    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 209.1k Views 22 Watching
      paviro
      Could you guys try to execute curl -H "X-Access-Token: OAUTH-TOKEN" -H "X-Client-ID: CLIENT-ID" https://a.wunderlist.com/api/v1/lists in a terminal?
      – The Doctor
      • Z Offline
        zombi27 @chrismoore
        Is the name of the list case sensitive? “today” / “Today”?
          chrismoore @zombi27
          @zombi27 I tried that earlier in the process and nothing appeared. I’m going to rip everything apart and try to figure out where the issue is.
            paviro
            Seems like there is no today list available via the API.
            – The Doctor
              jagerpower
              is it possible to get this module to work with magic mirror v2? if so how can i get the api?
                paviro @jagerpower
                @jagerpower this module is for MM v2.0? :confused:
                – The Doctor
                  CGabo
                  Hi @jagerpower
                  It’s definitely working. I just followed paviro’s instructions.
                  Here is my config:
                          module: 'MMM-Wunderlist',
                                  position: 'top_left',
                                  header: 'Wunderlist',
                                          accessToken: '*******************',
                                          clientID: '************',
                                          lists: [
                                                   'inbox',
                                                   'Einkaufsliste'
                                          interval: 60,
                                          fade: true
                  @paviro, thanks
                  P J 2 Replies Last reply Reply Quote 0
                    paviro @CGabo
                    @CGabo glad you find it useful :)
                    – The Doctor
                      jagerpower @CGabo
                      @CGabo Thank you, i just installed it to my MM.
                        jagerpower
                        @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
                        here is my config:
                                               position: 'top_left',  // This can be any of the regions. Best results in left$
                                               header: 'Wunderlist', // This is optional
                                               accesToken: '----',
                                               clientID: '----',
                                               lists: ["inbox"],
                                               interval: 60,
                                               fade: true
                        Note from admin: Please use Markdown on code snippets so it is easier to read!
                          paviro @jagerpower
                          @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
                          – The Doctor
                            jagerpower @paviro
                            @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
                              CGabo
                              @jagerpower
                              Interval: 60 is for refresh all 60 min. You can also restart mm.
                              If it’s still nothing, try the curl command which paviro provided 3 days ago.
                                paviro @jagerpower
                                @jagerpower alt cmd I
                                – The Doctor
                                  jagerpower @CGabo
                                  @CGabo @paviro when i run the curl command everythings seems right execpt for "public":false is this normal?
                                    paviro @jagerpower
                                    @jagerpower yes. Have you changed the interval?
                                    – The Doctor
                                      jagerpower @paviro
                                      @paviro yes i changed the interval to 1 but it didn’t help
                                        paviro @jagerpower
                                        @jagerpower checked the Web inspector?
                                        – The Doctor
                                          jagerpower
                                          @paviro no i didn’t do that yet but where do i use cmd alt i? in the terminal? and i use a windows keyboard, does this matter?
                                            CGabo
                                            @jagerpower
                                            https://developers.google.com/web/tools/chrome-devtools/iterate/inspect-styles/shortcuts?hl=en
                                            • 2 / 6
