Unsolved Face Recognition with inferred light
This might work though, if you’re using either an rPi camera, or something similar. If you’re going to put the camera in the frame, you’ll be drilling a hole. Why not two more for the IR lights as well. And at 3W each, that’s mighty bright. http://amzn.com/B00ZEFIU6C
hmmmm. thanks sounds like a plan.
I think i have to drill one larger hole, otherwise the photodiode cant see wether its dark or not hm?
A small hole next to the large one, enough for light to go through, should work. Usually it’s a tiny pinhole, but that’s also assuming the sensor is literally right up against the pinhole.
so still the problem with not logging in correctly :(
Is there any log in the Web inspector?
How can I see the web inspector?
@feuerball try
alt
cmd
I
Gonna give this a try when I’m back@home
@feuerball please press on
main.js
on the right so we can see on what it tries to execute the lower case thing.
