    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
    • paviroP
      paviro @chrismoore
      @chrismoore can you send me a Screenshot from the Wunderlist app showing the name of the list you try to embed?
      – The Doctor
        chrismoore
        Here you go.
        paviroP zombi27Z 2 Replies Last reply
        • MichMichM
          MichMich @paviro
          @paviro any plans for adding iCal reminders?
          paviroP 1 Reply Last reply
          • paviroP
            paviro @chrismoore
            @chrismoore ah! No idea how that list is called in the API :/ you’d have to check the API docs for that :)
            – The Doctor
            C 1 Reply Last reply
            • paviroP
              paviro @MichMich
              @MichMich iCal reminders? Like the Apple reminders? Are they synced via iCal?
              – The Doctor
              MitchfarinoM 1 Reply Last reply
                chrismoore @paviro
                @paviro As a test I also tried “inbox” which has a test to-do on Wunderlist but that also doesn’t show up.
                • MitchfarinoM
                  Mitchfarino Module Developer @paviro
                  @paviro @MichMich
                  Just to add my comment to this, I am making using of an IFTTT recipe to link my gmail calendar to Wunderlist.
                  It creates the relevant to do item with a due date, so I’m only showing this items on my mirror.
                  • MitchfarinoM
                    Mitchfarino Module Developer @Mitchfarino
                    @paviro Although when I use ‘week’ as the list, it seems to have stopped working :cold_sweat:
                    • paviroP
                      paviro
                      Could you guys try to execute curl -H "X-Access-Token: OAUTH-TOKEN" -H "X-Client-ID: CLIENT-ID" https://a.wunderlist.com/api/v1/lists in a terminal?
                      – The Doctor
                      • zombi27Z
                        zombi27 @chrismoore
                        Is the name of the list case sensitive? “today” / “Today”?
                          chrismoore @zombi27
                          @zombi27 I tried that earlier in the process and nothing appeared. I’m going to rip everything apart and try to figure out where the issue is.
                          • paviroP
                            paviro
                            Seems like there is no today list available via the API.
                            – The Doctor
                              jagerpower
                              is it possible to get this module to work with magic mirror v2? if so how can i get the api?
                              • paviroP
                                paviro @jagerpower
                                @jagerpower this module is for MM v2.0? :confused:
                                – The Doctor
                                  CGabo
                                  Hi @jagerpower
                                  It’s definitely working. I just followed paviro’s instructions.
                                  Here is my config:
                                          module: 'MMM-Wunderlist',
                                                  position: 'top_left',
                                                  header: 'Wunderlist',
                                                          accessToken: '*******************',
                                                          clientID: '************',
                                                          lists: [
        'inbox',
        'Einkaufsliste'
                                                          interval: 60,
                                                          fade: true
                                  @paviro, thanks
                                  paviroP J 2 Replies Last reply
                                  • paviroP
                                    paviro @CGabo
                                    @CGabo glad you find it useful :)
                                    – The Doctor
                                    foxF 1 Reply Last reply
                                      jagerpower @CGabo
                                      @CGabo Thank you, i just installed it to my MM.
                                        jagerpower
                                        @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
                                        here is my config:
                                                               position: 'top_left',  // This can be any of the regions. Best results in left$
                                                               header: 'Wunderlist', // This is optional
                                                               accesToken: '----',
                                                               clientID: '----',
                                                               lists: ["inbox"],
                                                               interval: 60,
                                                               fade: true
                                        Note from admin: Please use Markdown on code snippets so it is easier to read!
                                        • paviroP
                                          paviro @jagerpower
                                          @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
                                          – The Doctor
                                          J 1 Reply Last reply
                                            jagerpower @paviro
                                            @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
                                            • 1 / 6
