    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.6k Views 6 Watching
    • Cr4z33C
      Cr4z33 @AxLed
      @AxLed it’s an internal LAN IP address.
      • Cr4z33C
        Cr4z33
        @AxLed I tried @evroom 's module config, but it keeps not streaming.
        • evroomE
          evroom
          @Cr4z33
          Try this:
          $ cd ~/MagicMirror/modules/MMM-Dreambox/
          $ cp -p node_helper.js node_helper.js.orig
          $ vi node_helper.js
          Locate:
          exec('omxplayer '
          Append this line:
          console.log('DB-PLAY(1): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
          Locate next:
          exec('omxplayer '
          Append this line:
          console.log('DB-PLAY(2): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
          $ pm2 restart mm
          $ pm2 logs
          Select a service and play that service:
          http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
          http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-PLAY
          In pm2 logs should appear:
          0|mm  | DB-PLAY(1): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
          or:
          0|mm  | DB-PLAY(2): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
          In my case I see DB-PLAY(2).
          If you see nothing then it is back to the drawing board.
          Need to see what works and what not and where in the code.
          MagicMirror version: 2.37.0
          Cr4z33C 3 Replies Last reply
          • Cr4z33C
            Cr4z33 @evroom
            @evroom thanks I will try later today.
            • Cr4z33C
              Cr4z33 @evroom
              @evroom there are two instances of
              exec('omxplayer '
              one at line 40 and one at line 45.
              What shall I do?
              • evroomE
                evroom
                @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                What shall I do?
                After both lines you need to put the console.log line, one with (1) and one with (2), see my post:
                Locate:
                exec('omxplayer '
                Append this line:
                Locate next:
                exec('omxplayer '
                Append this line:
                • Cr4z33C
                  Cr4z33 @evroom
                  @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                  Nothing reported into PM2 logs. :persevering_face:
                  • evroomE
                    evroom
                    @Cr4z33
                    That explains the missing stream.
                    You are not getting to the DB-PLAY routine.
                    To me it looks like you have an issue with MMM-Remote-Control.
                    For example, I almost always get success, provide the IP is right, but the notification can be wrong
                    {"status":"success"}
                    Can you try this:
                    $ cd /home/pi/MagicMirror/modules/MMM-Remote-Control
                    $ git pull
                    $ git status
                    $ npm install
                    And then restart mm and try again.
                    You can also put a debug line in the DB-STOP call and do
                    http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-STOP
                    $ vi node_helper.js
                                    if (notification === "DB-STOP") {
                    console.log('DB-STOP: stop the stream');
                                            exec('pkill omxplayer', null);
                    If you do not see this in the pm2 logs, then MMM-Remote-Control seems to be the culprit or the communication between the 2 modules.
                    But as it works for both AxLed and me …
                    Cr4z33C 1 Reply Last reply
                    • Cr4z33C
                      Cr4z33 @evroom
                      @evroom oh wait what version of MMM-Remote-Control are you using? 🤔
                      The original developer (cannot remember the name sorry) one or the new one made by shbatm?
                      evroomE 1 Reply Last reply
                      • A
                        AxLed Module Developer
                        @evroom said in [MMM-Dreambox]:
                        @Cr4z33 and @evroom
                        You were pretty busy in debugging so far, somehow i had a similar idea as evroom.
                        You can do an git pull in your MMM-Dreambox folder for the dev branch, i added some debugging informations.
                        $ cd /home/pi/MagicMirror/modules/MMM-Dreambox
                        $ git pull
                        Maybe “zap” or the “zap” Url isnt working.
                        @Cr4z33 can you please update and post the logs, the should look like
                        Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:19:2B5C:41B:1:FFFF014A:0:0:0:
                        Debug MMM-Dreambox: zapstate:zap
                        or
                        Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:1:CBB2:2710:F001:FFFF0000:0:0:0:
                        You can also try to reduce the arguments like mine above to --win 320,180,1600,900 -o both.
                        I use MMM-Remote-Control of Jopyth.
                        AxLED
                        • evroomE
                          evroom @Cr4z33
                          @cr4z33
                          I think this one
                          https://github.com/Jopyth/MMM-Remote-Control
                          Cannot find the one from shbatm…
                          • evroomE
                            evroom
                            By coincidence there was a new post regarding the new module:
                            https://github.com/shbatm/MMM-Remote-Control
                            I do not use this one.
                            Neither does AxLed, so we can be on to something.
                            • Cr4z33C
                              Cr4z33 @evroom
                              @evroom yeah definitely a possible reason why I was getting no streams considering that I was using shbatm version!
                              Right now I am not at home, but I will surely try (also what @AxLed said) tomorrow. 👍🏼
                              • Cr4z33C
                                Cr4z33
                                @AxLed so I had the time to try everything you and @evroom suggested me.
                                I also ran the module update and installed MMM-Remote-Control by @Jopyth .
                                I still am getting the same ending (no streaming), BUT this time I noticed an error in console log as soon as I ran the remote DB-PLAY command (note that in the MMM-Remote-Control web page I got the ‘success’ message instead)!
                                MMM-Dreambox.js:292 Uncaught TypeError: Cannot read property '0' of undefined
                                    at Class.notificationReceived (MMM-Dreambox.js:292)
                                    at sendNotification (main.js:95)
                                    at Object.sendNotification (main.js:498)
                                    at Class.sendNotification (module.js:368)
                                    at Class.socketNotificationReceived (MMM-Remote-Control.js:130)
                                    at module.js:246
                                    at r.<anonymous> (socketclient.js:25)
                                    at r.emit (index.js:83)
                                    at r.onevent (index.js:83)
                                    at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                notificationReceived @ MMM-Dreambox.js:292
                                sendNotification @ main.js:95
                                sendNotification @ main.js:498
                                sendNotification @ module.js:368
                                socketNotificationReceived @ MMM-Remote-Control.js:130
                                (anonymous) @ module.js:246
                                (anonymous) @ socketclient.js:25
                                r.emit @ index.js:83
                                r.onevent @ index.js:83
                                MMSocket.self.socket.onevent @ socketclient.js:19
                                r.onpacket @ index.js:83
                                (anonymous) @ index.js:83
                                r.ondecoded @ index.js:83
                                a.add @ index.js:83
                                r.ondata @ index.js:83
                                r.onPacket @ index.js:83
                                r.onData @ index.js:83
                                ws.onmessage @ index.js:83
                                Listen what if I want to try a different bouquet?
                                Let’s say I call it ‘MagicMirror’ and put in just 4-5 TV channels where should I look at then to enter its URL path in the module?
                                • evroomE
                                  evroom
                                  Do:
                                  http://192.168.178.47/web/getservices
                                  Then use the FROM BOUQUET part to change the apiepgnow and apiServicelistplayable parameters in config.js.
                                  Best is to copy your original lines, comment out your original line.
                                  For example:
                                  // apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                                  apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.magicmirror__tv_.tv%22%20ORDER%20BY%20bouquet',
                                  Change the apibouquet parameter to the offset of your bouquet.
                                  Meaning, if your magicmirror bouquet is the 3rd bouquet, then use apibouquet: 2, (0 being favourites.tv).
                                  And of course restart mm.
                                  • Cr4z33C
                                    Cr4z33 @evroom
                                    @evroom cheers going to use it tomorrow. :)
                                    • evroomE
                                      evroom
                                      So, you do not see the Debug MMM-Dreambox: lines in the pm2 log ?
                                      I see this:
                                      0|mm  | Starting node helper for: MMM-Dreambox
                                      0|mm  | Debug MMM-Dreambox: omxplayer  --genlog --vol -6000 --win  600,300,960,940 --live http://192.168.178.47:8001/1:0:1:6DCA:44D:1:C00000:0:0:0:
                                      0|mm  | Debug MMM-Dreambox: zapstate:
                                      If not, I still believe DB-PLAY is not working for you, hence MMM-Remote-Control.
                                      Did you de-install the other version ? Perhaps they bite each other.
                                      Did not forget the npm install in the MMM-Remote-Control dir ?l
                                      • Cr4z33C
                                        Cr4z33 @evroom
                                        @evroom nope anyway I have to stop looking further into it.
                                        Mirror building is taking more than expected, I’ve got everything needed and my other streaming module is now working so honestly speaking I don’t need MMM-Dreambox anymore. :face_with_stuck-out_tongue_winking_eye:
                                        Once I am done with the mirror I might come back at trying it.
                                        In the meantime thank you very much indeed @evroom and @AxLed for all the support you gave me! :flexed_biceps_medium-light_skin_tone:
                                        • evroomE
                                          evroom
                                          You’re welcome, but still a pity it did not work for you.
                                          Good luck with the rest of your build.
                                          Ciao!
                                          • E
                                            Eisblume
                                            i also have a streaming problem, maybe you could help me.
                                            I cloned the dev - branch and connected with my Vu+ Ultimo 4K. The Bouquet-List is shown on my MagicMirror, but when i switch to a channel and want to stream, nothing happened. MPG2-License is installed on my RPI3.
                                            My config:
                                            	        module: 'MMM-Dreambox',
                                            			header: 'Vu+ Ultimo4K powered by VTi',
                                            			position: 'bottom_left',
                                            				apiBase: 'http://192.168.1.50:90',
                                            				omxargs: ' --genlog --win 320,180,1600,900 -o both ',
                                            				refreshInterval: 1000 * 30, //refresh every 30 seconds
                                            				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices),
                                            				apiRecordingsID: 0, //which recording folder should be listed
                                            				listmax: 10,
                                            				apiabout: '/web/about',
                                            				apiservices: '/web/getallservices',
                                            				apiepgnow: '/web/epgnow?bRef=',
                                            				apizap: '/web/zap?sRef=',
                                            				apiTimerlist: '/web/timerlist',
                                            				apiServicelistplayable: '/web/servicelistplayable?sRef=',
                                            				apiLocations: '/web/getlocations', //where are the recording folders listed
                                            				apiMovielist: '/web/movielist?dirname=' //link for opening recording folder and list recordings
                                            LOG:
                                            11:51:56 T:18446744072748435108   DEBUG: DllBcm: Using omx system library
                                            11:51:56 T:18446744072748437218   DEBUG: DllOMX: Using omx system library
                                            11:51:56 T:18446744072748438188   DEBUG: DllAvFormat: Using libavformat system library
                                            11:51:56 T:18446744072748440537 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                            11:51:56 T:18446744072748440974 WARNING: DBus connection failed, trying alternate
                                            11:51:56 T:18446744072748442960   DEBUG: DBus connection succeeded
                                            11:51:56 T:18446744072748444308   DEBUG: Keyboard: DBus connection succeeded
                                            11:51:56 T:18446744072748444536   DEBUG: OMXThread::Create - Thread with id 1855955424 started
                                            11:51:56 T:18446744072748444712   DEBUG: DllAvUtilBase: Using libavutil system library
                                            11:51:56 T:18446744072748444743   DEBUG: DllAvCodec: Using libavcodec system library
                                            11:51:56 T:18446744072748444765   DEBUG: DllAvFormat: Using libavformat system library
                                            11:51:56 T:18446744072748445900   DEBUG: COMXPlayer::OpenFile - avformat_open_input http://192.168.1.50:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:
                                            11:51:59 T:18446744072751434345   DEBUG: COMXPlayer::OpenFile - avformat_open_input enabled SEEKING
                                            11:52:02 T:18446744072754462336   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x2108d10
                                            11:52:02 T:18446744072754462735   DEBUG: OMXClock::OMXStop
                                            11:52:02 T:18446744072754462891   DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
                                            11:52:02 T:18446744072754463128   DEBUG: DllAvUtilBase: Using libavutil system library
                                            11:52:02 T:18446744072754463154   DEBUG: DllAvCodec: Using libavcodec system library
                                            11:52:02 T:18446744072754463176   DEBUG: DllAvFormat: Using libavformat system library
                                            11:52:02 T:18446744072754464909   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x21cb9a0
                                            11:52:02 T:18446744072754466025   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(60), nBufferSize(81920), nBufferAlignmen(16)
                                            11:52:02 T:18446744072754475930   DEBUG: COMXVideo::Open - decoder_component(0x0x21cb9a0), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 0
                                            11:52:02 T:18446744072754476291   DEBUG: OMXThread::Create - Thread with id 1843392992 started
                                            11:52:02 T:18446744072754476455   DEBUG: OMXThread::Create - Thread with id 1835000288 started
                                            11:52:02 T:18446744072754476561   DEBUG: DllAvUtilBase: Using libavutil system library
                                            11:52:02 T:18446744072754476617   DEBUG: DllAvCodec: Using libavcodec system library
                                            11:52:02 T:18446744072754476649   DEBUG: DllAvFormat: Using libavformat system library
                                            11:52:02 T:18446744072754476683   DEBUG: DllAvUtilBase: Using libavutil system library
                                            11:52:02 T:18446744072754476707   DEBUG: DllAvCodec: Using libavcodec system library
                                            11:52:02 T:18446744072754476739   DEBUG: DllAvFormat: Using libswresample system library
                                            11:52:02 T:18446744072754476943   ERROR: OMXPlayerSubtitles::RenderLoop threw 13Enforce_error (Enforcement failed in SubtitleRenderer.cpp(293))
                                            11:52:02 T:18446744072754477009   DEBUG: OMXThread::Run - Exited thread with  id 1835000288
                                            11:52:02 T:18446744072754477073    INFO: COMXAudioCodecOMX::GetChannelMap - FFmpeg reported 2 channels, but the layout contains 0 ignoring
                                            11:52:02 T:18446744072754477119   DEBUG: DllAvUtilBase: Using libavutil system library
                                            11:52:02 T:18446744072754477149   DEBUG: COMXAudio::SetCodingType OMX_AUDIO_CodingPCM
                                            11:52:02 T:18446744072754477190    INFO: CPCMRemap: I channel map: FL,FR
                                            11:52:02 T:18446744072754477271    INFO: CPCMRemap: O channel map: FL,FR
                                            11:52:02 T:18446744072754477301   DEBUG: CPCMRemap: Downmix normalization is disabled
                                            11:52:02 T:18446744072754477360   DEBUG: CPCMRemap: FL = FL(1.000000*)
                                            11:52:02 T:18446744072754477390   DEBUG: CPCMRemap: FR = FR(1.000000*)
                                            11:52:02 T:18446744072754479069   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121 m_handle 0x21cb930
                                            11:52:02 T:18446744072754480288   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - port(120), nBufferCountMin(4), nBufferCountActual(16), nBufferSize(65536), nBufferAlignmen(16)
                                            11:52:02 T:18446744072754492628   DEBUG: COMXAudio::Initialize Input bps 32 samplerate 48000 channels 2 buffer size 576000 bytes per second 384000
                                            11:52:02 T:18446744072754492747   DEBUG: pcm->direction      : input
                                            11:52:02 T:18446744072754492777   DEBUG: pcm->nPortIndex     : 120
                                            11:52:02 T:18446744072754492803   DEBUG: pcm->eNumData       : 0
                                            11:52:02 T:18446744072754492825   DEBUG: pcm->eEndian        : 1
                                            11:52:02 T:18446744072754492850   DEBUG: pcm->bInterleaved   : 1
                                            11:52:02 T:18446744072754492875   DEBUG: pcm->nBitPerSample  : 32
                                            11:52:02 T:18446744072754492898   DEBUG: pcm->ePCMMode       : 0
                                            11:52:02 T:18446744072754492920   DEBUG: pcm->nChannels      : 2
                                            11:52:02 T:18446744072754492944   DEBUG: pcm->nSamplingRate  : 48000
                                            11:52:02 T:18446744072754492965   DEBUG: OMX_AUDIO_ChannelLF
                                            11:52:02 T:18446744072754492989   DEBUG: OMX_AUDIO_ChannelRF
                                            11:52:02 T:18446744072754493013   DEBUG: COMXAudio::Initialize device omx:both passthrough 0 hwdecode 0
                                            11:52:02 T:18446744072754493239   DEBUG: OMXThread::Create - Thread with id 1826607584 started
                                            11:52:02 T:18446744072754493299  NOTICE: OMXClock using audio as reference
                                            11:52:02 T:18446744072754493559   DEBUG: OMXClock::OMXReset audio / video : 1 / 1 wait mask 0->3 state : 2->1
                                            11:52:02 T:18446744072754493965   DEBUG: Popped message member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
                                            11:52:02 T:18446744072754494024 WARNING: Unhandled dbus message, member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
                                            11:52:02 T:18446744072754494181   DEBUG: Normal M:0 (A:-4503599627370496 V:-4503599627370496) P:1 A:0.00 V:0.00/T:0.20 (0,0,0,0) A:0% V:0% (0.00,6.07)
                                            11:52:02 T:18446744072754494410    INFO: CDVDPlayerVideo::Decode dts:579978 pts:620000 cur:620000, size:38830
                                            11:52:02 T:18446744072754494468   DEBUG: OMXVideo::Decode VDec : setStartTime 0.620000
                                            11:52:02 T:18446744072754495015    INFO: CDVDPlayerAudio::Decode dts:101734 pts:101734 size:782
                                            11:52:02 T:18446744072754495431    INFO: CDVDPlayerVideo::Decode dts:599978 pts:600000 cur:600000, size:22063
                                            11:52:02 T:18446744072754495946   DEBUG: COMXAudioCodecOMX::Decode(0x2130f30,782) format=6(8) chan=2 samples=1152 size=2304 data=0x6c400560,0x6c400f30,(nil),(nil),(nil),(nil),(nil),(nil)
                                            11:52:02 T:18446744072754496546   DEBUG: COMXAudioCodecOMX::GetData size=4608/9216 line=2304/4608 buf=0x6c4018a8, desired=65536
                                            11:52:02 T:18446744072754496794    INFO: CDVDPlayerVideo::Decode dts:619978 pts:640000 cur:640000, size:20976
                                            11:52:02 T:18446744072754496900    INFO: CDVDPlayerAudio::Decode dts:125734 pts:125734 size:768
                                            11:52:02 T:18446744072754497501    INFO: CDVDPlayerVideo::Decode dts:639978 pts:740000 cur:740000, size:49029
                                            11:52:02 T:18446744072754497937    INFO: CDVDPlayerAudio::Decode dts:149734 pts:149734 size:768
                                            11:52:02 T:18446744072754498443    INFO: CDVDPlayerAudio::Decode dts:173734 pts:173734 size:768
                                            11:52:02 T:18446744072754498577    INFO: CDVDPlayerVideo::Decode dts:659978 pts:700000 cur:700000, size:33312
                                            11:52:02 T:18446744072754499257    INFO: CDVDPlayerAudio::Decode dts:197734 pts:197734 size:768
                                            11:52:02 T:18446744072754499877    INFO: CDVDPlayerAudio::Decode dts:221734 pts:221734 size:782
                                            11:52:02 T:18446744072754500450    INFO: CDVDPlayerAudio::Decode dts:245734 pts:245734 size:768
                                            11:52:02 T:18446744072754500879    INFO: CDVDPlayerAudio::Decode dts:269734 pts:269734 size:768
                                            11:52:02 T:18446744072754501563   DEBUG: COMXAudio::Decode ADec : setStartTime 0.101733
                                            11:52:02 T:18446744072754506083    INFO: CDVDPlayerVideo::Decode dts:679978 pts:680000 cur:680000, size:20826
                                            11:52:02 T:18446744072754507862    INFO: CDVDPlayerVideo::Decode dts:699978 pts:720000 cur:720000, size:22291
                                            11:52:02 T:18446744072754509115    INFO: CDVDPlayerVideo::Decode dts:719978 pts:820000 cur:820000, size:48896
                                            11:52:02 T:18446744072754510007    INFO: CDVDPlayerVideo::Decode dts:739978 pts:780000 cur:780000, size:29819
                                            11:52:02 T:18446744072754510702   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x6c415f20
                                            11:52:02 T:18446744072754510922    INFO: CDVDPlayerVideo::Decode dts:759978 pts:760000 cur:760000, size:17747
                                            11:52:02 T:18446744072754511602    INFO: CDVDPlayerVideo::Decode dts:779978 pts:800000 cur:800000, size:21012
                                            11:52:02 T:18446744072754512703    INFO: CDVDPlayerVideo::Decode dts:799978 pts:900000 cur:900000, size:55598
                                            11:52:02 T:18446744072754513370    INFO: CDVDPlayerVideo::Decode dts:819978 pts:860000 cur:860000, size:41374
                                            11:52:02 T:18446744072754514202    INFO: CDVDPlayerVideo::Decode dts:839978 pts:840000 cur:840000, size:20662
                                            11:52:02 T:18446744072754514839    INFO: CDVDPlayerVideo::Decode dts:859978 pts:880000 cur:880000, size:20566
                                            11:52:02 T:18446744072754515314   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_splitter input port 261 output port 262 m_handle 0x6c400498
                                            11:52:02 T:18446744072754515406    INFO: CDVDPlayerVideo::Decode dts:879978 pts:980000 cur:980000, size:47687
                                            11:52:02 T:18446744072754515454   DEBUG: Popped message member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
                                            11:52:02 T:18446744072754515597 WARNING: Unhandled dbus message, member: NameAcquired interface: org.freedesktop.DBus type: 4 path: /org/freedesktop/DBus
                                            11:52:02 T:18446744072754516290    INFO: CDVDPlayerVideo::Decode dts:899978 pts:940000 cur:940000, size:29649
                                            11:52:02 T:18446744072754516851    INFO: CDVDPlayerVideo::Decode dts:919978 pts:920000 cur:920000, size:20177
                                            11:52:02 T:18446744072754517306    INFO: CDVDPlayerVideo::Decode dts:939978 pts:960000 cur:960000, size:25105
                                            11:52:02 T:18446744072754517345   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x6c4160f0
                                            11:52:02 T:18446744072754517888    INFO: CDVDPlayerVideo::Decode dts:959978 pts:1000000 cur:1000000, size:79994
                                            11:52:02 T:18446744072754518996    INFO: CDVDPlayerVideo::Decode dts:979978 pts:1080000 cur:1080000, size:56353
                                            11:52:02 T:18446744072754519965    INFO: CDVDPlayerVideo::Decode dts:999978 pts:1040000 cur:1040000, size:41364
                                            11:52:02 T:18446744072754520216   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x6c4161c0
                                            11:52:02 T:18446744072754520520    INFO: COMXAudio::ApplyVolume - Volume=1.00 (* 1.00 * 1.00)
                                            11:52:02 T:18446744072754520617    INFO: CDVDPlayerVideo::Decode dts:1019978 pts:1020000 cur:1020000, size:23672
                                            11:52:02 T:18446744072754521516   DEBUG: COMXAudio::PortSettingsChanged - Output bps 16 samplerate 48000 channels 2 buffer size 576000 bytes per second 192000
                                            11:52:02 T:18446744072754521645    INFO: CDVDPlayerVideo::Decode dts:1039978 pts:1060000 cur:1060000, size:24216
                                            11:52:02 T:18446744072754521706   DEBUG: pcm->direction      : output
                                            11:52:02 T:18446744072754521737   DEBUG: pcm->nPortIndex     : 231
                                            11:52:02 T:18446744072754521773   DEBUG: pcm->eNumData       : 0
                                            11:52:02 T:18446744072754521802   DEBUG: pcm->eEndian        : 1
                                            11:52:02 T:18446744072754521832   DEBUG: pcm->bInterleaved   : 1
                                            11:52:02 T:18446744072754521854   DEBUG: pcm->nBitPerSample  : 16
                                            11:52:02 T:18446744072754521875   DEBUG: pcm->ePCMMode       : 0
                                            11:52:02 T:18446744072754521897   DEBUG: pcm->nChannels      : 2
                                            11:52:02 T:18446744072754521918   DEBUG: pcm->nSamplingRate  : 48000
                                            11:52:02 T:18446744072754521938   DEBUG: OMX_AUDIO_ChannelLF
                                            11:52:02 T:18446744072754521962   DEBUG: OMX_AUDIO_ChannelRF
                                            11:52:02 T:18446744072754522650    INFO: CDVDPlayerVideo::Decode dts:1059978 pts:1160000 cur:1160000, size:52784
                                            11:52:02 T:18446744072754523338    INFO: CDVDPlayerVideo::Decode dts:1079978 pts:1120000 cur:1120000, size:36614
                                            11:52:02 T:18446744072754523817    INFO: CDVDPlayerVideo::Decode dts:1099978 pts:1100000 cur:1100000, size:22682
                                            11:52:02 T:18446744072754524392    INFO: CDVDPlayerVideo::Decode dts:1119978 pts:1140000 cur:1140000, size:23151
                                            11:52:02 T:18446744072754524959    INFO: CDVDPlayerVideo::Decode dts:1139978 pts:1240000 cur:1240000, size:50413
                                            11:52:02 T:18446744072754525560    INFO: CDVDPlayerVideo::Decode dts:1159978 pts:1200000 cur:1200000, size:40547
                                            11:52:02 T:18446744072754526169    INFO: CDVDPlayerVideo::Decode dts:1179978 pts:1180000 cur:1180000, size:22771
                                            11:52:02 T:18446744072754526738    INFO: CDVDPlayerVideo::Decode dts:1199978 pts:1220000 cur:1220000, size:22696
                                            11:52:02 T:18446744072754527309    INFO: CDVDPlayerVideo::Decode dts:1219978 pts:1320000 cur:1320000, size:59286
                                            11:52:02 T:18446744072754527937    INFO: CDVDPlayerVideo::Decode dts:1239978 pts:1280000 cur:1280000, size:34118
                                            11:52:02 T:18446744072754528510    INFO: CDVDPlayerVideo::Decode dts:1259978 pts:1260000 cur:1260000, size:19347
                                            11:52:02 T:18446744072754528967    INFO: CDVDPlayerVideo::Decode dts:1279978 pts:1300000 cur:1300000, size:19724
                                            11:52:02 T:18446744072754529478   DEBUG: COMXAudio::PortSettingsChanged - bits:32 mode:0 channels:2 srate:48000 nopassthrough
                                            11:52:02 T:18446744072754529598    INFO: CDVDPlayerVideo::Decode dts:1299978 pts:1400000 cur:1400000, size:52410
                                            11:52:02 T:18446744072754530353    INFO: CDVDPlayerVideo::Decode dts:1319978 pts:1360000 cur:1360000, size:34922
                                            11:52:02 T:18446744072754530932    INFO: CDVDPlayerVideo::Decode dts:1339978 pts:1340000 cur:1340000, size:19939
                                            11:52:02 T:18446744072754531365    INFO: CDVDPlayerVideo::Decode dts:1359978 pts:1380000 cur:1380000, size:20313
                                            11:52:02 T:18446744072754532419    INFO: CDVDPlayerVideo::Decode dts:1379978 pts:1480000 cur:1480000, size:57283
                                            11:52:02 T:18446744072754533143    INFO: CDVDPlayerVideo::Decode dts:1399978 pts:1440000 cur:1440000, size:36849
                                            11:52:02 T:18446744072754533730    INFO: CDVDPlayerVideo::Decode dts:1419978 pts:1420000 cur:1420000, size:21832
                                            11:52:02 T:18446744072754534664    INFO: CDVDPlayerVideo::Decode dts:1439978 pts:1460000 cur:1460000, size:22125
                                            11:52:02 T:18446744072754535306    INFO: CDVDPlayerVideo::Decode dts:1459978 pts:1560000 cur:1560000, size:60120
                                            11:52:02 T:18446744072754536287    INFO: CDVDPlayerVideo::Decode dts:1479978 pts:1520000 cur:1520000, size:40186
                                            11:52:02 T:18446744072754537186    INFO: CDVDPlayerVideo::Decode dts:1499978 pts:1500000 cur:1500000, size:18653
                                            11:52:02 T:18446744072754538167    INFO: CDVDPlayerVideo::Decode dts:1519978 pts:1540000 cur:1540000, size:19150
                                            11:52:02 T:18446744072754539275    INFO: CDVDPlayerVideo::Decode dts:1539978 pts:1640000 cur:1640000, size:62148
                                            11:52:02 T:18446744072754540425    INFO: CDVDPlayerVideo::Decode dts:1559978 pts:1600000 cur:1600000, size:36130
                                            11:52:02 T:18446744072754541034    INFO: CDVDPlayerVideo::Decode dts:1579978 pts:1580000 cur:1580000, size:25455
                                            11:52:02 T:18446744072754541592    INFO: CDVDPlayerVideo::Decode dts:1599978 pts:1620000 cur:1620000, size:20837
                                            11:52:02 T:18446744072754542309   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.audio_decode - OMX_ErrorInsufficientResources, insufficient resources
                                            11:52:02 T:18446744072754543328    INFO: CDVDPlayerVideo::Decode dts:1619978 pts:1720000 cur:1720000, size:58306
                                            11:52:02 T:18446744072754544626    INFO: CDVDPlayerVideo::Decode dts:1639978 pts:1680000 cur:1680000, size:36670
                                            11:52:02 T:18446744072754545576    INFO: CDVDPlayerVideo::Decode dts:1659978 pts:1660000 cur:1660000, size:27504
                                            11:52:02 T:18446744072754546418    INFO: CDVDPlayerVideo::Decode dts:1679978 pts:1700000 cur:1700000, size:27320
                                            11:52:02 T:18446744072754554347    INFO: CDVDPlayerVideo::Decode dts:1699978 pts:1800000 cur:1800000, size:58452
                                            11:52:02 T:18446744072754555568    INFO: CDVDPlayerVideo::Decode dts:1719978 pts:1760000 cur:1760000, size:39294
                                            11:52:02 T:18446744072754556286    INFO: CDVDPlayerVideo::Decode dts:1739978 pts:1740000 cur:1740000, size:23306
                                            11:52:02 T:18446744072754556955    INFO: CDVDPlayerVideo::Decode dts:1759978 pts:1780000 cur:1780000, size:21371
                                            11:52:02 T:18446744072754557597    INFO: CDVDPlayerVideo::Decode dts:1779978 pts:1820000 cur:1820000, size:77382
                                            11:52:02 T:18446744072754558836    INFO: CDVDPlayerVideo::Decode dts:1799978 pts:1900000 cur:1900000, size:53764
                                            11:52:02 T:18446744072754559861    INFO: CDVDPlayerVideo::Decode dts:1819978 pts:1860000 cur:1860000, size:34809
                                            11:52:02 T:18446744072754560506    INFO: CDVDPlayerVideo::Decode dts:1839978 pts:1840000 cur:1840000, size:20027
                                            11:52:02 T:18446744072754561186    INFO: CDVDPlayerVideo::Decode dts:1859978 pts:1880000 cur:1880000, size:21149
                                            11:52:02 T:18446744072754562100    INFO: CDVDPlayerVideo::Decode dts:1879978 pts:1980000 cur:1980000, size:55266
                                            11:52:02 T:18446744072754562735    INFO: CDVDPlayerVideo::Decode dts:1899978 pts:1940000 cur:1940000, size:35319
                                            11:52:02 T:18446744072754563372    INFO: CDVDPlayerVideo::Decode dts:1919978 pts:1920000 cur:1920000, size:21445
                                            11:52:02 T:18446744072754563904    INFO: CDVDPlayerVideo::Decode dts:1939978 pts:1960000 cur:1960000, size:20460
                                            11:52:02 T:18446744072754564505    INFO: CDVDPlayerVideo::Decode dts:1959978 pts:2060000 cur:2060000, size:59220
                                            11:52:02 T:18446744072754565233    INFO: CDVDPlayerVideo::Decode dts:1979978 pts:2020000 cur:2020000, size:30488
                                            11:52:02 T:18446744072754565902    INFO: CDVDPlayerVideo::Decode dts:1999978 pts:2000000 cur:2000000, size:16162
                                            11:52:02 T:18446744072754566412    INFO: CDVDPlayerVideo::Decode dts:2019978 pts:2040000 cur:2040000, size:17207
                                            11:52:02 T:18446744072754566872    INFO: CDVDPlayerVideo::Decode dts:2039978 pts:2140000 cur:2140000, size:51194
                                            11:52:02 T:18446744072754571047    INFO: CDVDPlayerVideo::Decode dts:2059978 pts:2100000 cur:2100000, size:29320
                                            11:52:02 T:18446744072754572604    INFO: CDVDPlayerVideo::Decode dts:2079978 pts:2080000 cur:2080000, size:16653
                                            11:52:02 T:18446744072754573029    INFO: CDVDPlayerVideo::Decode dts:2099978 pts:2120000 cur:2120000, size:20551
                                            11:52:02 T:18446744072754573458    INFO: CDVDPlayerVideo::Decode dts:2119978 pts:2220000 cur:2220000, size:73307
                                            11:52:02 T:18446744072754574275    INFO: CDVDPlayerVideo::Decode dts:2139978 pts:2180000 cur:2180000, size:29475
                                            11:52:02 T:18446744072754574774    INFO: CDVDPlayerVideo::Decode dts:2159978 pts:2160000 cur:2160000, size:17045
                                            11:52:02 T:18446744072754575155    INFO: CDVDPlayerVideo::Decode dts:2179978 pts:2200000 cur:2200000, size:17053
                                            11:52:02 T:18446744072754575579    INFO: CDVDPlayerVideo::Decode dts:2199978 pts:2300000 cur:2300000, size:55457
                                            11:52:02 T:18446744072754576343    INFO: CDVDPlayerVideo::Decode dts:2219978 pts:2260000 cur:2260000, size:29357
                                            11:52:02 T:18446744072754576825    INFO: CDVDPlayerVideo::Decode dts:2239978 pts:2240000 cur:2240000, size:16611
                                            11:52:02 T:18446744072754577188    INFO: CDVDPlayerVideo::Decode dts:2259978 pts:2280000 cur:2280000, size:17411
                                            11:52:02 T:18446744072754577572    INFO: CDVDPlayerVideo::Decode dts:2279978 pts:2380000 cur:2380000, size:52161
                                            11:52:02 T:18446744072754578129    INFO: CDVDPlayerVideo::Decode dts:2299978 pts:2340000 cur:2340000, size:29740
                                            11:52:02 T:18446744072754578601    INFO: CDVDPlayerVideo::Decode dts:2319978 pts:2320000 cur:2320000, size:19979
                                            11:52:02 T:18446744072754579143    INFO: CDVDPlayerVideo::Decode dts:2339978 pts:2360000 cur:2360000, size:16378
                                            11:52:02 T:18446744072754579548    INFO: CDVDPlayerVideo::Decode dts:2359978 pts:2460000 cur:2460000, size:60321
                                            11:52:02 T:18446744072754580295    INFO: CDVDPlayerVideo::Decode dts:2379978 pts:2420000 cur:2420000, size:35591
                                            11:52:02 T:18446744072754580808    INFO: CDVDPlayerVideo::Decode dts:2399978 pts:2400000 cur:2400000, size:21597
                                            11:52:02 T:18446744072754581226    INFO: CDVDPlayerVideo::Decode dts:2419978 pts:2440000 cur:2440000, size:21746
                                            11:52:02 T:18446744072754582316    INFO: CDVDPlayerVideo::Decode dts:2439978 pts:2480000 cur:2480000, size:99011
                                            11:52:02 T:18446744072754583425    INFO: CDVDPlayerVideo::Decode dts:2459978 pts:2560000 cur:2560000, size:71080
                                            11:52:02 T:18446744072754584093    INFO: CDVDPlayerVideo::Decode dts:2479978 pts:2520000 cur:2520000, size:43871
                                            11:52:02 T:18446744072754584606    INFO: CDVDPlayerVideo::Decode dts:2499978 pts:2500000 cur:2500000, size:17682
                                            11:52:02 T:18446744072754584974    INFO: CDVDPlayerVideo::Decode dts:2519978 pts:2540000 cur:2540000, size:17928
                                            11:52:02 T:18446744072754585329    INFO: CDVDPlayerVideo::Decode dts:2539978 pts:2640000 cur:2640000, size:53824
                                            11:52:02 T:18446744072754585890    INFO: CDVDPlayerVideo::Decode dts:2559978 pts:2600000 cur:2600000, size:30944
                                            11:52:02 T:18446744072754586292    INFO: CDVDPlayerVideo::Decode dts:2579978 pts:2580000 cur:2580000, size:18211
                                            11:52:02 T:18446744072754586662    INFO: CDVDPlayerVideo::Decode dts:2599978 pts:2620000 cur:2620000, size:17724
                                            11:52:02 T:18446744072754587039    INFO: CDVDPlayerVideo::Decode dts:2619978 pts:2720000 cur:2720000, size:63718
                                            11:52:02 T:18446744072754587824    INFO: CDVDPlayerVideo::Decode dts:2639978 pts:2680000 cur:2680000, size:37042
                                            11:52:02 T:18446744072754588438    INFO: CDVDPlayerVideo::Decode dts:2659978 pts:2660000 cur:2660000, size:21339
                                            11:52:02 T:18446744072754588895    INFO: CDVDPlayerVideo::Decode dts:2679978 pts:2700000 cur:2700000, size:15947
                                            11:52:02 T:18446744072754589273    INFO: CDVDPlayerVideo::Decode dts:2699978 pts:2800000 cur:2800000, size:48633
                                            11:52:02 T:18446744072754620090    INFO: CDVDPlayerVideo::Decode dts:2719978 pts:2760000 cur:2760000, size:27974
                                            11:52:02 T:18446744072754620819    INFO: CDVDPlayerVideo::Decode dts:2739978 pts:2740000 cur:2740000, size:11853
                                            11:52:02 T:18446744072754621427    INFO: CDVDPlayerVideo::Decode dts:2759978 pts:2780000 cur:2780000, size:11740
                                            11:52:02 T:18446744072754632560    INFO: CDVDPlayerVideo::Decode dts:2779978 pts:2880000 cur:2880000, size:66130
                                            11:52:02 T:18446744072754633306    INFO: CDVDPlayerVideo::Decode dts:2799978 pts:2840000 cur:2840000, size:33760
                                            11:52:02 T:18446744072754654067    INFO: CDVDPlayerVideo::Decode dts:2819978 pts:2820000 cur:2820000, size:17500
                                            11:52:02 T:18446744072754655142    INFO: CDVDPlayerVideo::Decode dts:2839978 pts:2860000 cur:2860000, size:15348
                                            11:52:02 T:18446744072754655705    INFO: CDVDPlayerVideo::Decode dts:2859978 pts:2960000 cur:2960000, size:72718
                                            11:52:02 T:18446744072754666553    INFO: CDVDPlayerVideo::Decode dts:2879978 pts:2920000 cur:2920000, size:28342
                                            11:52:02 T:18446744072754689129    INFO: CDVDPlayerVideo::Decode dts:2899978 pts:2900000 cur:2900000, size:15326
                                            11:52:02 T:18446744072754690107    INFO: CDVDPlayerVideo::Decode dts:2919978 pts:2940000 cur:2940000, size:17144
                                            11:52:02 T:18446744072754690828    INFO: CDVDPlayerVideo::Decode dts:2939978 pts:3040000 cur:3040000, size:61126
                                            11:52:02 T:18446744072754723108    INFO: CDVDPlayerVideo::Decode dts:2959978 pts:3000000 cur:3000000, size:29458
                                            11:52:02 T:18446744072754726792   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_render input port 90 output port 90 m_handle 0x6df005d0
                                            11:52:02 T:18446744072754726930   DEBUG: COMXVideo::PortSettingsChangedLogger - 1280x720@50.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                            11:52:02 T:18446744072754730242   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_scheduler input port 10 output port 11 m_handle 0x6df006e0
                                            11:52:02 T:18446744072754740320    INFO: CDVDPlayerVideo::Decode dts:2979978 pts:2980000 cur:2980000, size:16106
                                            11:52:02 T:18446744072754741709    INFO: CDVDPlayerVideo::Decode dts:2999978 pts:3020000 cur:3020000, size:16905
                                            11:52:02 T:18446744072754742906    INFO: CDVDPlayerVideo::Decode dts:3019978 pts:3120000 cur:3120000, size:47597
                                            11:52:02 T:18446744072754743888    INFO: CDVDPlayerVideo::Decode dts:3039978 pts:3080000 cur:3080000, size:27772
                                            11:52:02 T:18446744072754756172    INFO: CDVDPlayerVideo::Decode dts:3059978 pts:3060000 cur:3060000, size:16047
                                            11:52:02 T:18446744072754757372    INFO: CDVDPlayerVideo::Decode dts:3079978 pts:3100000 cur:3100000, size:23222
                                            11:52:02 T:18446744072754779147    INFO: CDVDPlayerVideo::Decode dts:3099978 pts:3140000 cur:3140000, size:111109
                                            11:52:02 T:18446744072754791345    INFO: CDVDPlayerVideo::Decode dts:3119978 pts:3220000 cur:3220000, size:68499
                                            11:52:02 T:18446744072754793039    INFO: CDVDPlayerVideo::Decode dts:3139978 pts:3180000 cur:3180000, size:39854
                                            11:52:02 T:18446744072754793921    INFO: CDVDPlayerVideo::Decode dts:3159978 pts:3160000 cur:3160000, size:19475
                                            11:52:02 T:18446744072754795805    INFO: CDVDPlayerVideo::Decode dts:3179978 pts:3200000 cur:3200000, size:21175
                                            11:52:04 T:18446744072756530949   ERROR: COMXCoreComponent::WaitForCommand OMX.broadcom.audio_mixer wait timeout event.eEvent 0x00000000 event.command 0x00000000 event.nData2 2
                                            11:52:04 T:18446744072756531115   ERROR: COMXCoreComponent::WaitForCommand - OMX.broadcom.audio_mixer failed with omx_err(0x80001011)
                                            11:52:04 T:18446744072756531149   ERROR: COMXCoreComponent::Establish - Error setting state to idle OMX.broadcom.audio_decode omx_err(0x80001011)
                                            11:52:04 T:18446744072756531175   ERROR: COMXAudio::PortSettingsChanged - m_omx_tunnel_decoder.Establish omx_err(0x80001011)
                                            11:52:04 T:18446744072756531200   ERROR: COMXAudio::AddPackets - error PortSettingsChanged omx_err(0x00000000)
                                            11:52:04 T:18446744072756531370    INFO: COMXAudio::ApplyVolume - Volume=1.00 (* 1.00 * 1.00)
                                            11:52:04 T:18446744072756531426    INFO: CDVDPlayerAudio::Decode dts:293734 pts:293734 size:768
                                            11:52:04 T:18446744072756531529   DEBUG: Normal M:0 (A:269734 V:980000) P:1 A:0.27 V:0.98/T:0.20 (0,0,1,1) A:2% V:41% (0.10,6.07)
                                            11:52:04 T:18446744072756531636   DEBUG: Resume 0.27,0.98 (0,0,1,1) EOF:0 PKT:(nil)
                                            11:52:04 T:18446744072756531665   DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
                                            11:52:04 T:18446744072756531811    INFO: CDVDPlayerAudio::Decode dts:317734 pts:317734 size:768
                                            11:52:04 T:18446744072756532071    INFO: CDVDPlayerAudio::Decode dts:341734 pts:341734 size:782
                                            11:52:04 T:18446744072756532349    INFO: CDVDPlayerAudio::Decode dts:365734 pts:365734 size:768
                                            11:52:04 T:18446744072756532653    INFO: CDVDPlayerAudio::Decode dts:389734 pts:389734 size:768
                                            11:52:04 T:18446744072756532721   DEBUG: Normal M:0 (A:365734 V:3300000) P:0 A:0.37 V:3.30/T:0.20 (0,0,1,1) A:2% V:2% (0.10,6.07)
                                            11:52:04 T:18446744072756532941    INFO: CDVDPlayerAudio::Decode dts:413734 pts:413734 size:768
                                            11:52:04 T:18446744072756533222    INFO: CDVDPlayerAudio::Decode dts:437734 pts:437734 size:768
                                            11:52:04 T:18446744072756533506   ERROR: COMXAudio::Decode timeout
                                            11:52:04 T:18446744072756533602    INFO: CDVDPlayerAudio::Decode dts:461734 pts:461734 size:782
                                            11:52:04 T:18446744072756533956    INFO: CDVDPlayerAudio::Decode dts:485734 pts:485734 size:768
                                            11:52:04 T:18446744072756534407    INFO: CDVDPlayerAudio::Decode dts:509734 pts:509734 size:768
                                            11:52:04 T:18446744072756534711    INFO: CDVDPlayerAudio::Decode dts:533734 pts:533734 size:768
                                            11:52:04 T:18446744072756535036    INFO: CDVDPlayerAudio::Decode dts:557734 pts:557734 size:768
                                            11:52:04 T:18446744072756535328    INFO: CDVDPlayerAudio::Decode dts:581734 pts:581734 size:782
                                            11:52:04 T:18446744072756535738    INFO: CDVDPlayerAudio::Decode dts:605734 pts:605734 size:768
                                            11:52:04 T:18446744072756536464   ERROR: COMXAudio::Decode timeout
                                            11:52:04 T:18446744072756536717    INFO: CDVDPlayerAudio::Decode dts:629734 pts:629734 size:768
                                            11:52:04 T:18446744072756537743    INFO: CDVDPlayerAudio::Decode dts:653734 pts:653734 size:768
                                            11:52:04 T:18446744072756538317    INFO: CDVDPlayerAudio::Decode dts:677734 pts:677734 size:768
                                            11:52:04 T:18446744072756538868    INFO: CDVDPlayerAudio::Decode dts:701734 pts:701734 size:782
                                            11:52:04 T:18446744072756539324    INFO: CDVDPlayerAudio::Decode dts:725734 pts:725734 size:768
                                            11:52:04 T:18446744072756539682    INFO: CDVDPlayerAudio::Decode dts:749734 pts:749734 size:768
                                            11:52:04 T:18446744072756540051    INFO: CDVDPlayerAudio::Decode dts:773734 pts:773734 size:768
                                            11:52:04 T:18446744072756540417   ERROR: COMXAudio::Decode timeout
                                            11:52:04 T:18446744072756540483    INFO: CDVDPlayerAudio::Decode dts:797734 pts:797734 size:768
                                            11:52:04 T:18446744072756540817    INFO: CDVDPlayerAudio::Decode dts:821734 pts:821734 size:782
                                            11:52:04 T:18446744072756541161    INFO: CDVDPlayerAudio::Decode dts:845734 pts:845734 size:768
                                            11:52:04 T:18446744072756541530    INFO: CDVDPlayerAudio::Decode dts:869734 pts:869734 size:768
                                            11:52:04 T:18446744072756542004    INFO: CDVDPlayerAudio::Decode dts:893734 pts:893734 size:768
                                            11:52:04 T:18446744072756542514    INFO: CDVDPlayerAudio::Decode dts:917734 pts:917734 size:768
                                            11:52:04 T:18446744072756542981    INFO: CDVDPlayerAudio::Decode dts:941734 pts:941734 size:782
                                            11:52:04 T:18446744072756543354   ERROR: COMXAudio::Decode timeout
                                            Thx in advance,
                                            Marco
                                            • 7 / 8
