    [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server
    47 Posts 17 Posters 41.2k Views 18 Watching
      shbatm Module Developer
      Description:
      Monitor & Control an OctoPrint 3D Printer Server. Originally created by @DongerZonnie, expanded & updated by @shbatm
      The module will allow you to:
      View a live feed of the raspicam stream
      Start and stop prints
      View G-Code viewer
      Manually control the printer
      Recieve live updates on printer status
      Screenshots:
      Download:
      [card:shbatm/octomirror-module]
      Version 1.0.4
      • Implemented translations feature and added English & German
      • Added ability to show most recent temperatures
      • Added ability to hide additional details when the printer is offline.
      Version 1.0.3
      • Added options to disable camera feed and customize stream URL.
      Version 1.0.2
      • Refactored to use OctoPrint Client JS library and provide live updates via SockJS connection.
        barnosch
        Nice!
        Since i only have a 19" MM (going to update to 22" these days) i do not have enough space left for this nice little thing.
        I guess my wife would slowly start to kill me, if i would add a stream of the actual print ;)
        since the printer is only 5 meters away from the Mirror
        Need to build another mirror i guess :P
          barnosch
          Would it be possible to just see the
          status like ETA and % and the stream optional?
          Exactly like your screenshot, but without the stream?
          I guess i would find some place for that infromation ;)
            @barnosch Yep! Done! Pull the updated version and add showStream: false to your config.
            Also FYI – right now I only include the information useful to me, but the module interacts with the full OctoPrint API, so if there’s something else you’d like to see, or want to customize how it’s displayed, please let me know!
            API Reference – http://docs.octoprint.org/en/master/api/push.html
              barnosch
              Awesome. Thanks, dude.
              made some little adustments to fit my needs.
              The only thing which i think could be also interesting is maybe the temperatures of the nozzle and the bed?
                @barnosch: Made some more changes:
                • Implemented MM Translations and added English and what I could of German.
                • Added most recent nozzle & bed target & actual temperatures – can be enabled/disabled with showTemps config option.
                • Added option to hide the file, time, and temps when the printer is offline – can be enable/disabled with showDetailsWhenOffline option.
                You’ll have to move your lines around again after you update it–for now, anyway–I’m adding “Add Stylesheet and auto format for width” to my to-do list for the module, as well as hide camera window when not printing.
                  barnosch
                  Perfect! Already pulled and adjusted.
                  Thank you really much.
                  I appreciate your fast and nice work.
                    barnosch
                    Is there any chance to give the stream object a CSS name to override the common resolution of the webstream via CSS?
                    Right now, as i can see it, it fetches the stream from http://octopiIP:8080 as it is.
                    Thats killing my mirror ;)
                      @barnosch - it’s on the To-do list.
                      For now, try setting the height/width in your custom.css file with something like:
                      div.octomirror-module img {
                          height: 150px;
                          width: 150px;
                      EDIT: Removed the > in the selector line above.
                        barnosch
                        Great. Good idea, since it is “only” a img tag, it is pretty easy.
                        i was thinking to complicated. Now it fits nicely.
                        Looking forward for the “hide camera window when not printing” feature.
                        But no hurry.
                        Great work!
                        • michael24hM Offline
                          michael24h
                          My stream showing upside down. any idea ?
                            michael24h
                            this works for me:
                            transform: rotate(180deg);
                              d3r
                              Installed this on my pi3 for the Mp select mini today. This is great!
                              • citizendevpiC Offline
                                citizendevpi
                                I can not seam to get the informatin to show up all items say n/a but my video shows no problem, would realy apricate any help
                                  Can you please post your config section? Have you enabled the API and provided an API key?
                                  citizendevpiC 2 Replies Last reply Reply Quote 0
                                    michael24h
                                    @shbatm said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                      citizendevpi @shbatm
                                      @shbatm
                                              module: "octomirror-module",
                                              position: "bottom_left",
                                                  url: "http://192.168.2.141",
                                                  api_key: "B7ACF3C4BDD04D61BF5176C75778661E",
                                      so i obviously cannot figure out how to copy paste my config i feel like i have some issues
                                        @shbatm yes I have enabled the API as you can c it is in my config
                                          shbatm Module Developer @citizendevpi
                                          @citizendevpi Try adding debugMode: true, to the config and see if you get any useful information in the logs. I can’t remember if they’ll show up in the console or DevTools. Also, it’s been a while since I’ve used the module, but it will only show data when it’s actually printing too.
                                            michael24h
                                            @citizendevpi said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
                                            url: “http://192.168.2.141”
                                            Looks like link isn’t complete. Should looks like this http://ip_address/webcam/?action=stream
                                                    module: 'MMM-MotionEye',
                                                    position: 'top_right',
                                                        config:  {
                                                        width: "460px",
                                                        autoHide: false,
                                                        url: "http://octoprint IP address/webcam/?action=stream",
                                                        debug: false,
                                                        user: "pi"
                                            I hope this will help you
