    MMM-MealViewer
    48 Posts 6 Posters 34.1k Views 6 Watching
    • K Offline
      kazanjig
      I’m trying to develop a module to get today’s school lunch menu options from my kids’ school. The district uses a service provided by mealviewer.com. The API is available at https://api.mealviewer.com/api/v4/school/[schoolname]/[date range start MM-DD-YYYY]/[date range end MM-DD-YYYY]/. To keep it simple I’m only pulling the current day so the start and end date values are the same.
      Here’s an example: https://api.mealviewer.com/api/v4/school/ElmwoodElementary/02-15-2019/02-15-2019/
      You can see that there is a TON of XML data returned. I’m only interested in the [CafeteriaLine] nodes and each of their respective [FoodItem] nodes and then the respective [Item_Type] and [Item_Name] for each [FoodItem].
      I’m able to send an HTTP request and get (some) data but, unfortunately, most of the nonsense is returned and I don’t see the menu information. It’s like a big chunk out of the middle of the XML data is missing, whether I dump it out to the log before or after parsing it to JSON.
      Any thoughts?
      • cowboysdudeC Offline
        Happy to help… when you have time we can chat.
          @cowboysdude said in MMM-MealViewer:
          You are in danger of getting a reputation for being a nice guy. ;-)
            @mykle1 said in MMM-MealViewer:
              @cowboysdude
                • K Offline
                  kazanjig
                  .@cowboysdude was exceptionally helpful last night.
                  thumbs up
                    Behave boys! Lol
                      cowboysdude Module Developer @sdetweil
                      @sdetweil said in MMM-MealViewer:
                      Behave boys! Lol
                      Behave boys! Lol
                      We try VERY hard LOL
                      • K Offline
                        kazanjig
                        But now I seem to have gotten myself into a pickle. I tried expanding the functionality to add a date range and multiple schools and, of course, I broke it. It’s doing the same thing as before where the ‘cafeteriaLineList’ property is stripped out of the helper results…
                        EDIT:
                        LOL, it’s the weekend and I had it pulling just for today, Sunday. Of course there’s no data. Dumb da dumb dumb…
                          @kazanjig said in MMM-MealViewer:
                          cafeteriaLineList
                          Probably not stripped out just buried like many of the other things were LOL If you don’t get it we can look at it later if you want.
                          S K 2 Replies Last reply Reply Quote 0
                            sdetweil @cowboysdude
                            @cowboysdude you did convert the XML to json, right?
                              @sdetweil Yes I did … it’s all coming back as json but it has a TON of data…
                              • K Offline
                                kazanjig @cowboysdude
                                MAJOR EDIT, MAJOR DUMMIE: helps if you append the rows to the table… Success! Now for some CSS.
                                @cowboysdude I edited my earlier post… minor detail about it being the weekend and not being able to pull lunch data for a day with no school. Now just having getting the data to show up in the table…
                                It will display the “loading” message, but then it’s blank when this.loaded = true. I outputted the innerHTML values to console and they’re all there. Not sure why they won’t show up in the DOM.
                                  getDom: function() {
                                    // Set up the local wrapper
                                    var wrapper = null;
                                    // If we have some data to display then build the results table
                                    if (this.loaded) {
                                      wrapper = document.createElement("table");
                                      // Iterate through the schools
                                      for (var i = 0; i < this.results.length; i++) {
                                        // Set up header row with the school name
                                        schoolRow = document.createElement("tr");
                                        schoolName = document.createElement("td");
                                        schoolName.innerHTML = this.results[i].physicalLocation.name;
                                        schoolRow.appendChild(schoolName);
                                        // Iterate through the cafeteria lines for the school
                                        for (var j = 0; j < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data.length; j++) {
                                          // Set up header row with the cafeteria line name
                                          cafeteriaLineRow = document.createElement("tr");
                                          cafeteriaLineName = document.createElement("td");
                                          cafeteriaLineName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name;
                                          cafeteriaLineRow.appendChild(cafeteriaLineName);
                                          // Iterate through the menu items for the cafeteria line
                                          for (var k = 0; k < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data.length; k++) {
                                            foodItemRow = document.createElement("tr");
                                            foodItemType = document.createElement("td");
                                            foodItemType.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Type;
                                            foodItemName = document.createElement("td");
                                            foodItemName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Name;
                                            foodItemRow.appendChild(foodItemType);
                                            foodItemRow.appendChild(foodItemName);
                                    else {
                                      // Otherwise lets just use a simple div
                                      wrapper = document.createElement('div');
                                      wrapper.innerHTML = 'Loading menu data...';
                                    return wrapper;
                                • K Offline
                                  kazanjig
                                  So I now get the following table:
                                  Elementary Lunch
                                  Entree “Bold” Cheese Pizza
                                  Entree “Bold” Pepperoni Pizza
                                  Vegetable Parmesan Butternut Gratin
                                  Vegetable Seasoned Green Beans
                                  Elementary Alternative
                                  Entree Chef Salad
                                  Entree Bologna & Cheese Sandwich
                                  The foodItemType in the first column and the foodItemName in the second column are siblings in the data array.
                                  I’d like turn the first occurrence of foodItemType into a category so the table looks like this (ignore the spacing hyphens):
                                  Elementary Lunch
                                  --------------“Bold” Pepperoni Pizza
                                  -------------------Seasoned Green Beans
                                  Entree Chef Salad
                                  -------------Bologna & Cheese Sandwich
                                  Here’s the current loop that creates the table. Any help would be appreciated.
                                            if (this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name !== 'Elmwood Vegetarian Hot Entree') {
                                              cafeteriaLineName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name.replace("Elmwood Elementary", "Elementary Lunch").replace("Elmwood Alternative", "Elementary Alternative");
                                              wrapper.appendChild(cafeteriaLineRow);
                                                if (this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Name !== 'Choice Of:') {
                                                  foodItemTypeRow = documen t.createElement("tr");
                                                  foodItemTypeRow.appendChild(foodItemType);
                                                  wrapper.appendChild(foodItemTypeRow);
                                                  foodItemTypeRow.appendChild(foodItemName);
                                  G 1 Reply Last reply Reply Quote 1
                                  • G Offline
                                    gonzonia @kazanjig
                                    @kazanjig I know this post is old, but I’m trying to accomplish this in a different way. I was trying to do it with PHP instead and the XML coming back from the Mealviewer API isn’t recognized but when I load it directly in my browser all looks good. Would you be willing to share all the code you’re using to load this? I’m not as familiar with how the MM code works and how you’re plugging this into the whole thing. My implementation is just a shared home calendar view that I rolled myself (I may have to look into implementing MM though now that I’ve stumbled upon all this).
                                      cowboysdude Module Developer @gonzonia
                                      @gonzonia PHP won’t work in this software. If he doesn’t answer you I will be happy to help you get this going…
                                      • G Offline
                                        gonzonia @cowboysdude
                                        @cowboysdude Thanks. I’m happy to use a JS implementation as well. The family calendar I created is just hitting a wordpress site I’m hosting on a mac mini. PHP was just so that it could load pre-render but the main thing is just to get the meal list populated on the calendar screen instead of having a separate tab open in the browser. I haven’t had a lot of time to try to look into this or switching to MM. I hate to be hijacking a MM thread but this is literally the only discussion I’ve found of anyone accessing the MealViewer data like this.
                                        • G Offline
                                          gonzonia
                                          • G Offline
                                            gonzonia @gonzonia
