    MMM-Chart - View your graphs on your Mirror
    21 Posts 8 Posters 22.9k Views 10 Watching
    • L Offline
      logen563
      Finally it’s working :) Thanks for the help. I use googlespread sheet, csv export, and php to convert it to json. If some somebody interested I can give some help.
        schmo90
        Hy it was quite hard to get the dht22 values showing up with your chart.
        finally i got the php script working to fetch mysql data to your json format:
        //your code here
            //open connection to mysql db
            $connection = mysqli_connect("localhost","logger","password","temperatures") or die("Err$
            //fetch table rows from mysql db
            $sql = "select * from temperaturedata";
                $result = mysqli_query($connection, $sql) or die("Error in Selecting " . mysqli_erro$
                //create an array
                $emparray = array();
                $position=0;
                while($row =mysqli_fetch_assoc($result))
                        $emparray[$position][] = $row['dateandtime'];
                        $emparray[$position][] = $row['temperature'];
                        $emparray[$position][] = $row['humidity'];
                        $position++;
                echo json_encode($emparray);
                //close the db connection
                mysqli_close($connection);
          schmo90
          Hy i also have troubles with the real time chart.
          it shows the chart only for 0,5s and then it will disapear?
          do you ever had this issue?
          and is it possible to ad more ticks on the x-axis?
          if i display temp data from a day, it will only show two ticks
          • Z Offline
            zazzo
            Good day all,
            i’m able to see my data locally on my php file, but unfortunately i cannot see the graph on my MM page…
            This is what i see when i open my index.php file:
            This is the config file:
            And this is what i see in my MM page:
            Any suggestion? Consider that i’m not an expert…
            Thanks.
            Regards.
              schmo90
              (0_1531251389830_2018-07-10 21_35_41-192.168.8.100 (mirror) – VNC Viewer.png image url)
              I have the issue that the graph is jumping back to the beginning.
              Has anyone else this issue?
              @zazzo hm strange your data looks code…
                schmo90
                Hy i solved the issue with jumping values.
                you are deleting the y axis values in the file mmm-chart.js
                but not the label dataarray.
                i added the line:
                this.chartData.labels = [];
                at #296 and now i have fixed the jumping value issue
                i also added the suggestedMin/Max parameter and to change the line chart to a stepped line chart
                  ricq
                  @logen563 Hi. I am interested how you did this? Would like to display graph. Data is from an xml file that I download daily.
                    schmo90 @ricq
                    @ricq you have to convert the xml to the json format.
                    i have now build a python script which provides the data from my sensors.
                    or you build a php script…
                      ricq @logen563
                      • T Offline
                        turntablist2
                        How do i turn my MQTT temperature data from Mosquito into jason data providing me with a url for this module? or is there a way to get your module to read an mqtt topic?
                        • T Offline
                          turntablist2 @zazzo
                          @zazzo how did you create that php file in the first place? I’m new to this and really struggling. thanks in advance
                            sdetweil @turntablist2
                            @turntablist2 u can use any language u like. I created a conversion script in JavaScript for one person.
                            It’s knowing your data, and how you would organized it into items you would chart.
                            Draw the chart on paper, what are the x and y axis?, how do you get your data into points along the line.
