    node serveronly
    3 Posts 2 Posters 1.9k Views 2 Watching
      robiv8
      When I start with this “node serveronly” I become this:
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/Release/epoll.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 57. This version of Node.js requires
      NODE_MODULE_VERSION 59. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install).
      How to fix this?
      • cowboysdudeC Offline
        @robiv8 said in node serveronly:
        Tells me that you have a possible error in your config.js file…start there ;)
          robiv8
          The config.js seems to be OK
          My MM works fine with pm2 start mm,
          I just wanted to test it in server mode. And that’s just what it looks like!
