    modules day and time Depending represented
    29 Posts 7 Posters 23.1k Views 7 Watching
    • cowboysdudeC Offline
      Now here’s a challenge for you LOL
      Say you’d like a module to appear at 7 am until 8 am then again at 5pm until 11pm could it be worked so it could be set up like this:
      module: ‘calendar’,
      header: ‘US Holidays’,
      position: ‘top_left’,
      classes: ‘scheduler’,
      // DISPLAY THE CALENDAR BETWEEN 09:00 and 18:00 ON WEDNESDAYS
      schedule1: {from: ‘0 7 * * 3’, to: ‘0 8 * * 3’ },
      schedule2: {from: ‘0 17 * * 3’, to: ‘0 23 * * 3’ },
      symbol: 'calendar-check-o ',
      url: ‘webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics’
      Just a thought but it could be useful :) My other thought was to enter the module twice and run it the way it’s written… going to test that :)
      I tested that and that works ! :) The logic of the mirror just loads the modules [if in the config correctly] will load it as many times as you want! So I had it come on at 7 and go off at 8:30 then back on at 8:32 and that worked great! Not sure how hard it would be to change it to work but could just add another layer to the module :)
      • I Offline
        ianperrin
        @cowboysdude - rather than add two instances of the module, try the following expressions:
        module_schedule: {from: '0 7,17 * * *', to: '0 8,23 * * *'}
        This should create a schedule with jobs to show the module at 07:00hrs and 17:00hrs, and jobs to hide the module at 08:00hrs and 23:00hrs
        I can see there are use cases where multiple schedules might be required, so I’ve created an enhancement request on github to cover that one - https://github.com/ianperrin/MMM-ModuleScheduler/issues/2
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
          cowboysdude Module Developer @ianperrin
          @ianperrin Thank you! I’ll give that a go when I get home from work. This module is just about the handiest things I have seen!!!
          I guess had I investigated cron I could have found that out myself… sorry.
          With this I no longer wish the pi to ‘go to sleep’… I just show certain things at certain times and always leave the time and date on… it’s just amazing!!! You don’t realize how useful and important something sometimes until you have it!
          Thanks again!
            shashank @ianperrin
            @ianperrin I installed this modules and it found working fine.
            I S 2 Replies Last reply Reply Quote 0
            • I Offline
              ianperrin @shashank
              @shashank - great to hear - and thanks for the feedback.
              • I Offline
                ianperrin @cowboysdude
                @cowboysdude said in modules day and time Depending represented:
                Glad to help and no need to apologise at all
                • MitchfarinoM Offline
                  Mitchfarino Module Developer
                  Not implemented this yet @ianperrin , but this is an incredible contribution. We can make much more use of the modules now, rather than being limited to a certain number
                    cowboysdude Module Developer @Mitchfarino
                    @Mitchfarino said in modules day and time Depending represented:
                    This should be right in the install!! :)
                      bjoern
                      WORKS FINE! Thanks!
                        shashank @shashank
                        @shashank i configured this scheduler today with Calendar and Wunderground, after the end time the module will not disappear, i need to stop and start the MM.
                        module: ‘calendar’,
                        module_schedule: {from: ‘0 9 * * FRI’, to: ‘20 21 * * SAT’ },
                        • I Offline
                          ianperrin @shashank
                          @shashank said in modules day and time Depending represented:
                          Looking at your config, I can see a couple of potential issues
                          Firstly, make sure you use straight apostrophes (') not curly ones (‘ ’).
                          Secondly, the expressions in the module_schedule config option (module_schedule: {from: '0 9 * * FRI', to: '20 21 * * SAT' },) should schedule the calendar so it is displayed at 09:00 on Friday and be hidden at 21:20 on Saturday.
                          Is this what you intended? If so, check the logs (pm2 logs mm), you should see something like this.
                          MMM-ModuleScheduler received CREATE_MODULE_SCHEDULE
                          MMM-ModuleScheduler is scheduling calendar using '0 9 * * FRI' and '20 21 * * SAT'
                          MMM-ModuleScheduler has scheduled calendar
                          MMM-ModuleScheduler will next show calendar at Fri Sep 23 2016 09:00:00 GMT+0000 (UTC)
                          MMM-ModuleScheduler will next hide calendar at Sat Sep 17 2016 21:20:00 GMT+0000 (UTC)
                          Note the last two lines will vary depending on when start the mirror. In the example above started the mirror at 17:00 on Saturday, so the next ‘show’ (from) date is next friday (23rd) and the next hide (to) date is tonight.
                          Hope this helps
                          MitchfarinoM 1 Reply Last reply Reply Quote 0
                            Mitchfarino Module Developer @ianperrin
                            @ianperrin
                            Sorry for the odd question, will this work on a windows PC?
                            I’m testing the mirror on the PC before I deploy to my Pi, and this module doesn’t seem to be working
                            • I Offline
                              ianperrin @Mitchfarino
                              @Mitchfarino I’ve not tested the module on windows myself, so I can’t say for sure.
                              The module requires the cron package so make sure this has been installed by running npm install from the module folder.
                              You could then check whether cron works on windows by entering the following from the command prompt
                              cd MagicMirror/modules/MMM-ModuleScheduler
                              node
                              Once the node prompt appears, enter the following
                              var CronJob = require('cron').CronJob;
                              var testJob = new CronJob({cronTime: '* * * * * *', onTick: function() { console.log('Firing every second'); }, onComplete: function() { console.log('Stopping'); }, start: true});
                              console.log('Scheduled for ' + testJob.nextDate().toDate());
                              You should see a telling you when the module is next scheduled for and another message every second the expression is fired (pressCTRL-C twice to stop!)
                              If we’ve got this far cron is working successfully. What do the logs ( pm2 logs mm ) say? Could you post your config options?
