    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 209.1k Views 22 Watching
      paviro
      Seems like there is no today list available via the API.
      – The Doctor
        jagerpower
        is it possible to get this module to work with magic mirror v2? if so how can i get the api?
          paviro @jagerpower
          @jagerpower this module is for MM v2.0? :confused:
          – The Doctor
            CGabo
            Hi @jagerpower
            It’s definitely working. I just followed paviro’s instructions.
            Here is my config:
                    module: 'MMM-Wunderlist',
                            position: 'top_left',
                            header: 'Wunderlist',
                                    accessToken: '*******************',
                                    clientID: '************',
                                    lists: [
                                             'inbox',
                                             'Einkaufsliste'
                                    interval: 60,
                                    fade: true
            @paviro, thanks
            P J 2 Replies Last reply Reply Quote 0
              paviro @CGabo
              @CGabo glad you find it useful :)
              – The Doctor
                jagerpower @CGabo
                @CGabo Thank you, i just installed it to my MM.
                  jagerpower
                  @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
                  here is my config:
                                         position: 'top_left',  // This can be any of the regions. Best results in left$
                                         header: 'Wunderlist', // This is optional
                                         accesToken: '----',
                                         clientID: '----',
                                         lists: ["inbox"],
                                         interval: 60,
                                         fade: true
                  Note from admin: Please use Markdown on code snippets so it is easier to read!
                    paviro @jagerpower
                    @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
                    – The Doctor
                      jagerpower @paviro
                      @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
                        CGabo
                        @jagerpower
                        Interval: 60 is for refresh all 60 min. You can also restart mm.
                        If it’s still nothing, try the curl command which paviro provided 3 days ago.
                          paviro @jagerpower
                          @jagerpower alt cmd I
                          – The Doctor
                            jagerpower @CGabo
                            @CGabo @paviro when i run the curl command everythings seems right execpt for "public":false is this normal?
                              paviro @jagerpower
                              @jagerpower yes. Have you changed the interval?
                              – The Doctor
                                jagerpower @paviro
                                @paviro yes i changed the interval to 1 but it didn’t help
                                  paviro @jagerpower
                                  @jagerpower checked the Web inspector?
                                  – The Doctor
                                    jagerpower
                                    @paviro no i didn’t do that yet but where do i use cmd alt i? in the terminal? and i use a windows keyboard, does this matter?
                                      CGabo
                                      @jagerpower
                                      https://developers.google.com/web/tools/chrome-devtools/iterate/inspect-styles/shortcuts?hl=en
                                        jagerpower @CGabo
                                        @CGabo @paviro alt text
                                          paviro @jagerpower
                                          @jagerpower check the log not the element should be another tab.
                                          – The Doctor
                                            CGabo
                                            @jagerpower You find it under “Console”
                                            Btw. changing the interval to 1, I wouldn’t recommend. It pulls the data every 1 sec, leave it to 60 (default) . I personally increased it to 3600 (1h).
                                            • 2 / 6
