    [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server
    47 Posts 17 Posters 41.7k Views 18 Watching
      barnosch
      Perfect! Already pulled and adjusted.
      Thank you really much.
      I appreciate your fast and nice work.
        barnosch
        Is there any chance to give the stream object a CSS name to override the common resolution of the webstream via CSS?
        Right now, as i can see it, it fetches the stream from http://octopiIP:8080 as it is.
        Thats killing my mirror ;)
          shbatm Module Developer
          @barnosch - it’s on the To-do list.
          For now, try setting the height/width in your custom.css file with something like:
          div.octomirror-module img {
              height: 150px;
              width: 150px;
          EDIT: Removed the > in the selector line above.
            barnosch
            Great. Good idea, since it is “only” a img tag, it is pretty easy.
            i was thinking to complicated. Now it fits nicely.
            Looking forward for the “hide camera window when not printing” feature.
            But no hurry.
            Great work!
            • michael24hM Offline
              michael24h
              My stream showing upside down. any idea ?
                michael24h
                this works for me:
                transform: rotate(180deg);
                  d3r
                  Installed this on my pi3 for the Mp select mini today. This is great!
                  • citizendevpiC Offline
                    citizendevpi
                    I can not seam to get the informatin to show up all items say n/a but my video shows no problem, would realy apricate any help
                      Can you please post your config section? Have you enabled the API and provided an API key?
                      citizendevpiC 2 Replies Last reply Reply Quote 0
                        michael24h
                        @shbatm said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                          citizendevpi @shbatm
                          @shbatm
                                  module: "octomirror-module",
                                  position: "bottom_left",
                                      url: "http://192.168.2.141",
                                      api_key: "B7ACF3C4BDD04D61BF5176C75778661E",
                          so i obviously cannot figure out how to copy paste my config i feel like i have some issues
                            @shbatm yes I have enabled the API as you can c it is in my config
                              shbatm Module Developer @citizendevpi
                              @citizendevpi Try adding debugMode: true, to the config and see if you get any useful information in the logs. I can’t remember if they’ll show up in the console or DevTools. Also, it’s been a while since I’ve used the module, but it will only show data when it’s actually printing too.
                                michael24h
                                @citizendevpi said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                url: “http://192.168.2.141”
                                Looks like link isn’t complete. Should looks like this http://ip_address/webcam/?action=stream
                                        module: 'MMM-MotionEye',
                                        position: 'top_right',
                                            config:  {
                                            width: "460px",
                                            autoHide: false,
                                            url: "http://octoprint IP address/webcam/?action=stream",
                                            debug: false,
                                            user: "pi"
                                I hope this will help you
                                  michael24h
                                  Try open octoprint > go to webcam > then open image in new tab. and copy http address from web browser to your config file in octomirror-module.
                                    shbatm Module Developer @michael24h
                                    @michael24h said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                    Nope, that shouldn’t be it. He said his stream was working and the url parameter is just for the octopi instance, not the stream. The module assumes it needs to add /webcam/?action=stream” unless streamUrl is provided.
                                      @citizendevpi
                                      Just confirming: you are using my version https://github.com/shbatm/octomirror-module not the original, correct?
                                        @shbatm let me check and yes u are correct I do have my stream no problem but no info and I would only expect it to give me stats when printing
                                          @shbatm yes shbatm/octomirror-module
                                            citizendevpi
