    regions...
    31 Posts 11 Posters 15.8k Views 15 Watching
    • justjim1220J Offline
      justjim1220 Module Developer
      is there any way to add regions to MM?
      For instance: where middle_center is , how could i be change to add middle_left and middle_right?
      Also, could there be a way to get more than 3 in a section?
      IE: currently we have top_left, top_center, & top_right
      Could it be changed to have 4 or 5 sections?
      My interest is to have modules as a frame to a completely blank center
      16 modules:
      top_left            top_left_center           top_center           top_right_center             top_right
      middle_top_left        middle_top_right
      middle_center_left        middle_center_right
      middle_bottom_left        middle_bottom_right
      bottom_left        bottom_left_center        bottom_center        bottom_right_center        bottom_right
      would this be possible???
      I’ve tried to declare them in custom.css, but of course, it didn’t work, so I am assuming they are declared elsewhere in MM’s core coding…
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
      S ? 2 Replies Last reply Reply Quote 0
        sdetweil @justjim1220
        @justjim1220 they are in MM/css/main.css
        there isn’t much real estate to make many distinct regions…
          A Former User @justjim1220
          @justjim1220
          You should modify main.js which has a definition of module position hardcoded
          justjim1220J 1 Reply Last reply Reply Quote 1
          • yawnsY Offline
            yawns Moderator
            Shouldn’t the index.html be changed as well to add additional divs with his classes?
            justjim1220J 1 Reply Last reply Reply Quote 2
              justjim1220 Module Developer @sdetweil
              The real estate is there when using a 46" TV as a monitor, and it can always be modified with using ‘zoom’ or ctrl - or ctrl shift +
              I did try modifying the main.css also, still no luck.
              Jim Hallock - 1995
                justjim1220 Module Developer @Guest
                @sean
                I tried to modify the main.css and it didn’t do anything.
                Jim Hallock - 1995
                  justjim1220 Module Developer @yawns
                  @yawns
                  never thought to look there, will try it and see if it works, thanks!
                  Jim Hallock - 1995
                    @justjim1220 others noted that you will also have to edit the index.html to add the regions and the main.js
                    var updateWrapperStates = function() {
                    var positions = [“top_bar”, “top_left”, “top_center”, “top_right”, “upper_third”, “middle_center”, “lower_third”, “bottom_left”, “bottom_center”, “bottom_right”, “bottom_bar”, “fullscreen_above”, “fullscreen_below”];
                    which lists all the known regions
                    justjim1220J 2 Replies Last reply Reply Quote 2
                      thanks, was looking at that just now. :winking_face:
                      Jim Hallock - 1995
                      • G Offline
                        geograha @justjim1220
                        @justjim1220 I’m actually trying to do the exact same thing, but very limited knowledge with css. I’d be curious to see your index.html and main.css files if you get this working as expected. I updated main.js to be aware of the positions for now and am going to dig into creating the separate regions
                          justjim1220 Module Developer @geograha
                          @geograha
                          Sorry, got sidetracked into doing other stuff
                          My investigating showed there are a few places needing changed within MM code to get it to work
                          I haven’t given up, just placed it on the back burner for now.
                          Likewise with you, if you happen to figure it out before I do, let me know what you did. :winking_face:
                          Jim Hallock - 1995
                          • BKeyportB Online
                            BKeyport Module Developer
                            I’d love to see this - I’ve got a ton of dead space on my MM because of the lack of 5 columns of info.
                            justjim1220J 2 Replies Last reply Reply Quote 0
                              justjim1220 Module Developer @BKeyport
                              @bkeyport
                              I know the feeling
                              To keep up with the ‘mirror’ effect, I am wanting to surround the middle with a ‘frame’ of modules
                              Kinda like a monopoly game board with the middle or inside the properties being free of any modules to keep the mirror functioning as a mirror
                              Of course I am trying to make one with a 42" tv, rotated vertical, so I will have plenty of room at the top and bottom for more than one row of modules
                              My first idea, was to figure out how to show the modules in a frame around a working TV, without any interference to what is being watched. Which Is what I really want to be able to do!
                              Jim Hallock - 1995
                                @bkeyport
                                I don’t even really need modules on the sides, I have been paying attention a lot to how most tv I watch, which are movies, they almost always have a black area at the top and bottom of the screen. It’s getting the modules and the tv to display at the same time!
                                Jim Hallock - 1995
                                • cowboysdudeC Offline
                                  You don’t need to create new regions…just make your module width larger…
                                  There is no need to create new regions when you can just ‘stack’ your modules and they will move automatically…
                                    justjim1220 Module Developer @cowboysdude
                                    @cowboysdude
                                    Moy sure I am following what you mean
                                    Jim Hallock - 1995
                                      @cowboysdude
                                      the reasoning for our inquiry is to have more than 3 regions like in the top or bottom
                                      I would like to have 5 (or more) modules side by side across the top or bottom
                                      Stacking the modules? that is still 3 regions, but having modules on top of each other in each region, not side by side
                                      Jim Hallock - 1995
                                        If you put more then one module in a region starting with the top of the config down will stack them in the region you put them in…
                                        S justjim1220J 2 Replies Last reply Reply Quote 0
                                          sdetweil @cowboysdude
                                          @cowboysdude he doesn’t want stack, he wants side by side
                                            @cowboysdude
                                            Just forget it. You don’t seem to be grasping the concept we are referring to.
                                            I know you feel that I am just a dumbass
                                            So, don’t anyone listen to me any more!
                                            Geez!
                                            Jim Hallock - 1995
