    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 212.3k Views 22 Watching
      chrismoore
      Here you go.
      P Z 2 Replies Last reply Reply Quote 0
      • MichMichM
        MichMich @paviro
        @paviro any plans for adding iCal reminders?
          paviro @chrismoore
          @chrismoore ah! No idea how that list is called in the API :/ you’d have to check the API docs for that :)
          – The Doctor
            paviro @MichMich
            @MichMich iCal reminders? Like the Apple reminders? Are they synced via iCal?
            – The Doctor
              chrismoore @paviro
              @paviro As a test I also tried “inbox” which has a test to-do on Wunderlist but that also doesn’t show up.
                Mitchfarino Module Developer @paviro
                @paviro @MichMich
                Just to add my comment to this, I am making using of an IFTTT recipe to link my gmail calendar to Wunderlist.
                It creates the relevant to do item with a due date, so I’m only showing this items on my mirror.
                  Mitchfarino Module Developer @Mitchfarino
                  @paviro Although when I use ‘week’ as the list, it seems to have stopped working :cold_sweat:
                    paviro
                    Could you guys try to execute curl -H "X-Access-Token: OAUTH-TOKEN" -H "X-Client-ID: CLIENT-ID" https://a.wunderlist.com/api/v1/lists in a terminal?
                    – The Doctor
                    • Z
                      zombi27 @chrismoore
                      Is the name of the list case sensitive? “today” / “Today”?
                        chrismoore @zombi27
                        @zombi27 I tried that earlier in the process and nothing appeared. I’m going to rip everything apart and try to figure out where the issue is.
                          paviro
                          Seems like there is no today list available via the API.
                          – The Doctor
                            jagerpower
                            is it possible to get this module to work with magic mirror v2? if so how can i get the api?
                              paviro @jagerpower
                              @jagerpower this module is for MM v2.0? :confused:
                              – The Doctor
                                CGabo
                                Hi @jagerpower
                                It’s definitely working. I just followed paviro’s instructions.
                                Here is my config:
                                        module: 'MMM-Wunderlist',
                                                position: 'top_left',
                                                header: 'Wunderlist',
                                                        accessToken: '*******************',
                                                        clientID: '************',
                                                        lists: [
        'inbox',
        'Einkaufsliste'
                                                        interval: 60,
                                                        fade: true
                                @paviro, thanks
                                P J 2 Replies Last reply Reply Quote 0
                                  paviro @CGabo
                                  @CGabo glad you find it useful :)
                                  – The Doctor
                                    jagerpower @CGabo
                                    @CGabo Thank you, i just installed it to my MM.
                                      jagerpower
                                      @CGabo @paviro I can see the wunderlist Module in my mirror but when i add a to-do it doesn’t show up in the mirror.
                                      here is my config:
                                                             position: 'top_left',  // This can be any of the regions. Best results in left$
                                                             header: 'Wunderlist', // This is optional
                                                             accesToken: '----',
                                                             clientID: '----',
                                                             lists: ["inbox"],
                                                             interval: 60,
                                                             fade: true
                                      Note from admin: Please use Markdown on code snippets so it is easier to read!
                                        paviro @jagerpower
                                        @jagerpower have you checked your web inspector and really added your todo to the inbox list and not another one?
                                        – The Doctor
                                          jagerpower @paviro
                                          @paviro yes i added the to-do’s to inbox and how and where can i check my web inspector?
                                            CGabo
                                            @jagerpower
                                            Interval: 60 is for refresh all 60 min. You can also restart mm.
                                            If it’s still nothing, try the curl command which paviro provided 3 days ago.
                                            • 1 / 6
