    Can’t find a calendar that works
    calendar
    14 Posts 4 Posters 6.9k Views 4 Watching
      scoller @MadScientist
      @madscientist My url is taking me to the sign in page/log in page even though im logged in when I copy the url
      M 1 Reply Last reply
        mdhenriksen @scoller
        @scoller You are not using the right URL then. Could you post your config here so we can see?
          scoller @mdhenriksen
          @mdhenriksen sure
            scoller
            here is the code for the calendar:
            symbol: “calendar-check”,
            url: “https://calendar.google.com/calen”
              scoller
                scoller @scoller
                @scoller i edited the url so it don’t work because I don’t want everyone in my google acount. Hope you still can help me @mdhenriksen
                lavolp3L 1 Reply Last reply
                • lavolp3L
                  lavolp3 Module Developer @scoller
                  @scoller It would have been better to delete the middle part.
                  The tyoe of ending is important. Does the url end in a basic.ics?
                  Also can you please go into the console type in
                  pm2 logs
                  and give us the output that is referring to the calendar module?
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  S 2 Replies Last reply
                    scoller @lavolp3
                    @lavolp3 the url did not end with .ical it ended with calendar.m
                    • lavolp3L
                      @scoller I think only .ics calendars work but not sure.
                      You can also use an ics calendar from google and try that.
                      • Go into your google calendar webpage.
                      • Click on the three dots on one of the calendars in the left bar (the one with your name preferably) and then click on options.
                      • Scroll down and find your “private address in ical format”.
                      Use that address in your config.
                        MadScientist
                        I was just about to post the exact same as @lavolp3. That should work for sure.
                          scoller @lavolp3
                          @lavolp3 ok what am i looking for?
