    after update and upgrade raspberry and magic mirror
    13 Posts 3 Posters 5.8k Views 2 Watching
      sdetweil @Fonfon
      @fonfon said in after update and upgrade raspberry and magic mirror:
      pi@raspberrypi:~/MagicMirror $ npm -v
      1.4.21
      that is very old… please upgrade,
      i have 2 systems, 1 is at 3.5.2 (still too old, thx will upgrade)
      and 6.1.0
      use
      curl -L https://npmjs.org/install.sh | sudo sh
      F 1 Reply Last reply
      • F
        Fonfon @sdetweil
        @sdetweil thanks your command works great for upgrade !
        but after i have the same problem
        pi@raspberrypi:~ $ npm -v
        6.6.0
        pi@raspberrypi:~ $ cd MagicMirror/
        magicmirror@2.6.0 start /home/pi/MagicMirror
        sh run-start.sh
        run-start.sh: 4: run-start.sh: electron: not found
        npm ERR! file sh
        npm ERR! code ELIFECYCLE
        npm ERR! errno ENOENT
        npm ERR! syscall spawn
        npm ERR! magicmirror@2.6.0 start: sh run-start.sh
        npm ERR! spawn ENOENT
        npm ERR!
        npm ERR! Failed at the magicmirror@2.6.0 start script.
        npm ERR! /home/pi/.npm/_logs/2019-01-20T16_40_06_112Z-debug.log
          sdetweil @Fonfon
          @fonfon in the magic mirror folder
          npm -i electron
          • F
            Fonfon @sdetweil
            @sdetweil command don’t work
              sdetweil @Fonfon
              @fonfon please add more info
              • F
                Fonfon @sdetweil
                @sdetweil for sure sorry
                pi@raspberrypi:~/MagicMirror $ npm -i electron
                Usage: npm
                where is one of:
                access, adduser, audit, bin, bugs, c, cache, ci, cit,
                clean-install, clean-install-test, completion, config,
                create, ddp, dedupe, deprecate, dist-tag, docs, doctor,
                edit, explore, get, help, help-search, hook, i, init,
                install, install-ci-test, install-test, it, link, list, ln,
                login, logout, ls, org, outdated, owner, pack, ping, prefix,
                profile, prune, publish, rb, rebuild, repo, restart, root,
                run, run-script, s, se, search, set, shrinkwrap, star,
                stars, start, stop, t, team, test, token, tst, un,
                uninstall, unpublish, unstar, up, update, v, version, view,
                whoami
                npm -h quick help on
                npm -l display full usage info
                npm help search for help on
                npm help npm involved overview
                Specify configs in the ini-formatted file:
                /home/pi/.npmrc
                or on the command line via: npm --key value
                Config info can be viewed via: npm help config
                npm@6.6.0 /usr/lib/node_modules/npm
                  sdetweil @Fonfon
                  @fonfon ok, my mistake
                  npm i electron
                  no dash (-)
                  Reply Quote 2
                  • F
                    Fonfon @sdetweil
                    @sdetweil after that
                    i’ll make a
                    npm audit
                    npm audit fix
                    npm install
                    and now it’s work great
                    Thanks very much @sdetweil for your help !!!
                    Reply Quote 2
                      great feedback , thank you
                      please mark your issue resolved…
                        bhepler Module Developer
                        In the future, please use the Markdown features of the board when posting code and logs.
