    Calender only Loading!
    21 Posts 4 Posters 14.3k Views 4 Watching
    • F Offline
      Force_United
      Yo! @sdetweil
      Not working )-:
      with best regards
      ★Force_United ★
      • F Offline
        Force_United
        Yo! @sdetweil
        I think the calendar is set up as American time and not Norwegian time. how do I change the calendar to Norwegian time? The clock is set correctly but the calendar is not correct.
        with best regards
        ★Force_United ★
          sdetweil @Force_United
          @force_united what calendar? my google calendar is set to my local time
          • F Offline
            Force_United
            Yo!
            When the clock is 06:00 in norway it is 00:00 in the usa. so it changes when the clock is 06:00 in norway.
            with best regards
            ★Force_United ★
              @force_united not the question…
              there is local system time (pi clock) - YOU set the system time (MM uses system time)
              and there is calendar time (where is the calendar stored?)… mine is on google.com (wherever that is)…
              • F Offline
                Force_United
                Yo! @sdetweil i use google calender (-:
                • F Offline
                  Force_United
                  Yo! @Mykle1 @MichMich @sdetweil
                  Same problems with calander. Calander not sync with my norwegian time.
                  Where can I get this to work?
                  When the clock in norway is 00:00 it is still on the same date. But when the time is 06:00 in norway, the calendar changes to the next date. I want the calendar to sync with Norwegian time.
                  I need help!
                  ★Force_United ★
                  • F Offline
                    Force_United
                    Yo!
                    I want the calendar to change date 00:00 in Norwegian time.
                    ★Force_United ★
                    • F Offline
                      Force_United
                      HELLO???
                        @force_united is the mm system timezone the same as the calendar timezone?
                        • F Offline
                          Force_United
                          @sdetweil Yes!
