    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
      jagerpower @paviro
      @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
      paviroP 1 Reply Last reply
        CGabo
        @jagerpower
        Interval: 60 is for refresh all 60 min. You can also restart mm.
        If it’s still nothing, try the curl command which paviro provided 3 days ago.
        J 1 Reply Last reply
        • paviroP
          paviro @jagerpower
          @jagerpower alt cmd I
          – The Doctor
            jagerpower @CGabo
            @CGabo @paviro when i run the curl command everythings seems right execpt for "public":false is this normal?
            • paviroP
              paviro @jagerpower
              @jagerpower yes. Have you changed the interval?
              – The Doctor
                jagerpower @paviro
                @paviro yes i changed the interval to 1 but it didn’t help
                • paviroP
                  paviro @jagerpower
                  @jagerpower checked the Web inspector?
                  – The Doctor
                    jagerpower
                    @paviro no i didn’t do that yet but where do i use cmd alt i? in the terminal? and i use a windows keyboard, does this matter?
                      CGabo
                      @jagerpower
                      https://developers.google.com/web/tools/chrome-devtools/iterate/inspect-styles/shortcuts?hl=en
                        jagerpower @CGabo
                        @CGabo @paviro alt text
                        • paviroP
                          paviro @jagerpower
                          @jagerpower check the log not the element should be another tab.
                          – The Doctor
                            CGabo
                            @jagerpower You find it under “Console”
                            Btw. changing the interval to 1, I wouldn’t recommend. It pulls the data every 1 sec, leave it to 60 (default) . I personally increased it to 3600 (1h).
                              jagerpower
                              • paviroP
                                paviro @jagerpower
                                @jagerpower are there any log after that from the module?
                                – The Doctor
                                  jagerpower @paviro
                                  @paviro alt text
                                  • paviroP
                                    paviro @jagerpower
                                    @jagerpower toggle the array that’s logged by the module anything in there?
                                    – The Doctor
                                      jagerpower @paviro
                                      @paviro alt text
                                      • paviroP
                                        paviro @jagerpower
                                        @jagerpower also toggle the array in the array until there is nothing else to toggle…
                                        – The Doctor
                                          jagerpower @paviro
                                          @paviro do i need to toggle these too?
                                          alt text
                                          • paviroP
                                            paviro @jagerpower
                                            @jagerpower sorry forgot about those… Will add a Screenshot to this post when I am home.
                                            – The Doctor
                                            • 2 / 6
