    [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)
    81 Posts 13 Posters 81.1k Views 16 Watching
      shbatm Module Developer @richland007
      @richland007 said in [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io):
      What do you think?? i do not see any errors
      I’m at a loss. I ran the install on a fresh install of MagicMirror (v2.7.0-dev) on the latest version of Raspbian with Desktop (Nov’18) and I got the output shown in this Gist: https://gist.github.com/shbatm/886fc811d314d136ccedeaf5663e5881. Notice the FauxMo service started. Listening on 192.168.10.92:21900 on the third to last line.
      When I copy and paste your config section into my config it works fine. I run Discover Devices on Alexa and she finds “Horoscope Module” as a Wemo Switch.
      What version of MagicMirror, node, and Raspbian are you using? Is it the most recent?
      Try running FauxMo by itself and see if you can find the “fake” devices it creates:
      cd ~/MagicMirror/modules/MMM-AlexaOnOff/node_modules/fauxmojs/example
      node example.js
      You should see: started.. and then be able to discover ‘office light’ and ‘office fan’
      Edit: I did notice one thing: unless you’re using my fork of MMM-Remote-Control, the SHOW/HIDE functions require the module identifier, not the module name. The identifier will be something of the form module_4_MMM-horoscope and is the HTML ID of the module’s container (you can find this by using DevTools or digging into MMM-Remote-Control further.
      richland007R S 2 Replies Last reply
      • richland007R
        richland007 @shbatm
        @shbatm When i try to run the FauxMo example i see that it says: started …
        but there is no service running on port 21900 when i do “netstat -tulpn”
        I get a bunch of services running but none on that port.
        And when i try to discover devices, Alexa comes up saying that no new ones were found agian… so no Office Lamp and no Office Fan
        I am running Magic Mirror M 2.4.1
        Node version is: v6.13.0
        Rasbian Stretch 9.6 release (it is updated and upgraded as of today but i do not know if it is the lates release since i have been playing with it for a while)
        one more time with some more explanation on the MMM-Remote-Control names please… i did not quite get it where would i find the names again and are they numbered by MMM-Remote-Control according to their place that they have on my congfig.js list ??
        thank you for your help
        Denis
          The example runs on different ports (10000, 10001 I think) but I don’t know why Alexa wouldn’t find the devices. There must be something with your network or firewall causing an issue.
          The module may not be starting properly because it has a minimum MM version of 2.5.0. If you don’t want to upgrade, you can try changing line 21 in MMM-AlexaOnOff.js to match your version.
          About MMM-Remote-Control: see https://github.com/Jopyth/MMM-Remote-Control#list-of-actions for more details. The IDs are created by MM when it starts, and yes it should match the order in your config. The easiest way I’ve found to get these is to open the remote.html page on your computer, go to Edit View, and right-click > Inspect Element on one of the menu items. You’ll get something like this:
          I have a Pull Request for MMM-Remote-Control pending that will let you use the names directly, but it hasn’t been incorporated yet.
          richland007R 1 Reply Last reply
          • richland007R
            richland007 @shbatm
            @shbatm All right so i got it to work :) i have not fully tested yet with all my modules (i have 37 of them) but i did it with one and it works.
            So this is what i did:
            1. I ran the FauxMo example just like you said and it activates on ports 11000 and 11001
              I than went on alexa.amazon.com from my desktop and that is where i did the device discovery that found those sample devices… from my local echo it would not find anything.
            2. I went on the MMM-AlexaOnOff.js file and changed the minimum required version to 2.4.1 which is what i have (others if they happen to look into this forum thread should change it according to theirs)
            3. I activated my sample 1 module on/off on my config.js and Alexa did find it but it did not do anything until i changed the name of the module to “module_6_MMM-horoscope” again just like you said above and than it worked :)
            One last question: Through MMM-AlexaOnOff i want to create another on/off device called “Mirror” utilizing MMM-Remote-Control, that on On will send the command MONITORON and on Off with send the command MONITOROFF So will this work…I have no clue but just by dissecting your code???
                          on: {
                            notification: "REMOTE_ACTION",
                            payload: { action: "MONITORON"}
                          off: {
                            payload: { action: "MONITOROFF"}
            Do you think i will have any issues with 37 modules??
            I want to add them all on my config. js file before i run discovery on Alexa
            Thank you
            Denis
              I just found this setting up some smart plugs last week – is your echo on a different account in your “Amazon Household” by any chance?
              Yes, that should work. Here’s mine verbatim:
                          module: 'MMM-AlexaOnOff',
                              devices: [{
                                  on: {
                                      payload: { action: 'MONITORON' }
                                  off: {
                                      payload: { action: 'MONITOROFF' }
                              //{ add your other devices here },
              I haven’t stress tested it like that yet. You can certainly try it… From the FauxMo notes, you may have to run Discover a few times to find them all. Just make sure you don’t have anything running on the block of 37 ports.
              You can also try doing them in groups (you can send multiple notifications for each device’s on and off command, see earlier in this thread). Or use Profile Switcher or MMM-Carousel w/ Navigation (shbatm fork) to use “slides” of modules.
                djsunrise19
                Hi!
                Sounds like a perfect alexa module. Perhaps someone can help. Alexa can’t find my device. I followed the instructions - it’s not the first module I installed. I have to say, that I’m using ubuntu mate, because I have a mini-itx board with a Intel G4600, but that shouldn’t be the problem.
                I already deleted my devices and added them again - a few times. But there is no virtual Magic Mirror device.
                I corrected the netInterface variable to “enp3s0”, because I’m using LAN. In the newer ubuntu versions, there is no eth0.
                Here is my config:
                            module: 'MMM-OnScreenMenu',
                                netInterface: "enp3s0",
                                devices: [{
                                      on: {
                                        notification: "ONSCREENMENU_PROCESS_ACTION",
                                        payload: { actionName:'monitorOn' }
                                      off: {
                                        payload: { actionName:'monitorOff' }
                Ideas?
                Best regards
                Maurice
                  shbatm Module Developer @shbatm
                  @djsunrise19
                  Please check the same things:
                  1. Check your MagicMirror version, if it’s lower than v2.5.0 and you don’t want to upgrade, you can try changing line 21 in MMM-AlexaOnOff.js to match your version.
                  2. You should see FauxMo service started. Listening on 192.168.x.x:21900 in your log file if the service started.
                  3. You can try testing with the example:
                      node example.js
                  You should see: started.. and then be able to discover ‘office light’ and ‘office fan’ on your Alexa.
                  4. Make sure you try discovery from alexa.amazon.com, not just your Echo.
                  D 1 Reply Last reply
                    djsunrise19 @shbatm
                    @shbatm Thank you for responding!
                    1. I have the newest version 2.6
                    2. Yes, I can see that line while starting the mirror.
                    3. I also can see this in my command line with the example.
                    4. No devices found. With echo, Alexa app and web interface. Also no test “office light” or “office fan”.
                    Weird?! Perhaps the netInterface problem?! Or should it work with “enp3s0”?
                      shbatm Module Developer @djsunrise19
                      @djsunrise19 said in [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io):
                      As long as the line in the log is returning your computers’ correct IP Address, enp3s0 appears to be working…
                      Check netstat tulpn | grep 21900 and make sure the port is open. Otherwise check that your Alexa is on the same network/WiFi/account as you expect. If you’re getting the port open, then it’s something with the network or Alexa causing the problems.
                      • richland007R
                        richland007
                        @shbatm Ok so it works BUT it is only finding the last device on my list of the config.js file module entry when there are 36 others there. I tried discovery like 20 times from the website.
                        Should i try adding them one by one from the bottom up by commenting them out and adding them one by one …unless you got any other ideas :)
                        D
                          @richland007 in the log is it showing all of the ports in the range open? (e.g. 21900-21936)?
                          • richland007R
                            richland007 @shbatm
                            @shbatm Where do i see the logs??
                            When i use
                            netstat -tulpn | grep electron
                            It only show that 1 one port 0.0.0.0:21900 Listen
                            D
                              djsunrise19 @shbatm
                              @shbatm said in [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io):
                              Yes, IP-Adress is correct. From console everything looks like it should. Alexa is in the same network - wlan, mirror lan. I also have hue in here and the hue module on my mirror. Everything looks fine there. But actually, Alexa finds nothing.
                              Ich checked your command. After that, with sudo netstat -tulpnI see this:
                              Do I need the wemo skill or something like that?
                                wemo skill
                                You shouldn’t need a separate skill with it. It looks like everything is working from the mirror side so I’m not sure what else to try…
                                  It would be in pm2 logs mm or ~/.pm2/logs folder. I’ll check when I get a chance why it’s not opening more than 1 port.
                                  • richland007R
                                    richland007 @shbatm
                                    @shbatm I don not see anything out of the ordinary in my logs when i do pm2 logs mm definitely not 36 ports open in addition to 29100 when i go to location ~/.pm2/logs the log files are there in the directory but empty.
                                      So I was looking at the Fauxmojs project–what this module uses to handle the “devices”–and it looks like there are some issues with Gen 2 Echos not discovering the devices–but for most, the alexa.amazon.com website was working. I’ll keep an eye on that project–but at the moment, I don’t have anything else I can do from my end.
                                      If you want to see some more detailed logs–start the MM manually with the following:
                                      export DEBUG=sstp-server,deviceEndpoints,discoveryService
                                      npm start
                                      @richland007 - I just tested my installation with 3 devices and, while it wasn’t showing all of the ports on the log line due to a bug, it was opening the ports (visible with netstat -tulpn | grep electron – see below). Just in case anyone is wondering–port 1900 is the discovery port.
                                      tcp        0      0 0.0.0.0:21900           0.0.0.0:*               LISTEN      15738/electron.js
                                      tcp        0      0 0.0.0.0:21901           0.0.0.0:*               LISTEN      15738/electron.js
                                      tcp        0      0 0.0.0.0:21902           0.0.0.0:*               LISTEN      15738/electron.js
                                      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      15738/electron.js
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           15738/electron.js
                                      richland007R D 2 Replies Last reply
                                      • richland007R
                                        richland007 @shbatm
                                        @shbatm How do i read more log lines not only tailing the last 15 from pm2 logs mm ??
                                        This works so nicely with the only one device that it is starting (turn on and turn off the whole mirror) it is awesome… i am so hurt that i am unable to have the rest of the “devices/modules” working.
                                        If you want to have a look at my long a%$ :) config.js entry for the MMM-AlexaOnOff module here it is ;
                                                //netInterface: 'wlan0',
                                                //startPort: 15000,
                                                devices: [{
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_4_clock" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "modules_4_clock" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_5_calendar" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_5_calendar" }
        name: "Denis Calendar",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_6_calendar" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_6_calendar" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_7_compliments" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_7_compliments" }
                                        			  name: "Gas Prices Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_8_MMM-Gas" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_8_MMM-Gas" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_9_MMM-Instagram" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_9_MMM-Instagram" }
                                        			  name: "Page Indicator Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_11_MMM-page-indicator" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_11_MMM-page-indicator" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_12_MMM-DHT-Sensor" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_12_MMM-DHT-Sensor" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_13_MMM-NOAA3" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_13_MMM-NOAA3" }
                                        			  name: "System Stats Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_14_MMM-SystemStats" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_14_MMM-SystemStats" }
                                        			  name: "Movie Listings Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_15_MMM-MovieListings" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_15_MMM-MovieListings" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_16_MMM-Ecobee" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_16_MMM-Ecobee" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_17_MMM-AlexaPi" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_17_MMM-AlexaPi" }
                                        			  name: "Exchange Rate Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_20_MMM-LICE" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_20_MMM-LICE" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_21_stocks" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_21_stocks" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_22_MMM-GoogleMapsTraffic" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_22_MMM-GoogleMapsTraffic" }
                                        			  name: "My Commute Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_23_MMM-MyCommute" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_23_MMM-MyCommute" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_24_MMM-iFrame" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_24_MMM-iFrame" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_25_MMM-RSS-FEED" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_25_MMM-RSS-FEED" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_26_MMM-fitbit" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_26_MMM-fitbit" }
                                        			  name: "Google Fit Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_27_MMM-GoogleFit" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_27_MMM-GoogleFit" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_28_MMM-horoscope" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_28_MMM-horoscope" }
                                        			  name: "Phone Notification Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_29_phone_notification" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_29_phone_notification" }
                                        			  name: "TV Stream Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_30_MMM-RTSPStream" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_30_MMM-RTSPStream" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_31_iFrame" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_31_iFrame" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_32_MMM-NowPlayingOnSpotify" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_32_MMM-NowPlayingOnSpotify" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_33_MMM-Events" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_33_MMM-Events" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_34_MMM-NASA" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_34_MMM-NASA" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_35_MMM-SimpleLogo" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_35_MMM-SimpleLogo" }
                                        			  name: "Random Quotes Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_36_random_quotes" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_36_random_quotes" }
                                        			  name: "Bible Verse Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_37_MMM-DailyBibleVerse" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_37_MMM-DailyBibleVerse" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_39_MMM-DropboxWallpaper" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_39_MMM-DropboxWallpaper" }
                                        			  name: "Weather Background Module",
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_40_MMM-Dummy" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_40_MMM-Dummy" }
                                                      on: {
                                                        payload: { action: "SHOW", module: "module_43_MMM-Jnews" }
                                                      off: {
                                                        payload: { action: "HIDE", module: "module_43_MMM-Jnews" }
                                        	      name: "Eva's Modules",
                                                      on: [
                                                      off: [
                                        	      name: "Denis Modules",
                                                      on: [
                                                      off: [
                                                        payload: { action: "Show", module: "module_9_MMM-Instagram" }
                                                      on: {
                                                      off: {
                                        It is only loading the last “device” named Mirror for (an all on/off feature) on port 21900.
                                        I tried changing the port start number to something else to no avail, i tried commenting out all but the last 2 of the devices still no luck…it only starts 1.
                                        Edit: I spoke too early on singing it praises if you give a command ( in my case all i have is one that makes the monitor go off and than on after you ask Alexa to turn Mirror On) after 2-3 minutes everything freezes and you absolutely can not interact with the mirror completely neither from putty /ssh or vnc (ctrl/alt/del) or keyboard input only a hard power reset is the solution it has happened twice. I did try it one last time before posting this, and right after “Alexa turn Mirror On” i hit ctrl+Q to quit MM and see what the CPU values were and they were right around 70% but they went immediately down to 1% and nothing happened no more freezing of the Rpi…weird!!! I really need to get you some more detailed logs
                                        Please help me solve this so i can turn my modules on and off
                                        Thank you for your prompt replies and patience
                                        Denis
                                          djsunrise19 @shbatm
                                          @shbatm Thanks. I’m using an echo dot 3rd generation. Sadly, I have to wait. There seems to be no problems with your module / the mirror / network.
                                          Good work!
                                            They should be in ~/.pm2/logs by default. You can also stop the pm2 version and run the mirror manually using the instructions above.
                                            I’ll let you know if I can replecate the CPU issue, but that’s very strange. I haven’t seen that.
                                            Make sure you update to the latest version of the module to see the correct line, but other than that I don’t know why its not working for more than one device. At this point it sounds like a fauxmojs issue… You can always open an issue on their GitHub repo.
                                            • 2 / 5
