    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 205.8k Views 22 Watching
      chrismoore
      This module is perfect since we’re using Wunderlist already but I’m having a difficult time getting it to display. It installed properly, I’ve included my clientID and accessToken in config.js, it loads the header but the actual widget is blank and it’s not throwing any errors.
      Any help is appreciated.
      Chris
        paviro @chrismoore
        @chrismoore Can you show me your lists: [] entry in your config?
        – The Doctor
          chrismoore
          Sure, it’s just: lists: ["today"] which is currently populated and active on Wunderlist. The app url on Wunderlist is http://localhost:8080
            paviro
            The list is exactly written like this?
            – The Doctor
              chrismoore
                      module: 'MMM-Wunderlist',
                      position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                      header: 'To-Do List', // This is optional
                          accessToken: '***',
              			clientID: '***',
              			lists: ["today"]
                paviro @chrismoore
                @chrismoore can you send me a Screenshot from the Wunderlist app showing the name of the list you try to embed?
                – The Doctor
                  chrismoore
                  Here you go.
                  P Z 2 Replies Last reply Reply Quote 0
                  • MichMichM Offline
                    MichMich @paviro
                    @paviro any plans for adding iCal reminders?
                      paviro @chrismoore
                      @chrismoore ah! No idea how that list is called in the API :/ you’d have to check the API docs for that :)
                      – The Doctor
                        paviro @MichMich
                        @MichMich iCal reminders? Like the Apple reminders? Are they synced via iCal?
                        – The Doctor
                          chrismoore @paviro
                          @paviro As a test I also tried “inbox” which has a test to-do on Wunderlist but that also doesn’t show up.
                            Mitchfarino Module Developer @paviro
                            @paviro @MichMich
                            Just to add my comment to this, I am making using of an IFTTT recipe to link my gmail calendar to Wunderlist.
                            It creates the relevant to do item with a due date, so I’m only showing this items on my mirror.
                              Mitchfarino Module Developer @Mitchfarino
                              @paviro Although when I use ‘week’ as the list, it seems to have stopped working :cold_sweat:
                                paviro
                                Could you guys try to execute curl -H "X-Access-Token: OAUTH-TOKEN" -H "X-Client-ID: CLIENT-ID" https://a.wunderlist.com/api/v1/lists in a terminal?
                                – The Doctor
                                • Z Offline
                                  zombi27 @chrismoore
                                  Is the name of the list case sensitive? “today” / “Today”?
                                    chrismoore @zombi27
                                    @zombi27 I tried that earlier in the process and nothing appeared. I’m going to rip everything apart and try to figure out where the issue is.
                                      paviro
                                      Seems like there is no today list available via the API.
                                      – The Doctor
                                        jagerpower
                                        is it possible to get this module to work with magic mirror v2? if so how can i get the api?
                                          paviro @jagerpower
                                          @jagerpower this module is for MM v2.0? :confused:
                                          – The Doctor
                                            CGabo
                                            Hi @jagerpower
                                            It’s definitely working. I just followed paviro’s instructions.
                                            Here is my config:
                                                            position: 'top_left',
                                                            header: 'Wunderlist',
        accessToken: '*******************',
        clientID: '************',
        lists: [
        'inbox',
        'Einkaufsliste'
        interval: 60,
        fade: true
                                            @paviro, thanks
                                            P J 2 Replies Last reply Reply Quote 0
                                            • 1 / 6
