    regions...
    31 Posts 11 Posters 19.2k Views 15 Watching
    • justjim1220J
      justjim1220 Module Developer @sdetweil
      The real estate is there when using a 46" TV as a monitor, and it can always be modified with using ‘zoom’ or ctrl - or ctrl shift +
      I did try modifying the main.css also, still no luck.
      Jim Hallock - 1995
      • justjim1220J
        justjim1220 Module Developer @Guest
        @sean
        I tried to modify the main.css and it didn’t do anything.
        Jim Hallock - 1995
        • justjim1220J
          justjim1220 Module Developer @yawns
          @yawns
          never thought to look there, will try it and see if it works, thanks!
          Jim Hallock - 1995
            sdetweil @justjim1220
            @justjim1220 others noted that you will also have to edit the index.html to add the regions and the main.js
            var updateWrapperStates = function() {
            var positions = [“top_bar”, “top_left”, “top_center”, “top_right”, “upper_third”, “middle_center”, “lower_third”, “bottom_left”, “bottom_center”, “bottom_right”, “bottom_bar”, “fullscreen_above”, “fullscreen_below”];
            which lists all the known regions
            justjim1220J 2 Replies Last reply
            Reply Quote 2
            • justjim1220J
              thanks, was looking at that just now. :winking_face:
              Jim Hallock - 1995
              G 1 Reply Last reply
              • G
                geograha @justjim1220
                @justjim1220 I’m actually trying to do the exact same thing, but very limited knowledge with css. I’d be curious to see your index.html and main.css files if you get this working as expected. I updated main.js to be aware of the positions for now and am going to dig into creating the separate regions
                justjim1220J 1 Reply Last reply
                • justjim1220J
                  justjim1220 Module Developer @geograha
                  @geograha
                  Sorry, got sidetracked into doing other stuff
                  My investigating showed there are a few places needing changed within MM code to get it to work
                  I haven’t given up, just placed it on the back burner for now.
                  Likewise with you, if you happen to figure it out before I do, let me know what you did. :winking_face:
                  Jim Hallock - 1995
                  • BKeyportB
                    BKeyport Module Developer
                    I’d love to see this - I’ve got a ton of dead space on my MM because of the lack of 5 columns of info.
                    • justjim1220J
                      justjim1220 Module Developer @BKeyport
                      @bkeyport
                      I know the feeling
                      To keep up with the ‘mirror’ effect, I am wanting to surround the middle with a ‘frame’ of modules
                      Kinda like a monopoly game board with the middle or inside the properties being free of any modules to keep the mirror functioning as a mirror
                      Of course I am trying to make one with a 42" tv, rotated vertical, so I will have plenty of room at the top and bottom for more than one row of modules
                      My first idea, was to figure out how to show the modules in a frame around a working TV, without any interference to what is being watched. Which Is what I really want to be able to do!
                      Jim Hallock - 1995
                      • justjim1220J
                        @bkeyport
                        I don’t even really need modules on the sides, I have been paying attention a lot to how most tv I watch, which are movies, they almost always have a black area at the top and bottom of the screen. It’s getting the modules and the tv to display at the same time!
                        Jim Hallock - 1995
                        • cowboysdudeC
                          You don’t need to create new regions…just make your module width larger…
                          There is no need to create new regions when you can just ‘stack’ your modules and they will move automatically…
                          • justjim1220J
                            justjim1220 Module Developer @cowboysdude
                            @cowboysdude
                            Moy sure I am following what you mean
                            Jim Hallock - 1995
                            • justjim1220J
                              @cowboysdude
                              the reasoning for our inquiry is to have more than 3 regions like in the top or bottom
                              I would like to have 5 (or more) modules side by side across the top or bottom
                              Stacking the modules? that is still 3 regions, but having modules on top of each other in each region, not side by side
                              Jim Hallock - 1995
                              • cowboysdudeC
                                If you put more then one module in a region starting with the top of the config down will stack them in the region you put them in…
                                S justjim1220J 2 Replies Last reply
                                  sdetweil @cowboysdude
                                  @cowboysdude he doesn’t want stack, he wants side by side
                                  • justjim1220J
                                    @cowboysdude
                                    Just forget it. You don’t seem to be grasping the concept we are referring to.
                                    I know you feel that I am just a dumbass
                                    So, don’t anyone listen to me any more!
                                    Geez!
                                    Jim Hallock - 1995
                                    • BKeyportB
                                      Stacking is great, but for those of us that have landscape mode monitors, that becomes useless rather quickly. I’d rather have the modules sit next to each other.
                                      My one mirror at home will go Portrait mode eventually, so the stacking will work… the one at work (due to a broken part) will always be landscape.
                                        Smotx
                                        I love that (and you) if you find how to have 5 ragions on the same line, i need to display MM on my TV !
                                        • justjim1220J
                                          Any chance you ever try this?
                                          Jim Hallock - 1995
                                          • I
                                            isaac2004
                                            Is there a way to “hover” modules over eachother. For instance if I use Lucy to “SHOW” a module, I want it to float above all other modules. Currently, it pushes modules down.
                                            Mykle1M R justjim1220J 3 Replies Last reply
