    MMM-MealViewer
    48 Posts 6 Posters 29.6k Views 6 Watching
      @cowboysdude
      • cowboysdudeC Offline
        • K Offline
          kazanjig
          .@cowboysdude was exceptionally helpful last night.
          thumbs up
            Behave boys! Lol
              cowboysdude Module Developer @sdetweil
              @sdetweil said in MMM-MealViewer:
              Behave boys! Lol
              Behave boys! Lol
              We try VERY hard LOL
              • K Offline
                kazanjig
                But now I seem to have gotten myself into a pickle. I tried expanding the functionality to add a date range and multiple schools and, of course, I broke it. It’s doing the same thing as before where the ‘cafeteriaLineList’ property is stripped out of the helper results…
                EDIT:
                LOL, it’s the weekend and I had it pulling just for today, Sunday. Of course there’s no data. Dumb da dumb dumb…
                  @kazanjig said in MMM-MealViewer:
                  cafeteriaLineList
                  Probably not stripped out just buried like many of the other things were LOL If you don’t get it we can look at it later if you want.
                  S K 2 Replies Last reply Reply Quote 0
                    sdetweil @cowboysdude
                    @cowboysdude you did convert the XML to json, right?
                      @sdetweil Yes I did … it’s all coming back as json but it has a TON of data…
                      • K Offline
                        kazanjig @cowboysdude
                        MAJOR EDIT, MAJOR DUMMIE: helps if you append the rows to the table… Success! Now for some CSS.
                        @cowboysdude I edited my earlier post… minor detail about it being the weekend and not being able to pull lunch data for a day with no school. Now just having getting the data to show up in the table…
                        It will display the “loading” message, but then it’s blank when this.loaded = true. I outputted the innerHTML values to console and they’re all there. Not sure why they won’t show up in the DOM.
                          getDom: function() {
                            // Set up the local wrapper
                            var wrapper = null;
                            // If we have some data to display then build the results table
                            if (this.loaded) {
                              wrapper = document.createElement("table");
                              // Iterate through the schools
                              for (var i = 0; i < this.results.length; i++) {
                                // Set up header row with the school name
                                schoolRow = document.createElement("tr");
                                schoolName = document.createElement("td");
                                schoolName.innerHTML = this.results[i].physicalLocation.name;
                                schoolRow.appendChild(schoolName);
                                // Iterate through the cafeteria lines for the school
                                for (var j = 0; j < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data.length; j++) {
                                  // Set up header row with the cafeteria line name
                                  cafeteriaLineRow = document.createElement("tr");
                                  cafeteriaLineName = document.createElement("td");
                                  cafeteriaLineName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name;
                                  cafeteriaLineRow.appendChild(cafeteriaLineName);
                                  // Iterate through the menu items for the cafeteria line
                                  for (var k = 0; k < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data.length; k++) {
                                    foodItemRow = document.createElement("tr");
                                    foodItemType = document.createElement("td");
                                    foodItemType.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Type;
                                    foodItemName = document.createElement("td");
                                    foodItemName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Name;
                                    foodItemRow.appendChild(foodItemType);
                                    foodItemRow.appendChild(foodItemName);
                            else {
                              // Otherwise lets just use a simple div
                              wrapper = document.createElement('div');
                              wrapper.innerHTML = 'Loading menu data...';
                            return wrapper;
                        • 1 / 5
