RTSP Stream error since last Update
4 Posts 4 Posters 1.5k Views 4 Watching
  • N Offline
    Niggich
    Hallo @shbatm, hallo everybody,
    since I install the last update of your Module I get the following error. Maybe you can help me…
    0|mm       |     TypeError: Cannot read property 'omxRestart' of undefined
    0|mm       |     at pm2.start (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:155:85)
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1017:21
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1088:19
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:473:16
    0|mm       |     at replenish (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:1006:25)
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:1016:9
    0|mm       |     at Object.eachLimit$1 (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:3196:24)
    0|mm       |     at startApps (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1033:11)
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1015:14
    0|mm       |     at iterateeCallback (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:992:24)
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/async/dist/async.js:969:16
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1007:16
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1342:19
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:1338:16
    0|mm       |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
    0|mm       |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
    0|mm       |     at emitOne (events.js:116:13)
    0|mm       |     at Parser.emit (events.js:211:7)
    THX
    • T Offline
      tobiv
      i have exact the same problem! I have two RTSP-Streams implemented, the first one doesn’t start, the second one works!
      Greetings
      D 1 Reply Last reply Dec 28, 2018, 1:54 PM Reply Quote 0
        djuscha @tobiv
        @tobiv
        did you find any mistakes?
          shbatm Module Developer
          I’ve updated the develop branch of the module, please see the main MMM-RTSPStream Thread and update to the latest version on the develop branch.
