    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 78.6k Views 13 Watching
      shbatm Module Developer
      Description
      I created an updated version of @Jopyth’s excellent MMM-Remote-Control module with an extensible REST API for controlling everything about your mirror, as well as an upgrade of the /remote.html tool to use the module’s node_helper socket connection for communication back and forth–instead of get/post calls.
      Example REST Calls:
      Turn on the monitor
      GET /api/monitor/on  (curl -X GET 'http://magicmirror:8080/api/monitor/on')
      Hide All Modules
      GET /api/modules/all/hide (curl -X GET 'http://magicmirror:8080/api/modules/all/hide')
      Here’s the link to the API README and API Documentation. The API also includes the ability to automatically interpret other modules’ anticipated notifications to create a “guessed” API to control it (created from MMM-API). Modules’ can also send a notification to this module to explicitly declare their own API actions.
      This is still in testing, and I’m still adding a few features, but I wanted to share in case anyone is interested in testing as well.
      Inspiration
      I’ve now written several modules and end up constantly including similar functions into my code (things like monitor control, module switching, etc.) for the different modules and I wanted to start migrating to a “One Remote to Rule Them All”-style module. @Jopyth’s module is an awesome base with a lot of the functions needed already built in, but I also wanted to have a better RESTful interface (inspired by @juzim’s MMM-API module natively incorporated) so I could control the mirror from my home automation devices. Eventually, I’ll scrub my other modules like MMM-OnScreenMenu and MMM-KeyBindings to just call the functions from this module and keep them focused on their own key features.
      Download
      [card:shbatm/MMM-Remote-Control]
      Recommend using the Develop Branch for most recent changes.
      Key Features and Changes
      Added:
      • REST API interface for controlling all aspects of the MagicMirror from HTTP RESTful-style GET and POST calls, based on principles from MMM-Api
        • Full API Documentation at API/README.md
        • Extensible Actions – Interprets other modules’ notifications to “guess” an API, but also allows a module to explicitly provide API actions to use.
      • Live daily updates of modules.json from the MagicMirror wiki, based on @eouia’s MMM-Remote-Control-Repository.
      • Incorporated some features found in MMM-OnScreenMenu that were not originally in this module.
        • Monitor (Connected Screen) On-Off Status and Toggle
        • If using Electron: Open Dev Tools, Minimize, Toggle Fullscreen
      • Configuration Option to send custom shell commands to use. Currently, only custom monitor on/off/status commands are supported. Addresses PR #99.
      Changed:
      • Updates to remote.html and the node_helper.js to use direct SocketIO communication back and forth instead of separate HTTP calls.
        • Future framework for following PM2 logs and more live update options.
      • General clean-up and standardization of status reporting for GET and POST calls, to original URLs and to new API URLs.
      • Updated to ES2015 (ES Version 6) function calls in most locations.
      • Added USER_PRESENCE controls from AgP42, PR #84
      • Added translations from BKeyport, PR #103
      • Added SHOW/HIDE/TOGGLE ALL modules option per request from Rene1709, Issue #101
      N Cr4z33C 2 Replies Last reply
      Reply Quote 4
        Additional Features Added:
        • Dynamic Module Control menu – uses the new API to create a Module Control menu on the remote page to control other modules via notifications.
        • Custom Menu – ability to specify your own custom menu items from a file (for advanced users)
        • Use PM2 API to control restarts/stops of MM. Can also support starting/stopping other PM2 scripts by passing processName: “scriptToUse” in the query payload.
        Example Dynamic Menu for MMM-Carousel w/ Navigation
        N 1 Reply Last reply
        • N
          nobita @shbatm
          @shbatm
          The first time I Install MMM-Remote-Control (by Jopyth ) before
          If I would like to use your MMM-Remote-Control (by shbatm)
          question
          I have to Remove from jopyth or not
          Thank so much
            shbatm Module Developer @nobita
            @nobita said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
            You can checkout my fork/branch without removing @Jopyth’s by adding a remote:
            $ cd ~/MagicMirror/modules/MMM-Remote-Control
            $ git remote add shbatm https://github.com/shbatm/MMM-Remote-Control.git
            $ git fetch shbatm
            $ git checkout -b shbatm-develop shbatm/develop
            $ npm install
            After that you can switch back and forth using git checkout master and git checkout shbatm-develop
            N swvalentiS 2 Replies Last reply
            • N
              nobita @shbatm
              @shbatm
              Thanks again
                dazza120
                Can this also update modules like MMM-Remote-Control-Repositories, in just this one module?
                  shbatm Module Developer @dazza120
                  @dazza120 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                  Yes. This version pulls the list of modules from the Wiki and updates the modules.json file when its started (at most 1x per day).
                  D Cr4z33C 2 Replies Last reply
                    dazza120 @shbatm
                    @shbatm cheers I’ve looked through the read me and I am completely lost, it’s not just like doing a git clone and then putting stuff in the config file 🧠😁
                    • Cr4z33C
                      Cr4z33 @shbatm
                        @dazza120 Sorry, I’ve been away. What are you lost with? Can I help point you in the right direction?
                        If you’re just looking to install this version, see a couple posts up. For the most part it functions just like the other version, but adds a lot of advanced control features on top–like controlling your mirror from a browser or home automation controller (via API) or adding module control menus to the existing “/remote.html” page.
                        Cr4z33C 1 Reply Last reply
                          robiv8
                          Is there any way to track traffic from remote control Nothing is visible in pm2 logs.
                          A kind debuging or like.
                          Alert it does not work. It comes the OK for transmit but nothing appears. Restart works and also monitor ON OFF.
                          But the browser does not refresh again.
                          Everything works as long as I only have the sample config.
                          But as soon as I have several other modules running (Page-Selector, Buttons, DWD-Warn-Wetter, PublicTransportHafas, etc.), it is no longer possible.
                          I would like to know what blocks the module.
                            shbatm Module Developer @robiv8
                            @robiv8 I don’t have a debug mode, but you can try adding:
                            console.log(notification, payload); to Line #988 of node_helper.js to print all notifications received by the back-end from other modules; or console.log(query) to Line #644. If you are using the API, you should be getting a response back in the browser or Postman.
                            Looking at your list, I have a sneaking suspicion that Page-Selector is causing the issues, just because it may be inadvertently suspending the module. If you troubleshoot and find that to be the case, and can’t find a work around with that module, you can try using MMM-Carousel w/ Navigation which is what Page-Selector was originally based off of. I know there is an option in that module to “exclude” a module from being suspended.
                            R 2 Replies Last reply
                              robiv8 @shbatm
                              @shbatm
                              Thanks for your explanation
                              I will try it tonight and then report it.
                              And yes, I also suspect that it is the page selector.
                              Whereby I set “Alert, notification, buttons and podcast2” to exclude. And nevertheless.
                              I’ll take a look.
                              • Cr4z33C
                                Cr4z33 @shbatm
                                @shbatm I’ve done the Italian translation if you want to add it. ;)
                                https://www.dropbox.com/s/u8hwhecv0exrmcj/it.json?dl=0
                                  robiv8 @shbatm
                                  @shbatm
                                  are you sure with console.log(notification, payload); to Line #988
                                  my node_helper.js is going only to line 958
                                    shbatm Module Developer @Cr4z33
                                    @cr4z33 thanks! I’ll add it when I get a chance.
                                      @robiv8 make sure your are on the develop branch (git checkout develop from a command line inside the module folder).
                                      https://github.com/shbatm/MMM-Remote-Control/blob/develop/node_helper.js#L988
                                      R 1 Reply Last reply
                                        robiv8 @shbatm
                                          robiv8
                                          OK So i can see that:
                                          REMOTE_CLIENT_CONNECTED {}
                                          0|mm  | REMOTE_ACTION { data: 'translations' }
                                          0|mm  | REMOTE_ACTION { action: 'SHOW_ALERT',
                                          0|mm  |   type: 'alert',
                                          0|mm  |   title: 'Test',
                                          0|mm  |   message: 'This is a test text',
                                          0|mm  |   timer: '4' }
                                          but nothing happened!
                                          The Devtools says:
                                          alert is suspended.
                                          updatenotification is suspended.
                                          so I mean you are right with MMM-Page-Selector
                                          Good to know on the one hand,
                                          but on the other SHIT
                                          I spent a lot of time making it look and working with the page selector.
                                          Now I can start over :-(
                                            robiv8
                                            One more question!
                                            Now I have 6 pages that I use with physical buttons.
                                            If I restart the setup now with Carousel which example am I taking?
                                            Global, Positional or Slides
                                            I found it out myself. :-)
                                            Thank you
                                            • 1 / 4
