    Calender only Loading!
    21 Posts 4 Posters 12.9k Views 4 Watching
      sdetweil @Force_United
      @force_united could u give us a little more info.
      New system, old, what level of MM, what kind of calendar, do u see errors,
      Etc
      • F Offline
        Force_United @sdetweil
        Hi! Do you have discord so i can show you! I am not good in Linux so i need so much help!
        Please help
        • F Offline
          Force_United
          @sdetweil can you help me??
            Mykle1 Project Sponsor Module Developer @Force_United
            @force_united
            @sdetweil asked you a few questions in order to help you. That’s how it works. You post your problem. Others posts their answers. People that read this in the future have the benefit of this information.
            • F Offline
              Force_United
              @Mykle1 Yo! I am not good in linux so can you get me the commands to check everything i need to check?
              what is the command here? New system, old, what level of MM, what kind of calendar, do u see errors,
              linux is unknown to me
              Please help me!
                @force_united said in Calender only Loading!:
                Hmm, let’s just start here. I assume you’ve changed the default NY TIMES CALENDAR url. Otherwise, it should be working. SO, post(copy and paste, using a code block) your calendar entry from your config.js file here.
                • F Offline
                  Force_United
                  Yo! @Mykle1
                  i fix my problem (-:
                  But somthing is wrong ): date in calender is not correct is not 4 days to the event is 5 days. I not understand that )-;
                  Please help! (-:
                  Thank you
                  with best regards
                  ★¯_(Force_United)_/¯★
                  • F Offline
                    Force_United
                    Yo! @Mykle1 @MichMich
                    How can I set up the calendar for Norwegian time?
                    with best regards
                    ★Force_United ★
                      @force_united
                      another post said
                      had the same issue, it shows you the end of the event, usually because its an all day event.
                      here is my config:
                      just added the option showEnd: false <-----
                      and date and time formats according to moment
                      • F Offline
                        Force_United
                        Yo! @sdetweil
                        Not working )-:
                        with best regards
                        ★Force_United ★
