    MMM-Pollen and MMM-Quote of the day
    3 Posts 2 Posters 1.1k Views 2 Watching
    • T Offline
      twwilkerson1
      I am having issues with both of the above modules. When I add them to the config/config.js file, my MM gives the error message about no config file. if I delete those lines, it goes back to working correctly. I am certain I am the one making a mistake, but I cannot figure it out. I am not a programmer or coder–just dabbling with the Pi. I have even just copied the maker’s code without adjusting for my location, and it still fails. Please help if you can.
                             module: "MMM-Pollen",
                             header: "Pollen Forecast",
                                     updateInterval: 3 * 60 * 60 * 1000, // every 3 hours
                                     zip_code: "90210"
                          module: "MMM-quote-of-the-day",
                          position: "lower_third",
                              language: "en",
                              updateInterval: "1d"
      • T Offline
        twwilkerson1 @twwilkerson1
        @twwilkerson1 add this to my issue as well. Clearly I am bad at this. I get the same “no config file” error message when I tried to add the MMM-PIR-Sensor to my config/config.js file.
        //your code here
                                module: 'MMM-PIR-Sensor',
                                        sensorPin: 17,
                                        powerSaving: true // See 'Configuration options' for more information.
        Any advice is greatly appreciated.
          Mykle1 Project Sponsor Module Developer @twwilkerson1
          @twwilkerson1
          You’re missing a comma at the end of the “MMM-quote-of-the-day” entry and there is a comma out of place in the sensor entry. Everything else looks good. Try these please.
                  zip_code: "90210"
                  language: "en",
                  sensorPin: 17,
