ipwhitelist - a lot of issues... can't connect remotely ..
Some days now, i try to get my MM running on a Raspberry (Zero, B3A+) but without Access
two main issues occurs…
i can’t access remotly …
whatever i tried in “config.js”
this is what i tried
var config = {
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipwhitelist: [],
//ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.2.54”],
//ipWhitelist: [“::ffff:192.168.2.1/120”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],for Explanation my Home LAN is addressed with 192.168.2.x…
i have installed it with PM2
if i start it locally with
startx (cause “chromium-browser -Kiosk http://localhost:8080” gives an GTK-Error) and after that
DISPLAY=:0 chromium-browser -Kiosk http://localhost:8080" it starts but give me an Warn Message that Address “localhost” is already in use …any Ideas…
The last entrys for “ipwhitelist” i found were form one year ago…
basicliy i want to start it jast locally on my Pi …
@big11 said in ipwhitelist - a lot of issues... can't connect remotely ..:
Try change address: “localhost” to “0.0.0.0”
And please use the Markdown features of the board when pasting code or logs.
got it … thank you…
but the ipwhitelist Parameter are not very handsome
so i did a
ipwhitelist: [],and that works…
further i will look for the correct Syntax to grant Access for Special addresses outside my LAN…
