    MMM-FUEL Icon Issue when Default Calendar is activated
    3 Posts 2 Posters 1.5k Views 3 Watching
    • I Offline
      icke
      Hi guys i have a problem with the MMM-Fuel module.
      The arrow for price list isn`t showing if i have activate the default Calendar module.
      default Calendar module activated
      default Calendar module deactivated
      Thanks for help.
        j.e.f.f Project Sponsor Module Developer @icke
        @icke I’m going to guess that both modules are using fontawesome for the icons, but the default calendar is using a local copy that does not include the icon that the MMM-Fuel needs, and it is likely overriding the MMM-Fuel version.
        A couple of things you can do:
        • examine the fontawesome CSS file in the calendar module to see if there is a different name for the same icon included, then use some custom CSS to apply it to the MMM-Fuel module
        • override fontawesome in your custom CSS with a more complete version, either calling the CDN version directly, or a local copy that includes all the icons you need.
        • I Offline
          icke
          Thanks Jeff i changed the Icon in the MMM-fuel.js
