    MMM-MealViewer
    48 Posts 6 Posters 35.4k Views 6 Watching
    • Mykle1M
      @cowboysdude said in MMM-MealViewer:
      Happy to help… when you have time we can chat.
      You are in danger of getting a reputation for being a nice guy. ;-)
      • cowboysdudeC
        @mykle1 said in MMM-MealViewer:
        • Mykle1M
          @cowboysdude
          • cowboysdudeC
            • K
              kazanjig
              .@cowboysdude was exceptionally helpful last night.
              thumbs up
                Behave boys! Lol
                • cowboysdudeC
                  cowboysdude Module Developer @sdetweil
                  @sdetweil said in MMM-MealViewer:
                  Behave boys! Lol
                  Behave boys! Lol
                  We try VERY hard LOL
                  • K
                    kazanjig
                    But now I seem to have gotten myself into a pickle. I tried expanding the functionality to add a date range and multiple schools and, of course, I broke it. It’s doing the same thing as before where the ‘cafeteriaLineList’ property is stripped out of the helper results…
                    EDIT:
                    LOL, it’s the weekend and I had it pulling just for today, Sunday. Of course there’s no data. Dumb da dumb dumb…
                    • cowboysdudeC
                      @kazanjig said in MMM-MealViewer:
                      cafeteriaLineList
                      Probably not stripped out just buried like many of the other things were LOL If you don’t get it we can look at it later if you want.
                      S K 2 Replies Last reply Reply Quote 0
                        sdetweil @cowboysdude
                        @cowboysdude you did convert the XML to json, right?
                        • cowboysdudeC
                          @sdetweil Yes I did … it’s all coming back as json but it has a TON of data…
                          • K
                            kazanjig @cowboysdude
                            MAJOR EDIT, MAJOR DUMMIE: helps if you append the rows to the table… Success! Now for some CSS.
                            @cowboysdude I edited my earlier post… minor detail about it being the weekend and not being able to pull lunch data for a day with no school. Now just having getting the data to show up in the table…
                            It will display the “loading” message, but then it’s blank when this.loaded = true. I outputted the innerHTML values to console and they’re all there. Not sure why they won’t show up in the DOM.
                              getDom: function() {
                                // Set up the local wrapper
                                var wrapper = null;
                                // If we have some data to display then build the results table
                                if (this.loaded) {
                                  wrapper = document.createElement("table");
                                  // Iterate through the schools
                                  for (var i = 0; i < this.results.length; i++) {
                                    // Set up header row with the school name
                                    schoolRow = document.createElement("tr");
                                    schoolName = document.createElement("td");
                                    schoolName.innerHTML = this.results[i].physicalLocation.name;
                                    schoolRow.appendChild(schoolName);
                                    // Iterate through the cafeteria lines for the school
                                    for (var j = 0; j < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data.length; j++) {
                                      // Set up header row with the cafeteria line name
                                      cafeteriaLineRow = document.createElement("tr");
                                      cafeteriaLineName = document.createElement("td");
                                      cafeteriaLineName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name;
                                      cafeteriaLineRow.appendChild(cafeteriaLineName);
                                      // Iterate through the menu items for the cafeteria line
                                      for (var k = 0; k < this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data.length; k++) {
                                        foodItemRow = document.createElement("tr");
                                        foodItemType = document.createElement("td");
                                        foodItemType.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Type;
                                        foodItemName = document.createElement("td");
                                        foodItemName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Name;
                                        foodItemRow.appendChild(foodItemType);
                                        foodItemRow.appendChild(foodItemName);
                                else {
                                  // Otherwise lets just use a simple div
                                  wrapper = document.createElement('div');
                                  wrapper.innerHTML = 'Loading menu data...';
                                return wrapper;
                            • K
                              kazanjig
                              So I now get the following table:
                              Elementary Lunch
                              Entree “Bold” Cheese Pizza
                              Entree “Bold” Pepperoni Pizza
                              Vegetable Parmesan Butternut Gratin
                              Vegetable Seasoned Green Beans
                              Elementary Alternative
                              Entree Chef Salad
                              Entree Bologna & Cheese Sandwich
                              The foodItemType in the first column and the foodItemName in the second column are siblings in the data array.
                              I’d like turn the first occurrence of foodItemType into a category so the table looks like this (ignore the spacing hyphens):
                              Elementary Lunch
                              --------------“Bold” Pepperoni Pizza
                              -------------------Seasoned Green Beans
                              Entree Chef Salad
                              -------------Bologna & Cheese Sandwich
                              Here’s the current loop that creates the table. Any help would be appreciated.
                                        if (this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name !== 'Elmwood Vegetarian Hot Entree') {
                                          cafeteriaLineName.innerHTML = this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].name.replace("Elmwood Elementary", "Elementary Lunch").replace("Elmwood Alternative", "Elementary Alternative");
                                          wrapper.appendChild(cafeteriaLineRow);
                                            if (this.results[i].menuSchedules[0].menuBlocks[0].cafeteriaLineList.data[j].foodItemList.data[k].item_Name !== 'Choice Of:') {
                                              foodItemTypeRow = documen t.createElement("tr");
                                              foodItemTypeRow.appendChild(foodItemType);
                                              wrapper.appendChild(foodItemTypeRow);
                                              foodItemTypeRow.appendChild(foodItemName);
                              G 1 Reply Last reply Reply Quote 1
                              • G
                                gonzonia @kazanjig
                                @kazanjig I know this post is old, but I’m trying to accomplish this in a different way. I was trying to do it with PHP instead and the XML coming back from the Mealviewer API isn’t recognized but when I load it directly in my browser all looks good. Would you be willing to share all the code you’re using to load this? I’m not as familiar with how the MM code works and how you’re plugging this into the whole thing. My implementation is just a shared home calendar view that I rolled myself (I may have to look into implementing MM though now that I’ve stumbled upon all this).
                                • cowboysdudeC
                                  cowboysdude Module Developer @gonzonia
                                  @gonzonia PHP won’t work in this software. If he doesn’t answer you I will be happy to help you get this going…
                                  • G
                                    gonzonia @cowboysdude
                                    @cowboysdude Thanks. I’m happy to use a JS implementation as well. The family calendar I created is just hitting a wordpress site I’m hosting on a mac mini. PHP was just so that it could load pre-render but the main thing is just to get the meal list populated on the calendar screen instead of having a separate tab open in the browser. I haven’t had a lot of time to try to look into this or switching to MM. I hate to be hijacking a MM thread but this is literally the only discussion I’ve found of anyone accessing the MealViewer data like this.
                                    • G
                                      gonzonia
                                      • G
                                        gonzonia @gonzonia
                                        • G
                                          gonzonia
                                          Okay. I’ve decided to build a MagicMirror to replace my homegrown and now I’m trying to implement this module. I’ve downloaded the repository for this from GitHub and ran npm install.
                                          I’ve added some config info to set the school and position. It’s showing breakfast and “Tomorrow’s Undefined”. I’d like it to show lunch. Help?
                                            Open the developers window, ctrl-shift-i on the keyboard. Select the console tab and scroll up to see any errors. Usually red text
