    Application not starting when OpenGL is enabled
    33 Posts 7 Posters 19.1k Views 6 Watching
      Anthony Project Sponsor @dazza120
      @dazza120 I already have heat sinks on all 3 chips of my rpi and a fan as well. I bought it like this in a case. I don’t know about temperatures because I haven’t monitor them yet but I hope you are right and not have any overheating problem. Thank you again.
        dazza120 @Anthony
        @anthony mines been running for 5days because I was trying to get GL running to see what it was like but so many problems with that on the Pi, anyway yep that’s the readings I just took them today, I have MMM-SystemStats you may want to look at it for the Pi
          @dazza120 I will install it as soon as I get home and solve another problem with black screen I have right now (too many reasons for black screen). Thank you so much for your help.
            dazza120 @Anthony
            @anthony yeah found GL caused black screen and running out of ram that’s why I have a Cron Job running every 12hours as after 24hours it would go dark, hence Cron job every 12hours
              rts58 @Anthony
              @anthony I am also noob. But, I installed pm2 and it allowed me to run OpenGL. I think it keeps electron and other running processes from using up all memory and will help.
                dazza120 @rts58
                @rts58 as mentioned GL causes all sorts of other issues for the Pi really not advisable
                  rts58 @dazza120
                  @dazza120 I was also running OpenGL because mostly of this thread. I was/am concerned about temps, my pi is stuck in a wall and I’m running modules for background images, weather, nests, calendar and newsfeeds. When I first tried the fake and full I was having startup problems so started using pm2 which fixed them. I just now performed a very unscientific comparison. I ran under each driver and compared the average 15 minute processor usage (after 30 minutes).
                  Full - .62
                  Fake - .45
                  Orig - .36
                  I wasn’t smart enough to pay attention to the other stats :frowning_face: . But for now I am going to follow your recommendation and drop OpenGL. Thanks.
                    dazza120 @rts58
                    @rts58 get MMM-SystemStats works well for the Pi and you can see memory,cpu and temp readings very handy when your running a Pi, if it ever happens that it goes black screen from days of use you will need to set a Cron job that refreshes the MM so memory starts over again hope that helps
                    • bheplerB Offline
                      bhepler Module Developer @Anthony
                      @anthony - Just FYI: PM2 is a process manager. It’s purpose is to make sure that the Magic Mirror process is always running and to start it automatically when you Pi boots. That’s all. It won’t help nor hinder your mirror’s performance.
                      When your Pi starts to overheat, you’ll see a thermometer icon in the upper right corner of your mirror.
                        dazza120 @bhepler
                        @bhepler wow never knew about the overheating symbol good to know, Everyone with a Pi should get a good heatsink and a fan fan not essential but helps loads.
                          dazza120 @rts58
                          @rts58 I stand corrected the latest version of MMM-System-Stats locks up after 13hours of the Pi being on, I’ve left a message on his github so hopefully it will be fixed as it’s the Pi’s only true stat reading for everything that you need to know the Pi is doing. Oh if your not using video modules you can get 16Mb more ram 🐏 by taking it from the graphics if your on a Pi 3B+ You can use the desktop
                          Start Menu, Preferences, Raspberry Pi configuration, Performance, then change GPU memory
                          or use Terminal
                          sudo Raspi-config
                          Advance
                          Memory Split
                          Ok
                          Then it will ask you to reboot
                            rts58 @dazza120
                            @dazza120 Thanks, I’m not using video, so I’ll look into this. I’ll also look at system stats.
                              Hello everyone. So I installed pm2 as @bhepler said and MMM-System-Stats as @dazza120 mentioned above and I managed to enable OpenGL without a black screen but I realized that the cpu load went from 0.85 to 2.1 and after half an hour the rpi got frozen. So I and up disabled it once again and my mirror runs continuously fro yesterday afternoon without any problem of overheating, black screen or freezing. the last stats I saw today was:
                              CPU Temp: 32.22
                              System Load 0.81
                              Free RAM: 32%
                              Uptime: 13 hours
                              Avail Space: 24G
                                @dazza120 I installed MMM-SystemStats to my mirror and it helped a lot to monitor its status. Thank you for the tip. I would like to ask you if you know if it is possible to change the module size because it looks too big according to the other modules. I tried to do it but I didn’t find any css file in its folder to customize it.
                                D R 2 Replies Last reply Reply Quote 0
                                  dazza120 @Anthony
                                  @anthony hi mate sorry, haven’t found out yet, may be message the Dev, but it isn’t really an issue for me but it would be nice to make the text look better
                                    @dazza120 I don’t want to make it look better. Just to reduce the size of the module. Thank you anyway for your reply. I’ll message the Dev.
                                      rts58 @Anthony
                                      @anthony Hi, I found this post maybe it will help? Also, custom.css is for all modules is in the css directory.
                                      @strawberry-3-141 said in MMM-forecast-io -- Localized up to the minute weather:
                                      .MODULENAME {
                                        transform: scale(0.5, 0.5);
                                      if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
                                      A 1 Reply Last reply Reply Quote 1
                                        Anthony Project Sponsor @rts58
                                        @rts58 That worked. Thank you very much.
