    Any youtube tutorials?
    11 Posts 8 Posters 7.9k Views 6 Watching
      azza_pazza
      Really struggling with the whole project. I’m pretty sure I’ve deleted wifi off of my Raspberry Pi. npm start just never worked and I’ve destroyed the config file countless times. Any help would be appreciated.
      • KirAsh4K Offline
        KirAsh4 Moderator
        Not a YouTube, but perhaps this can help you:
        https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
        • andrewchumchalA Offline
          andrewchumchal
          @azza_pazza. If that still dose not help ^^. Feel free to messages me. I will give you some help as well.
            azza_pazza @KirAsh4
            @KirAsh4 Thanks, I’m going to give this a try now!
              azza_pazza @andrewchumchal
              @andrewchumchal thanks very much, I’ll let you know how I get on.
                creye
                Hows it going? I myself is a total amateur also, so I can relate to the struggle. :D
                  bartalluyn
                  Maybe my blog can help?
                  https://smartmirrorprojectblog.wordpress.com
                    PindaPower
                    Good work guys.
                    • cowboysdudeC Offline
                      @creye @azza_pazza
                      Don’t feel bad a couple months ago I was a total noob at this too.
                      Here’s what I did… I read… alot. If you get an error either come here and ask OR look it the exact error on the internet… you’d be shocked to find how many times that error has happened :)
                      Next do this -> GO HERE…
                      https://github.com/MichMich/MagicMirror
                      There are two sets of instructions…
                      *Easy install
                      • Manual install -> I found that this worked best for me…
                      Remember it’s not a race, take your time… drink a coffee and relax. We’ll do what we can to help get you there.
                      IF you have questions or find you just can’t figure it out we’ll help you :)
                      Rule #1… ALWAYS…ALWAYS…ALWAYS… DO THIS BEFORE YOU CHANGE YOUR CONFIG.JS FILE
                      If you have a working config.js file before you make ANY changes to it ----->
                      cd ~/MagicMirror/config
                      cp config.js config.bak
                      That way if you have any issues when you make changes you have a backup to look at to see where you went wrong or you can just delete the config.js file and …
                      cp config.bak config.js
                      Then it’s working again! :)
                      NEVER delete the config.js.sample file… in the beginning I found this to be VERY helpeful to reference.
                      Common mistakes in config.js files… missing commas or missing { }
                      As for install issues they happen… generally [and don’t get offended please]
                      because something gets skipped.
                      @MichMich has done an excellent job with the instructions on that page so they do work very well.
                      Hang in there… :)
                      • MichMichM Offline
                        MichMich
                        What helps if you have issues with your config file is to pass it into http://jshint.com.
                        It should give no errors, other than one minor warning which probably states:
                        One undefined variable
                        	module
                        All other errors should be fixed before your config is able to work properly.
