    Troubleshooting MagicMirror
    19 Posts 5 Posters 7.8k Views 4 Watching
    • O Offline
      OthTheGentel
      Do I have to modify the script in config.js or go inside each folder in modules and customize them?
        Mykle1 Project Sponsor Module Developer @OthTheGentel
        @oththegentel said in Troubleshooting MagicMirror:
        You should only make changes to your config.js when adding or removing the modules you want to display. It is not recommended that you modify the module files.
        • O Offline
          OthTheGentel
          @Mykle1 Thank you for your answer.
            @oththegentel
            You’re welcome, mate.
            You might want to read this simple guide if you are unsure about adding modules to your config.js file.
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
            • O Offline
              OthTheGentel
              Is there any way to get an overview when I’m editing the config.js file
              I tried a web access to pi’s ip address and port from another computer on the same network but it’s not working even if i specified the ip address of pi in address section and allowed all ip addresses in ipwhitelist section!!
                @oththegentel
                This is not working for you?
                var config = {
                	address: "localhost",
                	port: 8080,
                	ipWhitelist: [],
                • O Offline
                  OthTheGentel @Mykle1
                  @mykle1 unfortunately not.
                  I put the wlan0 ip address of my pi instead of localhost and it’s not working neither.
                    @oththegentel
                    Long shot:
                    Try address: "0.0.0.0",
                    • O Offline
                      @mykle1 Nope even locally
                      I’ll scan all my ports and check if 8080 is already used
                      D idoodlerI 2 Replies Last reply Reply Quote 0
                        dazza120 @OthTheGentel
                        @oththegentel enable VNC and patch in using that, I’m doing changes on my phone using that method it’s not the best given the screen size normally I do adjustments on the Mac when I can be bothered to boot it up, last minute changes are done on the phone.
                        • idoodlerI Offline
                          idoodler Module Developer @OthTheGentel
                          @oththegentel It sounds like your MagicMirror instance is not running.
                          How did you start MagicMirror, do you have pm2 installed?
