    Correct Weather Module
    3 Posts 3 Posters 1.3k Views 3 Watching
    • T Offline
      txajay
      Hi Guys,
      I’m curious to know what everyone here is using. I recently started my MagicMirror build and have been messing around with the modules seeing out how I’m going to make this look. The one thing bugging me most is the weather module. I started off with the default weather module using openweathermap, but like others I am having the same issue, displaying wrong values and is off by 10 degrees mostly.
      I tried to use the MM-WUnderground module, but it seems like weatherunderground no longer provides a free api-key.
      Has anyone here found a reliable weather module that can be used.
      Thanks,
      AJ
      M Mykle1M 2 Replies Last reply Reply Quote 0
        mdhenriksen @txajay
        @txajay Hey AJ! I think there is one called DarkSky or at least one there is based on that. It seems to work as it should and also looks quite nice! Let me know if it does the trick. 😄
          Mykle1 Project Sponsor Module Developer @txajay
          @txajay
          There are quite a few weather modules. Just scroll down to the weather section.
          https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
