    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 61.5k Views 18 Watching
      costascontis
      thnx for your hard work ,i really like this module,but its not updating right.When i restart MM works fine for few hours and then stops updating.My token is working fine ,i use it also to my Openhab setup .Also my other modules are all updating fine.My config is :
                             module: "mmm-nest-status",
                             position: "top_center", // pick whichever position you want
                                     token: "c.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                     displayType: "grid",
                                     displayMode: "all",
                                     thermostatsToShow: "all",
                                     updateInterval: "60000",
                                     showNames: true,
                                     thermostatSize: "medium",
                                     // ... and whatever else configuration options you want to use
      michael5rM N 2 Replies Last reply Reply Quote 0
      • michael5rM
        michael5r Module Developer @costascontis
        @costascontis You configuration looks fine - the updateInterval is set to 60000, so it’s only pulling data every 10 minutes.
        What exactly do you mean that it “stops updating”?
          costascontis
          isnt updateinterval in ms?cause if it is then 60000 ms = 1min…
          michael5rM 1 Reply Last reply Reply Quote 0
          • michael5rM
            @costascontis said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
            My bad - you’re right, it’s 1 minute :)
            • N
              nhl @costascontis
              @costascontis Make sure the away read permission is active on your nest development OAuth client
                costascontis @nhl
                @nhl in my Other Permissions Away read is greyed out.
                • michael5rM
                  @costascontis It shouldn’t matter - I don’t use the Away read setting in this module. The settings that matter are the ones directly tied to the thermostat and smoke detectors.
                    costascontis @michael5r
                    @michael5r my Thermostat read is greyed out too …is that matter?
                    • michael5rM
                      @costascontis No, that’s fine - directly below you’ve enabled read/write, so that supersedes the standalone read setting.
                        costascontis
                        found some time to debug why module stops updating.I think it has something to do with my on/off monitor function.I use Motion to turn on my mm tv when movement detected by sending a “/opt/vc/bin/tvservice -p ; sudo chvt 6 ; sudo chvt 7” command.After 5 min with no motion detected it power off my tv sending a “on_event_end /opt/vc/bin/tvservice -p”.I think that after some time of power off monitor the module’s update function breaks.All other modules i use they work and updating fine all the time.
                        EDIT: ignore all of the above,even when my screen is on the module stops updating after a few hours…I dont know what else to try…maybe some other module causing this?Is it possible?
                        EDIT 2: I opened the console at the developers tools inside mm and i notished that from the moment MMM-NEST-STATUS module starts spams with notifications clock and calendar modules like that
                        clock received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
                        calendar received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
                        until it stops and stop updating the nest status also.Is that normal?
                          costascontis
                          @michael5r after hours of tests i found out that if i use default clock and calendar module then after a few minutes nest module stop updating.If i dont use clock/calendar and comment them at config.js then nest module is working fine for days.I am not a developer but i suspect that has something to do with notifications between these modules…
                          • michael5rM
                            Yes, that’s totally normal. The mmm-nest-status module is broadcasting a notification to all modules saying that data is available - it’s how the socket notification system works.
                            • michael5rM
                              I’ll see if I can recreate this with those modules - thanks for the doing the debugging!
                                costascontis
                                @michael5r just asking…why nest-status need to send notifications to other modules ?
                                • michael5rM
                                  mmm-nest-status isn’t sending a notification directly to other modules, it’s sending a global notification.
                                  But seeing that all modules listen for these notifications, the notification will also reach modules that don’t need or use it (which is where the console log you showed comes from - it’s basically all modules saying “I received a socket notification”, but it doesn’t mean they actually do anything with it).
                                  That’s just how the magic mirror socket system works - every module that broadcasts data or status does this.
                                  • N
                                    numb3rs
                                    With the sell of Nest to Google, is this module still working at all?
                                    • michael5rM
                                      michael5r Module Developer @numb3rs
                                      @numb3rs It works just fine if you have an existing Nest developer account, but as I also posted in the repo for the module, there’s currently no way for new users to use the module.
                                      Still waiting on Google to open their Individual Device Access program:
                                      https://developers.google.com/nest/device-access
                                      • K
                                        kash @michael5r
                                        @michael5r
                                        i have not migrated to a google account yet and still have a existing developers account. how do i get the token?
                                        • F
                                          fordi
                                          spectacular!!!
                                          • michael5rM
                                            michael5r Module Developer @kash
                                            @kash said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                                            @michael5r
                                            Download the previous version of the module:
                                            https://github.com/michael5r/mmm-nest-status/tree/fcbf291a26374e32901e993f9e109465819f59bf
                                            It has the shell script that allows you to get a token.
                                            • 3 / 4
