after update and upgrade raspberry and magic mirror
13 Posts 3 Posters 3.7k Views 2 Watching
  • F Offline
    Fonfon
    Thanks to help me this is the message when i try to start with “npm start”
    (node:5115) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
    magicmirror@2.6.0 start /home/pi/.local/share/Trash/files/MagicMirror.2
    sh run-start.sh
    run-start.sh: 4: run-start.sh: electron: not found
    npm ERR! magicmirror@2.6.0 start: sh run-start.sh
    npm ERR! Exit status 127
    npm ERR!
    npm ERR! Failed at the magicmirror@2.6.0 start script.
    npm ERR! This is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR! sh run-start.sh
    npm ERR! You can get their info via:
    npm ERR! npm owner ls magicmirror
    npm ERR! System Linux 4.14.79-v7+
    npm ERR! command “/usr/bin/node” “/usr/bin/npm” “start”
    npm ERR! cwd /home/pi/.local/share/Trash/files/MagicMirror.2
    npm ERR! node -v v8.11.1
    npm ERR! npm -v 1.4.21
    npm ERR! code ELIFECYCLE
    npm WARN This failure might be due to the use of legacy binary “node”
    npm WARN For further explanations, please read
    /usr/share/doc/nodejs/README.Debian
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR! /home/pi/.local/share/Trash/files/MagicMirror.2/npm-debug.log
    npm ERR! not ok code 0
      can u show us the output of
      npm -v
      and
      node -v
      F 1 Reply Last reply Jan 20, 2019, 3:42 PM Reply Quote 0
      • F Offline
        Fonfon @sdetweil
        @sdetweil thanks
        pi@raspberrypi:~/MagicMirror $ npm -v
        1.4.21
        (node:5164) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        and
        pi@raspberrypi:~/MagicMirror $ node -v
        v8.11.1
        S 1 Reply Last reply Jan 20, 2019, 3:49 PM Reply Quote 0
          sdetweil @Fonfon
          @fonfon said in after update and upgrade raspberry and magic mirror:
          1.4.21
          that is very old… please upgrade,
          i have 2 systems, 1 is at 3.5.2 (still too old, thx will upgrade)
          and 6.1.0
          use
          curl -L https://npmjs.org/install.sh | sudo sh
          F 1 Reply Last reply Jan 20, 2019, 4:41 PM Reply Quote 0
          • F Offline
            Fonfon @sdetweil
            @sdetweil thanks your command works great for upgrade !
            but after i have the same problem
            pi@raspberrypi:~ $ npm -v
            6.6.0
            pi@raspberrypi:~ $ cd MagicMirror/
            magicmirror@2.6.0 start /home/pi/MagicMirror
            sh run-start.sh
            npm ERR! file sh
            npm ERR! errno ENOENT
            npm ERR! syscall spawn
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! /home/pi/.npm/_logs/2019-01-20T16_40_06_112Z-debug.log
            S 1 Reply Last reply Jan 20, 2019, 4:44 PM Reply Quote 0
              sdetweil @Fonfon
              @fonfon in the magic mirror folder
              npm -i electron
              F 1 Reply Last reply Jan 20, 2019, 4:48 PM Reply Quote 0
              • F Offline
                Fonfon @sdetweil
                @sdetweil command don’t work
                S 1 Reply Last reply Jan 20, 2019, 4:55 PM Reply Quote 0
                  sdetweil @Fonfon
                  @fonfon please add more info
                  F 1 Reply Last reply Jan 20, 2019, 5:01 PM Reply Quote 0
                  • F Offline
                    Fonfon @sdetweil
                    @sdetweil for sure sorry
                    pi@raspberrypi:~/MagicMirror $ npm -i electron
                    Usage: npm
                    where is one of:
                    access, adduser, audit, bin, bugs, c, cache, ci, cit,
                    clean-install, clean-install-test, completion, config,
                    create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
                    edit, explore, get, help, help-search, hook, i, init,
                    install, install-ci-test, install-test, it, link, list, ln,
                    login, logout, ls, org, outdated, owner, pack, ping, prefix,
                    profile, prune, publish, rb, rebuild, repo, restart, root,
                    run, run-script, s, se, search, set, shrinkwrap, star,
                    stars, start, stop, t, team, test, token, tst, un,
                    uninstall, unpublish, unstar, up, update, v, version, view,
                    whoami
                    npm -h quick help on
                    npm -l display full usage info
                    npm help search for help on
                    npm help npm involved overview
                    Specify configs in the ini-formatted file:
                    /home/pi/.npmrc
                    or on the command line via: npm --key value
                    Config info can be viewed via: npm help config
                    npm@6.6.0 /usr/lib/node_modules/npm
                    S 1 Reply Last reply Jan 20, 2019, 5:13 PM Reply Quote 0
                      sdetweil @Fonfon
                      @fonfon ok, my mistake
                      npm i electron
                      no dash (-)
                      F 1 Reply Last reply Jan 20, 2019, 5:22 PM Reply Quote 2
