    Blank Screen on Pi 1 after successful Install
    21 Posts 7 Posters 19.6k Views 7 Watching
      pagoa
      Have you tried accessing the MM-interface on an other device? So if you enter “http://IP_OF_YOUR_PI:8080” in the browser of your computer for instance, does it work? I had a similar problem, where the interface only worked on other devices…
      But you know that electron is not working on the RPi 1 right? So you will probably have a hard time trying to get this to work yourself on a Pi1…
        BenRoe Module Developer
        @bharathvenkat i use MM with node serveronly and a Midori Browser on my Raspberry PI B. Theoretically it should work on your RPi. Like Mr.Meeseeks (btw rick and morty is awesome) proposed, open the developer console in the browser and check if there is some code.
        @pagoa he is using node serveronly. With this command electron is not used.
          chase
          I’m also having this issue. I was getting the intro/setup your config screen. I got the donfig setup and wrestled with file permissions to get it copied. Relaunched and now I’ve got a black screen. The source of the page has the Magic Mirror stuff in it. Don’t know what’s wrong. Any advice?
          M 1 Reply Last reply
            Mr.Meeseeks @chase
            @chase what pi version? Are you running it in server mode? Any JavaScript errors in console? What browser?
            CAAAAN DOO!👍
              chase
              I’m using an original model A. It is running in server mode, no javascript errors besides one below the don’t edit line in the config file. Any browser. Tried from multiple devices including the Pi itself. Thanks!
                Which node.js Version is installed? Maybe this is the problem.
                  chase
                  v0.10.29
                    Try a newer node version.
                    Here is a blog post (unfortunately  in german) how to install the latest version. Deinstall the node before you install the newer version.
                    http://www.benjaminroesner.com/blog/node-js-raspberry-pi-installieren/#variante2
                      chase
                      Thanks for the blog post! I’m now on 4.2.1, but I’m still getting a black screen after a boot. Here’s a picture from chrome. I would attach a picture of the actual thing, but it’s a monitor with a black screen. Screens
                      I really appreciate all the help
                        Should the url contain the port? 192.168.0.7:8080?
                          chase
                          Just got back home and gave that a shot. I get a refused to connect error there.
                          B 1 Reply Last reply
                            BenRoe Module Developer @chase
                            Maybe i found the problem. I am working on a FHEM module for MM. I changed the config.js and had a wrong module name in it. After reload the screen was black.
                            @chase please check your config.js for spelling or json format errors.
                              chase
                              I’ll give it a look over. Also just for reference I followed this tutorial to set it up https://www.reddit.com/r/raspberry_pi/comments/3oktfu/magic_mirror_how_to/
                                chase
                                I couldn’t find anything, but I did find something strange. I pulled my config file out and once again got the please setup your file screen. So I made a copy config file and replaced it’s contents with the sample config file code and reuploaded it. Black screen again. Should that have shown something?
                                  bhepler Module Developer @chase
                                  @chase Yes. The sample config file should at least show you the clock and the basic compliments. If you update it with your openweathermap key it should show you weather. Curious.
                                  Also, yes the URL should contain the 8080 port.
                                  MichMich usually recommends this tutorial: Complete Setup Tutorial
                                  • K
                                    Kisaua
                                    I have the same issue. it seems that information is out of range in Midori. Chromium shows everything on the left side.
                                    Iceweasel works fine. No ideas how to run in full screen mode.
                                    kweb - black window, nothing.
                                    From other devices in network works fine.
                                      @Kisaua i have the mirror running on a RPi B with Fullscreen Midori. Check your Node version and Midori version.
                                      Here is a Midori autostart tutorial with kiosk mode. http://www.benjaminroesner.com/blog/autostart-midori-browser-vollbild-kiosk-mode-via-konsole-ohne-desktop/
                                      • K
                                        Kisaua
                                        node v.4.2.1 and i have tried with node v.6.7.0
                                        Midori 0.4.3
                                        • K
                                          Kisaua
                                          Now works fine with iceweasel (Firefox) with plugin R-kiosk plugin.
