    Blank Screen on Pi 1 after successful Install
    21 Posts 7 Posters 19.6k Views 7 Watching
      BenRoe Module Developer
      Which node.js Version is installed? Maybe this is the problem.
        chase
        v0.10.29
          Try a newer node version.
          Here is a blog post (unfortunately  in german) how to install the latest version. Deinstall the node before you install the newer version.
          http://www.benjaminroesner.com/blog/node-js-raspberry-pi-installieren/#variante2
            chase
            Thanks for the blog post! I’m now on 4.2.1, but I’m still getting a black screen after a boot. Here’s a picture from chrome. I would attach a picture of the actual thing, but it’s a monitor with a black screen. Screens
            I really appreciate all the help
              Should the url contain the port? 192.168.0.7:8080?
                chase
                Just got back home and gave that a shot. I get a refused to connect error there.
                B 1 Reply Last reply
                  BenRoe Module Developer @chase
                  Maybe i found the problem. I am working on a FHEM module for MM. I changed the config.js and had a wrong module name in it. After reload the screen was black.
                  @chase please check your config.js for spelling or json format errors.
                    chase
                    I’ll give it a look over. Also just for reference I followed this tutorial to set it up https://www.reddit.com/r/raspberry_pi/comments/3oktfu/magic_mirror_how_to/
                      chase
                      I couldn’t find anything, but I did find something strange. I pulled my config file out and once again got the please setup your file screen. So I made a copy config file and replaced it’s contents with the sample config file code and reuploaded it. Black screen again. Should that have shown something?
                        bhepler Module Developer @chase
                        @chase Yes. The sample config file should at least show you the clock and the basic compliments. If you update it with your openweathermap key it should show you weather. Curious.
                        Also, yes the URL should contain the 8080 port.
                        MichMich usually recommends this tutorial: Complete Setup Tutorial
                        • K
                          Kisaua
                          I have the same issue. it seems that information is out of range in Midori. Chromium shows everything on the left side.
                          Iceweasel works fine. No ideas how to run in full screen mode.
                          kweb - black window, nothing.
                          From other devices in network works fine.
                            @Kisaua i have the mirror running on a RPi B with Fullscreen Midori. Check your Node version and Midori version.
                            Here is a Midori autostart tutorial with kiosk mode. http://www.benjaminroesner.com/blog/autostart-midori-browser-vollbild-kiosk-mode-via-konsole-ohne-desktop/
                            • K
                              Kisaua
                              node v.4.2.1 and i have tried with node v.6.7.0
                              Midori 0.4.3
                              • K
                                Kisaua
                                Now works fine with iceweasel (Firefox) with plugin R-kiosk plugin.
