    Calender only Loading!
    21 Posts 4 Posters 14.2k Views 4 Watching
    • F Offline
      Force_United
      @Mykle1 Yo! I am not good in linux so can you get me the commands to check everything i need to check?
      what is the command here? New system, old, what level of MM, what kind of calendar, do u see errors,
      linux is unknown to me
      Please help me!
        Mykle1 Project Sponsor Module Developer @Force_United
        @force_united said in Calender only Loading!:
        Hmm, let’s just start here. I assume you’ve changed the default NY TIMES CALENDAR url. Otherwise, it should be working. SO, post(copy and paste, using a code block) your calendar entry from your config.js file here.
        • F Offline
          Force_United
          Yo! @Mykle1
          i fix my problem (-:
          But somthing is wrong ): date in calender is not correct is not 4 days to the event is 5 days. I not understand that )-;
          Please help! (-:
          Thank you
          with best regards
          ★¯_(Force_United)_/¯★
          • F Offline
            Force_United
            Yo! @Mykle1 @MichMich
            How can I set up the calendar for Norwegian time?
            with best regards
            ★Force_United ★
              sdetweil @Force_United
              @force_united
              another post said
              had the same issue, it shows you the end of the event, usually because its an all day event.
              here is my config:
              just added the option showEnd: false <-----
              and date and time formats according to moment
              • F Offline
                Force_United
                Yo! @sdetweil
                Not working )-:
                with best regards
                ★Force_United ★
                • F Offline
                  Force_United
                  Yo! @sdetweil
                  I think the calendar is set up as American time and not Norwegian time. how do I change the calendar to Norwegian time? The clock is set correctly but the calendar is not correct.
                  with best regards
                  ★Force_United ★
                    @force_united what calendar? my google calendar is set to my local time
                    • F Offline
                      Force_United
                      Yo!
                      When the clock is 06:00 in norway it is 00:00 in the usa. so it changes when the clock is 06:00 in norway.
                      with best regards
                      ★Force_United ★
                        @force_united not the question…
                        there is local system time (pi clock) - YOU set the system time (MM uses system time)
                        and there is calendar time (where is the calendar stored?)… mine is on google.com (wherever that is)…
                        • F Offline
                          Force_United
                          Yo! @sdetweil i use google calender (-:
                          • F Offline
                            Force_United
                            Yo! @Mykle1 @MichMich @sdetweil
                            Same problems with calander. Calander not sync with my norwegian time.
                            Where can I get this to work?
                            When the clock in norway is 00:00 it is still on the same date. But when the time is 06:00 in norway, the calendar changes to the next date. I want the calendar to sync with Norwegian time.
                            I need help!
                            ★Force_United ★
                            • F Offline
                              Force_United
                              Yo!
                              I want the calendar to change date 00:00 in Norwegian time.
                              ★Force_United ★
                              • F Offline
                                Force_United
                                HELLO???
                                  @force_united is the mm system timezone the same as the calendar timezone?
                                  • F Offline
                                    Force_United
                                    @sdetweil Yes!
