    Can’t find a calendar that works
    calendar
    14 Posts 4 Posters 6.1k Views 4 Watching
      mdhenriksen @scoller
      @scoller You are not using the right URL then. Could you post your config here so we can see?
        scoller @mdhenriksen
        @mdhenriksen sure
          scoller
          here is the code for the calendar:
          symbol: “calendar-check”,
          url: “https://calendar.google.com/calen”
            scoller
              scoller @scoller
              @scoller i edited the url so it don’t work because I don’t want everyone in my google acount. Hope you still can help me @mdhenriksen
              • lavolp3L Offline
                lavolp3 Module Developer @scoller
                @scoller It would have been better to delete the middle part.
                The tyoe of ending is important. Does the url end in a basic.ics?
                Also can you please go into the console type in
                pm2 logs
                and give us the output that is referring to the calendar module?
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  scoller @lavolp3
                  @lavolp3 the url did not end with .ical it ended with calendar.m
                  • lavolp3L Offline
                    @scoller I think only .ics calendars work but not sure.
                    You can also use an ics calendar from google and try that.
                    • Go into your google calendar webpage.
                    • Click on the three dots on one of the calendars in the left bar (the one with your name preferably) and then click on options.
                    • Scroll down and find your “private address in ical format”.
                    Use that address in your config.
                      MadScientist
                      I was just about to post the exact same as @lavolp3. That should work for sure.
                        scoller @lavolp3
                        @lavolp3 ok what am i looking for?
