland007
        Found it myself what it was causing it …it needed “udp” protocol on MM config.js for MMM_RTSPStream …why, i have no clue but i figured that parameter would be the only one that may make a difference and it worked :)
        D
          djuscha
          Hello
          I have two same hikvision cameras with the same settings so my config looks like.
              module: "MMM-RTSPStream",
              position: "bottom_bar",
                  autoStart: true,
                  rotateStreams: false,
                  rotateStreamTimeout: 10,
                  moduleWidth: 1152,
                  moduleHeight: 400,
                  localPlayer: 'omxplayer',
                  remotePlayer: 'none',
                  showSnapWhenPaused: false,
                  remoteSnaps: true,
          		moduleOffset:{ top: 32, left: 32 },
                  stream1: {
                      url: 'rtsp://******:********@192.***.178.160/Streaming/Channels/102',
                      frameRate: 'undefined',
                      snapshotUrl: 'rtsp://******:*******@192.***.178.160/Streaming/Channels/2/picture',
                      snapshotType: 'url',
                      snapshotRefresh: 10,
                      width: 480,
                      height: 300,
                  stream2: {
                      url: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/102',
                      snapshotUrl: 'rtsp://****:*******@192.***.178.170/Streaming/Channels/2/picture',
                      width: 480,
                      height: 300,
          The Problem is that one camara is showing a Picture and the second once does not Show any Picture on the screen.
          What am I doing wrong?
            shbatm Module Developer @djuscha
            @djuscha If you switch the order, does the opposite one show up? You may need to change the CPU/GPU memory split in your Pi – sudo raspi-config find the “Memory Split” option and increase from 64 to 128.
              djuscha
              When I switch the order I see the picture from the other camera.
              with change from the “Memory Split” I see no Change :(
                @djuscha Try 256, and make sure you restart the Pi after each adjustment.
                Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                  djuscha
                  @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                  pm2 Status
                  pi@raspberrypi:~ $ pm2 status
                  │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                  │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.6 MB   │
                  │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
                  │ omx_stream2 │ 2  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.7 MB   │
                  /home/pi/.npm/_logs/2018-12-25T13_58_40_969Z-debug.log
                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                  2 info using npm@6.4.1
                  3 info using node@v10.14.2
                  5 info lifecycle magicmirror@2.5.0~prestart: magicmirror@2.5.0
                  6 info lifecycle magicmirror@2.5.0~start: magicmirror@2.5.0
                  7 verbose lifecycle magicmirror@2.5.0~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.5.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                  9 verbose lifecycle magicmirror@2.5.0~start: CWD: /home/pi/MagicMirror
                  10 silly lifecycle magicmirror@2.5.0~start: Args: [ '-c', 'sh run-start.sh' ]
                  11 silly lifecycle magicmirror@2.5.0~start: Returned: code: 1  signal: null
                  12 info lifecycle magicmirror@2.5.0~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.5.0 start: `sh run-start.sh`
                  13 verbose stack Exit status 1
                  13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
                  13 verbose stack     at EventEmitter.emit (events.js:182:13)
                  13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  13 verbose stack     at ChildProcess.emit (events.js:182:13)
                  13 verbose stack     at maybeClose (internal/child_process.js:962:16)
                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
                  14 verbose pkgid magicmirror@2.5.0
                  15 verbose cwd /home/pi/MagicMirror
                  16 verbose Linux 4.14.79-v7+
                  17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                  18 verbose node v10.14.2
                  19 verbose npm  v6.4.1
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.5.0 start: `sh run-start.sh`
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.5.0 start script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                    AxLed Module Developer @evroom
                    @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                    Next thing I am trying to use MMM-RTSPStream for, is streaming sat-tv from a Dreambox & VU+ receivers.
                    I am able to stream a channel using:
                    omxplayer --vol -3000 --win “0 0 480 320” --live http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                    @evroom
                    Maybe my new module is something for you:
                    MMM-Dreambox
                    Regards
                    AxLED
                    Cr4z33C evroomE 2 Replies Last reply Reply Quote 0
                    • Cr4z33C Offline
                      Cr4z33 @AxLed
                      @axled woah gonna try it now! :thumbs_up_medium-light_skin_tone:
                      • evroomE Offline
                        evroom @AxLed
                        @axled
                        Interesting. Will give it a try.
                        MagicMirror version: 2.36.0
                          djuscha @shbatm
                          @shbatm
                          @shbatm> Also, please check the MM logs and post if you see any errors. You should be seeing two calls to start omxplayer. You can also do pm2 status to make sure both streams are running.
                          what am I doing wrong?
                            barnosch
                            i have the same problem like @djuscha
                            The second stream does not show up.
                            Can it be a layering issue? Maybe its underneath the other one and just needs to moved down via a
                            or something?
                            As soon as i turn autorotate=on i can see both streams , but the delay between the switch is useless. I see 10 sec the stream1 than for 10 sec black and then for 10sec the other stream2.
                            (if i watch the pm2 status while in rotate mode, it stops the whole stream, thats why it takes forever to load, i guess. shutdowndelay option seems not to change something)
                            I would like to see them in parallel if possible.
                            Any idea or suggestion?
                              @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              I agree, unfortunately this is a an OMXPlayer problem – it takes anywhere from 5-10s to actually open and play a stream, so rotating the streams with OMXPlayer is limited unless you’re willing to accept the delay. I’ve played with everything I can think of to leave a stream open in the background–but nothing worked. The shutdown delay option only affects FFMPEG.
                              @djuscha For some reason only 1 stream is being started (the PM2 status is showing STOPPED for the other stream). I think I must have broken something in one of the last releases, try reverting back to an old version and see if it works:
                              cd ~/MagicMirror/modules/MMM-RTSPStream
                              git checkout f583553
                              I will work on troubleshooting and see what I broke.
                              D S 2 Replies Last reply Reply Quote 0
                                djuscha @shbatm
                                @shbatm said in [[MMM-RTSPStream] - Video Streaming from Live Feeds & Security
                                │ omx_stream1 │ 1 │ N/A │ fork │ online │ 6 │ 0% │ 2.8 MB │
                                │ omx_stream2 │ 2 │ N/A │ fork │ online │ 0 │ 0% │ 2.8 MB │
                                It works!!
                                Many Thanks!!
                                  STATUS UPDATE
                                  Just wanted to give everyone a quick status update about this module.
                                  Bad news first: the current version in the master branch is malfunctioning. Please revert to a previous version (see post above) until I get time to undo the commit.
                                  EDIT - I’ve reverted the changes that I think broke the master channel. Please try updating your module to the current master branch and test.
                                  Good news! The reason I haven’t fixed the main branch yet is because the most recent version of the Raspbian image (Nov '18) has introduced a native version of VLC with hardware acceleration. I am actively working on a version of this module that will abandon OMXPlayer in favor of VLC, and have a working prototype in the develop branch for anyone interested in testing!
                                  Requirements:
                                  • Must have the most recent version of Raspbian with Desktop (> Nov '18). Google how to upgrade, but you may be better off starting with a fresh image.
                                  • Enable OpenGL (Fake KMS) driver in raspi-config
                                  • Increase GPU/CPU Memory Split to at least 128 (do this after enabling OpenGL because it will reset it to 64).
                                  • Upgrade Electron to v3.0.13 (v2.0.16 in MM v2.6 is not working with OpenGL–see MM Issue #1500:
                                      # Remove the node_modules folder to start fresh
                                      rm -R ./node_modules
                                      # Either manually update the required electron version in package.json to 3.0.13 or use the sed command below
                                      sed -i 's/electron": "\^2\.0\..*",/electron": "^3.0.13",/g' package.json
                                      # Re-install the MM node modules
                                      npm install
                                  • Delete your MMM-RTSPStream module directory and use the new installer script to install everything:
                                      rm -R ~/MagicMirror/modules/MMM-RTSPStream
                                      bash -c "$(curl -s https://raw.githubusercontent.com/shbatm/MMM-RTSPStream/develop/scripts/installer.sh)"
                                  • Update your config.js section to use VLC: localPlayer: 'vlc'
                                  Working:
                                  • VLC windows “placed” on top of the main Electron window inside the module’s box
                                  • Plays quickly, minimal lag, low CPU usage (4 streams @ ~35%)
                                  • Visible in VNC client (couldn’t do this with OMXPlayer)
                                  • Fast switching between streams – all VLC windows will remain open, and wmctrl utility used to toggle which one is on top.
                                    • Make sure to set a shutdownDelay for in your module config section make it longer than it takes to rotate back to that stream time (e.g. if you have rotateStreamTimeout: 10, and 3 streams, then it will take 20s to get back to the first stream, so you should set shutdownDelay: 22– 20s + 2s buffer).
                                  • Suspend/Restore functions
                                  • New version of Raspbian also has a hw-accelerated version of FFMPEG; I’ve added a hwAccel: true option for ffmpeg users to use HW-accelerated decoding. FFMPEG still has a big CPU impact for the encoder though.
                                  Not-yet-tested / left to-do:
                                  • Test if sound works
                                  • Figure out what I broke in the OMXPlayer version
                                  Not-gonna-happen:
                                  • Embedding VLC into Electron window (NPAPI-plugins are no longer supported and this is the only way I know how to do that).
                                  • Using VLC as the viewer for “remote” windows (other web browser instances of the MM) – same reason as above.
                                  Known Bugs:
                                  • When VLC windows are first created, you see them move around the screen. After they’re “put in the box” it they won’t fill up the box right away. After ~7 secs they should fill the box.
                                    • I am using devilspie2 to remove window decorations and move the VLC windows; however, for some reason I have to call it twice (~7s apart) to get VLC to resize it’s video properly. Shouldn’t be an issue in the long-term, unless you are hiding/showing the module often.
                                  A 1 Reply Last reply Reply Quote 1
                                    anthony6608 @shbatm
                                    @shbatm I can confirm that this method works. I tried to apply it to my original installation however during the ’ sed -i ‘s/electron": “^2.0..*”,/electron": “^3.0.13”,/g’ package.json’ command my installation failed half way through and seemed to mess my installation up. I have an open issue and you’ll see about 10+ responses from me as I tried to troubleshoot but its irrelevant as long as your Pi doesn’t lock up during this process.
                                    The only issue I seem to be having now is when I add the MMM-GoogleMapsTraffic module I see the Live feed box but the video doesn’t appear.
                                    I’m fairly new to this so I am not sure what could be causing it?
                                    Thanks again for all of your help!
                                      shbatm Module Developer @anthony6608
                                      @anthony6608 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                      I probably should have explained better above what the sed command was for. The current version of MagicMirror uses Electron version 2.0.16–this is defined in the package.json file in the MM directory. The sed command updates package.json to use Electron version 3.0.13 instead. It’s probably best to remove the node_modules directory first and reinstall (cleaner). I updated the steps above.
                                      The problem with updating Electron is there is a reason MM still uses the lower version–it was working–we don’t know what else the new version is going to break. On mine, I had to update Node to v10.15 from v8.15 to get one of my other modules to work.
                                      I have a love-hate relationship with this module. I use it, but seems to break my other modules too (KeyBindings, OnScreenMenu)… I’ll look into the cause of this one, but if I had to guess-- The VLC window is just that, another window setting on top of the browser page that is MM. If something causes the browser to get focus (as simple as clicking the black background), the VLC window falls behind it. If you have a keyboard hooked up, try Alt + Tab and see if it comes back. I’m already looking for a way to make the VLC windows modal so they stay on top.
                                        anthony6608
                                        Yep, Ive tried all different settings and I am not sure what is going on but the second I remove the MMM-GoogleMapsTraffic module from config.js the stream shows? Any idea why the two would conflict? I noticed when I remove the module from config.js then I see activity from RTSP stream in the logs when its added I dont see much:
                                        0|MagicMirror | Starting MagicMirror: v2.6.0
                                        0|MagicMirror | Loading config …
                                        0|MagicMirror | Loading module helpers …
                                        0|MagicMirror | Initializing new module helper …
                                        0|MagicMirror | Module helper loaded: mmm-nest-status
                                        0|MagicMirror | Module helper loaded: MMM-MyCommute
                                        0|MagicMirror | Module helper loaded: MMM-RTSPStream
                                        0|MagicMirror | No helper found for module: alert.
                                        0|MagicMirror | Module helper loaded: updatenotification
                                        0|MagicMirror | No helper found for module: clock.
                                        0|MagicMirror | Module helper loaded: calendar
                                        0|MagicMirror | No helper found for module: compliments.
                                        0|MagicMirror | No helper found for module: currentweather.
                                        0|MagicMirror | No helper found for module: weatherforecast.
                                        0|MagicMirror | Module helper loaded: newsfeed
                                        0|MagicMirror | All module helpers loaded.
                                        0|MagicMirror | Starting server on port 8080 …
                                        0|MagicMirror | Server started …
                                        0|MagicMirror | Connecting socket for: mmm-nest-status
                                        0|MagicMirror | Starting node_helper for module [mmm-nest-status]
                                        0|MagicMirror | Connecting socket for: MMM-MyCommute
                                        0|MagicMirror | ====================== Starting node_helper for module [MMM-MyCommute]
                                        0|MagicMirror | Connecting socket for: MMM-RTSPStream
                                        0|MagicMirror | PM2: Stopping all OMXPlayer Streams…
                                        0|MagicMirror | Connecting socket for: updatenotification
                                        0|MagicMirror | Connecting socket for: calendar
                                        0|MagicMirror | Starting node helper for: calendar
                                        0|MagicMirror | Connecting socket for: newsfeed
                                        0|MagicMirror | Starting module: newsfeed
                                        0|MagicMirror | Sockets connected & modules started …
                                        0|MagicMirror | Launching application.
                                        0|MagicMirror | libGL error:
                                        0|MagicMirror | MESA-LOADER: failed to retrieve device information
                                        0|MagicMirror | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                        0|MagicMirror | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                        0|MagicMirror | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                        0|MagicMirror | Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --no-video-deco --no-embedded-video --video-title=stream1 rtsp://xxxx;xxxx@192.168.0.6:554/cam/realmonitor?channel=1&subtype=1…
                                        0|MagicMirror | DP2: Config File Saved!
                                        0|MagicMirror | DP2: Running window resizers…
                                          anthony6608
                                          Ok I spoke too soon 😩
                                          Now the video won’t fit in the box no matter how I adjust it. I noticed that the other commute plugin width is adjusted as well. Is this a case of brackets not being in the right place or something? I’ve been working with this plugin all day 😟
                                          Recap:
                                          When I remove ALL other modules it aligns in the box however it doesnt take up the full box its like showing half of the picture.
                                          • When I enable the maps module the feed is there but just a black box.
                                          • When I have commute module loaded it overlaps the module on the screen.
                                          • When I remove all (non-default) modules it only fills up half of the box so the video is barely noticeable.
                                          • No matter how much I play with height/width settings, I cannot get it centered (right side always has blank space) and cant get anything sized up correctly.
                                          I appreciate any help you guys can offer!
                                          /* Magic Mirror Config Sample
                                          • MIT Licensed.
                                          • For more information how you can configurate this file
                                          • See https://github.com/MichMich/MagicMirror#configuration
                                          var config = {
                                          // - “”, “0.0.0.0”, “::” to listen on any interface
                                          // Default, when address config is left out, is “localhost”
                                          port: 8080,
                                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                                          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                                          language: "en",
                                          timeFormat: 12,
                                          units: "imperial",
                                                               header: "LIVE FEED",
                                                               autoStart: true,
                                                               rotateStreamTimeout: 20,
                                                               moduleWidth: 354,
                                                               moduleHeight: 240,
                                                               localPlayer: 'vlc',
                                                               remoteSnaps: false,
                                                               stream1: {
                                                               url: 'rtsp://admin:xxxxxxx@192.168.0.6:554/cam/realmonitor?channel=1&subtype=1',
                                                               autoStart: true,
                                                               //protocol: "tcp",
                                                               frameRate: undefined,
                                                               hdUrl: 'rtsp://admin:xxxx@192.168.0.6:554/cam/realmonitor?channel=1&subtype=0',
                                                               width: 354,
                                                               height: 240,
                                          		module: "alert",
                                          		module: "updatenotification",
                                          		position: "top_bar"
                                          		module: "clock",
                                          		position: "top_left"
                                          		header: "US Holidays",
                                          					symbol: "calendar-check",
                                          		module: "compliments",
                                          		position: "lower_third"
                                          		module: "currentweather",
                                          			locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                          		module: "weatherforecast",
                                          		header: "Weather Forecast",
                                          			locationID: "5128581",  //ID from https://openweathermap.org/city
                                          		module: "newsfeed",
                                          			feeds: [
                                          					title: "New York Times",
                                          			showSourceTitle: true,
                                          			showPublishDate: true
                                          if (typeof module !== “undefined”) {module.exports = config;}
                                            anthony6608 @shbatm
                                            Thanks for the response. As of right now im still having a few issues which I posted in my reply below. Ive been using GoogleMapsTraffic and had no issues before however I only got RTSP working today so I don’t know. The overlay isn’t the only issue… Do you have any idea why my STREAM stops loading when I readd GoogleMapsTraffic back to the config?
                                            Also, I have removed all other modules and just trying to get RTSP sorted. Now that all modules are removed I am able to get a good stream BUT no matter what I do I have a black space on the right side so it doesn’t look clean at all.
                                            • No matter how much I play with height/width settings, I cannot get it centered (right side always has black space) and cant get anything sized up correctly.
                                            Thanks again
                                            • 10
                                            • 30
                                            • 31
                                            • 8 / 31
