    Troubleshooting MagicMirror
    19 Posts 5 Posters 7.7k Views 4 Watching
      dazza120 @OthTheGentel
      @oththegentel delete the folder and do the manual method I’m not sure if pm2 start mm work doing it that method, ie when you reboot it I did put the pm2 script in a thread on the site that worked for me, so use the manual method then reboot and see if the mirror comes back online if not look for pm2 restart
      If PM2 gives you trouble use https://forum.magicmirror.builders/topic/8987/pm2-error/13
        @oththegentel your pi up to date? Get all updates for the pi and try again
          bhepler Module Developer @OthTheGentel
          @oththegentel - You can install over top of a busted installation. Any attempts to install dependencies that you already have in place will automatically be intercepted and you’ll see a message saying that there’s nothing to install.
          It sure sounds like Node didn’t install correctly. The connection issue is probably on their end (I’m assuming your local network isn’t in the 173.209.xxx.xxx range). This is most likely temporary and once someone notices, they’ll get it back up & running. Keep trying!
          • O Offline
            OthTheGentel @dazza120
            @dazza120 Perfect thanks a lot man it’s working now.
            So the next step, i copied the file /home/pi/MagicMirror/config/config.js.sample to /home/pi/MagicMirror/config/config.js
            Do I have to modify the script in config.js or go to inside each folder in modules and customize them?
            • O Offline
              OthTheGentel @bhepler
              @bhepler Thanks for your help, it’s working now. I deleted the folder and installed it with the manual method :thumbs_up:
              • O Offline
                OthTheGentel
                Do I have to modify the script in config.js or go inside each folder in modules and customize them?
                  Mykle1 Project Sponsor Module Developer @OthTheGentel
                  @oththegentel said in Troubleshooting MagicMirror:
                  You should only make changes to your config.js when adding or removing the modules you want to display. It is not recommended that you modify the module files.
                  • O Offline
                    OthTheGentel
                    @Mykle1 Thank you for your answer.
                      @oththegentel
                      You’re welcome, mate.
                      You might want to read this simple guide if you are unsure about adding modules to your config.js file.
                      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                      • O Offline
                        OthTheGentel
                        Is there any way to get an overview when I’m editing the config.js file
                        I tried a web access to pi’s ip address and port from another computer on the same network but it’s not working even if i specified the ip address of pi in address section and allowed all ip addresses in ipwhitelist section!!
                          @oththegentel
                          This is not working for you?
                          var config = {
                          	address: "localhost",
                          	port: 8080,
                          	ipWhitelist: [],
                          • O Offline
                            OthTheGentel @Mykle1
                            @mykle1 unfortunately not.
                            I put the wlan0 ip address of my pi instead of localhost and it’s not working neither.
                              @oththegentel
                              Long shot:
                              Try address: "0.0.0.0",
                              • O Offline
                                @mykle1 Nope even locally
                                I’ll scan all my ports and check if 8080 is already used
                                D idoodlerI 2 Replies Last reply Reply Quote 0
                                  @oththegentel enable VNC and patch in using that, I’m doing changes on my phone using that method it’s not the best given the screen size normally I do adjustments on the Mac when I can be bothered to boot it up, last minute changes are done on the phone.
                                  • idoodlerI Offline
                                    idoodler Module Developer @OthTheGentel
                                    @oththegentel It sounds like your MagicMirror instance is not running.
                                    How did you start MagicMirror, do you have pm2 installed?
