    regions...
    31 Posts 11 Posters 15.6k Views 15 Watching
      A Former User @justjim1220
      @justjim1220
      You should modify main.js which has a definition of module position hardcoded
      justjim1220J 1 Reply Last reply Reply Quote 1
      • yawnsY Offline
        yawns Moderator
        Shouldn’t the index.html be changed as well to add additional divs with his classes?
        justjim1220J 1 Reply Last reply Reply Quote 2
        • justjim1220J Offline
          justjim1220 Module Developer @sdetweil
          The real estate is there when using a 46" TV as a monitor, and it can always be modified with using ‘zoom’ or ctrl - or ctrl shift +
          I did try modifying the main.css also, still no luck.
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
            justjim1220 Module Developer @Guest
            @sean
            I tried to modify the main.css and it didn’t do anything.
            Jim Hallock - 1995
              justjim1220 Module Developer @yawns
              @yawns
              never thought to look there, will try it and see if it works, thanks!
              Jim Hallock - 1995
                sdetweil @justjim1220
                @justjim1220 others noted that you will also have to edit the index.html to add the regions and the main.js
                var updateWrapperStates = function() {
                var positions = [“top_bar”, “top_left”, “top_center”, “top_right”, “upper_third”, “middle_center”, “lower_third”, “bottom_left”, “bottom_center”, “bottom_right”, “bottom_bar”, “fullscreen_above”, “fullscreen_below”];
                which lists all the known regions
                justjim1220J 2 Replies Last reply Reply Quote 2
                  thanks, was looking at that just now. :winking_face:
                  Jim Hallock - 1995
                  • G Offline
                    geograha @justjim1220
                    @justjim1220 I’m actually trying to do the exact same thing, but very limited knowledge with css. I’d be curious to see your index.html and main.css files if you get this working as expected. I updated main.js to be aware of the positions for now and am going to dig into creating the separate regions
                      justjim1220 Module Developer @geograha
                      @geograha
                      Sorry, got sidetracked into doing other stuff
                      My investigating showed there are a few places needing changed within MM code to get it to work
                      I haven’t given up, just placed it on the back burner for now.
                      Likewise with you, if you happen to figure it out before I do, let me know what you did. :winking_face:
                      Jim Hallock - 1995
                      • BKeyportB Offline
                        BKeyport Module Developer
                        I’d love to see this - I’ve got a ton of dead space on my MM because of the lack of 5 columns of info.
                        justjim1220J 2 Replies Last reply Reply Quote 0
                        • 1 / 4
