    [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server
    47 Posts 17 Posters 41.2k Views 18 Watching
      barnosch
      Awesome. Thanks, dude.
      made some little adustments to fit my needs.
      The only thing which i think could be also interesting is maybe the temperatures of the nozzle and the bed?
        shbatm Module Developer
        @barnosch: Made some more changes:
        • Implemented MM Translations and added English and what I could of German.
        • Added most recent nozzle & bed target & actual temperatures – can be enabled/disabled with showTemps config option.
        • Added option to hide the file, time, and temps when the printer is offline – can be enable/disabled with showDetailsWhenOffline option.
        You’ll have to move your lines around again after you update it–for now, anyway–I’m adding “Add Stylesheet and auto format for width” to my to-do list for the module, as well as hide camera window when not printing.
          barnosch
          Perfect! Already pulled and adjusted.
          Thank you really much.
          I appreciate your fast and nice work.
            barnosch
            Is there any chance to give the stream object a CSS name to override the common resolution of the webstream via CSS?
            Right now, as i can see it, it fetches the stream from http://octopiIP:8080 as it is.
            Thats killing my mirror ;)
              @barnosch - it’s on the To-do list.
              For now, try setting the height/width in your custom.css file with something like:
              div.octomirror-module img {
                  height: 150px;
                  width: 150px;
              EDIT: Removed the > in the selector line above.
                barnosch
                Great. Good idea, since it is “only” a img tag, it is pretty easy.
                i was thinking to complicated. Now it fits nicely.
                Looking forward for the “hide camera window when not printing” feature.
                But no hurry.
                Great work!
                • michael24hM Offline
                  michael24h
                  My stream showing upside down. any idea ?
                    michael24h
                    this works for me:
                    transform: rotate(180deg);
                      d3r
                      Installed this on my pi3 for the Mp select mini today. This is great!
                      • citizendevpiC Offline
                        citizendevpi
                        I can not seam to get the informatin to show up all items say n/a but my video shows no problem, would realy apricate any help
                          Can you please post your config section? Have you enabled the API and provided an API key?
                          citizendevpiC 2 Replies Last reply Reply Quote 0
                            michael24h
                            @shbatm said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                              citizendevpi @shbatm
                              @shbatm
                                      module: "octomirror-module",
                                      position: "bottom_left",
                                          url: "http://192.168.2.141",
                                          api_key: "B7ACF3C4BDD04D61BF5176C75778661E",
                              so i obviously cannot figure out how to copy paste my config i feel like i have some issues
                                @shbatm yes I have enabled the API as you can c it is in my config
                                  shbatm Module Developer @citizendevpi
                                  @citizendevpi Try adding debugMode: true, to the config and see if you get any useful information in the logs. I can’t remember if they’ll show up in the console or DevTools. Also, it’s been a while since I’ve used the module, but it will only show data when it’s actually printing too.
                                    michael24h
                                    @citizendevpi said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                    url: “http://192.168.2.141”
                                    Looks like link isn’t complete. Should looks like this http://ip_address/webcam/?action=stream
                                            module: 'MMM-MotionEye',
                                            position: 'top_right',
                                                config:  {
                                                width: "460px",
                                                autoHide: false,
                                                url: "http://octoprint IP address/webcam/?action=stream",
                                                debug: false,
                                                user: "pi"
                                    I hope this will help you
                                      michael24h
                                      Try open octoprint > go to webcam > then open image in new tab. and copy http address from web browser to your config file in octomirror-module.
                                        shbatm Module Developer @michael24h
                                        @michael24h said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                        Nope, that shouldn’t be it. He said his stream was working and the url parameter is just for the octopi instance, not the stream. The module assumes it needs to add /webcam/?action=stream” unless streamUrl is provided.
                                          @citizendevpi
                                          Just confirming: you are using my version https://github.com/shbatm/octomirror-module not the original, correct?
                                            @shbatm let me check and yes u are correct I do have my stream no problem but no info and I would only expect it to give me stats when printing
