    after update and upgrade raspberry and magic mirror
    13 Posts 3 Posters 5.2k Views 2 Watching
    • F Offline
      Fonfon
      Thanks to help me this is the message when i try to start with “npm start”
      (node:5115) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      magicmirror@2.6.0 start /home/pi/.local/share/Trash/files/MagicMirror.2
      sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! magicmirror@2.6.0 start: sh run-start.sh
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command “/usr/bin/node” “/usr/bin/npm” “start”
      npm ERR! cwd /home/pi/.local/share/Trash/files/MagicMirror.2
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      npm WARN This failure might be due to the use of legacy binary “node”
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR! /home/pi/.local/share/Trash/files/MagicMirror.2/npm-debug.log
      npm ERR! not ok code 0
        can u show us the output of
        npm -v
        and
        node -v
        • F Offline
          Fonfon @sdetweil
          @sdetweil thanks
          pi@raspberrypi:~/MagicMirror $ npm -v
          1.4.21
          (node:5164) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
          and
          pi@raspberrypi:~/MagicMirror $ node -v
          v8.11.1
            sdetweil @Fonfon
            @fonfon said in after update and upgrade raspberry and magic mirror:
            1.4.21
            that is very old… please upgrade,
            i have 2 systems, 1 is at 3.5.2 (still too old, thx will upgrade)
            and 6.1.0
            use
            curl -L https://npmjs.org/install.sh | sudo sh
            • F Offline
              Fonfon @sdetweil
              @sdetweil thanks your command works great for upgrade !
              but after i have the same problem
              pi@raspberrypi:~ $ npm -v
              6.6.0
              pi@raspberrypi:~ $ cd MagicMirror/
              magicmirror@2.6.0 start /home/pi/MagicMirror
              sh run-start.sh
              npm ERR! file sh
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! /home/pi/.npm/_logs/2019-01-20T16_40_06_112Z-debug.log
                sdetweil @Fonfon
                @fonfon in the magic mirror folder
                npm -i electron
                • F Offline
                  Fonfon @sdetweil
                  @sdetweil command don’t work
                    sdetweil @Fonfon
                    @fonfon please add more info
                    • F Offline
                      Fonfon @sdetweil
                      @sdetweil for sure sorry
                      pi@raspberrypi:~/MagicMirror $ npm -i electron
                      Usage: npm
                      where is one of:
                      access, adduser, audit, bin, bugs, c, cache, ci, cit,
                      clean-install, clean-install-test, completion, config,
                      create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
                      edit, explore, get, help, help-search, hook, i, init,
                      install, install-ci-test, install-test, it, link, list, ln,
                      login, logout, ls, org, outdated, owner, pack, ping, prefix,
                      profile, prune, publish, rb, rebuild, repo, restart, root,
                      run, run-script, s, se, search, set, shrinkwrap, star,
                      stars, start, stop, t, team, test, token, tst, un,
                      uninstall, unpublish, unstar, up, update, v, version, view,
                      whoami
                      npm -h quick help on
                      npm -l display full usage info
                      npm help search for help on
                      npm help npm involved overview
                      Specify configs in the ini-formatted file:
                      /home/pi/.npmrc
                      or on the command line via: npm --key value
                      Config info can be viewed via: npm help config
                      npm@6.6.0 /usr/lib/node_modules/npm
                        sdetweil @Fonfon
                        @fonfon ok, my mistake
                        npm i electron
                        no dash (-)
                        F 1 Reply Last reply Reply Quote 2
                        • F Offline
                          Fonfon @sdetweil
                          @sdetweil after that
                          i’ll make a
                          npm audit
                          npm audit fix
                          npm install
                          and now it’s work great
                          Thanks very much @sdetweil for your help !!!
                            great feedback , thank you
                            please mark your issue resolved…
                            • bheplerB Offline
                              bhepler Module Developer
                              In the future, please use the Markdown features of the board when posting code and logs.
