    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
      jagerpower @CGabo
      @CGabo Thank you, i just installed it to my MM.
        jagerpower
        @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
        here is my config:
        module: 'MMM-Wunderlist',
                               position: 'top_left',  // This can be any of the regions. Best results in left$
                               header: 'Wunderlist', // This is optional
                               accesToken: '----',
                               clientID: '----',
                               lists: ["inbox"],
                               interval: 60,
                               fade: true
        Note from admin: Please use Markdown on code snippets so it is easier to read!
        paviroP 1 Reply Last reply
        • paviroP
          paviro @jagerpower
          @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
          – The Doctor
          J 1 Reply Last reply
            jagerpower @paviro
            @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
              CGabo
              @jagerpower
              Interval: 60 is for refresh all 60 min. You can also restart mm.
              If it’s still nothing, try the curl command which paviro provided 3 days ago.
              • paviroP
                paviro @jagerpower
                @jagerpower alt cmd I
                – The Doctor
                  jagerpower @CGabo
                  @CGabo @paviro when i run the curl command everythings seems right execpt for "public":false is this normal?
                  • paviroP
                    paviro @jagerpower
                    @jagerpower yes. Have you changed the interval?
                    – The Doctor
                      jagerpower @paviro
                      @paviro yes i changed the interval to 1 but it didn’t help
                      • paviroP
                        paviro @jagerpower
                        @jagerpower checked the Web inspector?
                        – The Doctor
                          jagerpower
                          @paviro no i didn’t do that yet but where do i use cmd alt i? in the terminal? and i use a windows keyboard, does this matter?
                            CGabo
                            @jagerpower
                            https://developers.google.com/web/tools/chrome-devtools/iterate/inspect-styles/shortcuts?hl=en
                              jagerpower @CGabo
                              @CGabo @paviro alt text
                              • paviroP
                                paviro @jagerpower
                                @jagerpower check the log not the element should be another tab.
                                – The Doctor
                                  CGabo
                                  @jagerpower You find it under “Console”
                                  Btw. changing the interval to 1, I wouldn’t recommend. It pulls the data every 1 sec, leave it to 60 (default) . I personally increased it to 3600 (1h).
                                    jagerpower
                                    • paviroP
                                      paviro @jagerpower
                                      @jagerpower are there any log after that from the module?
                                      – The Doctor
                                        jagerpower @paviro
                                        @paviro alt text
                                        • paviroP
                                          paviro @jagerpower
                                          @jagerpower toggle the array that’s logged by the module anything in there?
                                          – The Doctor
                                            jagerpower @paviro
                                            @paviro alt text
                                            • 2 / 6
