    jquery module not working --- need help!
    10 Posts 3 Posters 2.7k Views 3 Watching
    • justjim1220J Offline
      justjim1220 Module Developer
      Ok, so I wrote this program: https://codepen.io/justjim1220/pen/dapLPo?editors=1000
      And in CodePen, it works perfectly.
      But I have attempted to convert it over to be a MagicMirror module:
      https://github.com/justjim1220/MMM-KitchenTimer
      it shows up exactly as it should, BUT, none of the buttons work.
      I get the hover action, and even the click action, but the buttons don’t do anything else.
      Plus, I don’t get any errors in dev console.
      Any ideas?
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        sdetweil @justjim1220
        @justjim1220 we discussed this offline…
        the jquery code is executing inline of the getDom() function, and the element selectors
        $('#more')  is same as  (document.getElementById('more'))
        will fail as the content is not IN the html document yet
          MagicMirror is what is called a Single Page web application. one html page.
          the base framework defines the page layout and regions. each module can contribute ITS little piece of content by returning the top element of that content starting with a div.
          the getDom module function is responsible for developing and returning that div tree.
          sometime AFTER the getdom function returns with the div object
          var wrapper=  document.createElement('div')
          return wrapper
          the div will be inserted into the dom at the module defined location. (position)
          note that multiple modules may contribute to the same location, in a FIFO order. (as defined in config.js)
          element.appendChild(new_content_anchor)
          any code inside getDom() that attempts to locate elements by ID (search the single page dom) will FAIL,
          as the modules dom contribution has not been inserted until AFTER sometime getdom() returns the div element
          • cowboysdudeC Offline
            You can’t just go copy something and plug it in… you have to have an understanding of how it works… @sdetweil gave a REALLY great explanation.
            You can load your jquery either with the above getScripts or you can do in the getDom … I have a few things working with jQuery… go look at my MMM-Recipe module…for an example of how I did it.
            justjim1220J 3 Replies Last reply Reply Quote 0
              justjim1220 Module Developer @cowboysdude
              @cowboysdude Thanks! I will do that! :winking_face:
              Jim Hallock - 1995
                @cowboysdude How do I mark this as SOLVED?
                Jim Hallock - 1995
                  @justjim1220 I’d like to see what you did.
                    justjim1220 Module Developer @sdetweil
                    LOL!
                    I merged a pull request from @Seann :face_with_tears_of_joy:
                    I am going through it right now to see what he did.
                    And, I am going through the changes you made with the VideoPlayer2 module.
                    With what you have taught me and with the changes to the Video Player and the Kitchen timer,
                    I am gonna try to apply this to a few other programs I have ready to convert from JQuery.
                    I am also going through @cowboysdude’s Recipe module to see how to get JQuery to actually work with MM.
                    Today, I am spending time RE-LEARNING javascript and how to apply it to MM modules. :upside-down_face: :upside-down_face: :upside-down_face:
                    Maybe it will steer me away from JQuery in the future! :winking_face:
                    Jim Hallock - 1995
                      @cowboysdude
                      I really like the changes you’ve made with this Recipe Module!!! :winking_face:
                      Jim Hallock - 1995
                        @justjim1220 yeh, his use of jQuery is not against the HTML as u were doing, but against data items returned from other sources.
