    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 61.5k Views 18 Watching
    • michael5rM
      michael5r Module Developer @costascontis
      @costascontis No, that’s fine - directly below you’ve enabled read/write, so that supersedes the standalone read setting.
        costascontis
        found some time to debug why module stops updating.I think it has something to do with my on/off monitor function.I use Motion to turn on my mm tv when movement detected by sending a “/opt/vc/bin/tvservice -p ; sudo chvt 6 ; sudo chvt 7” command.After 5 min with no motion detected it power off my tv sending a “on_event_end /opt/vc/bin/tvservice -p”.I think that after some time of power off monitor the module’s update function breaks.All other modules i use they work and updating fine all the time.
        EDIT: ignore all of the above,even when my screen is on the module stops updating after a few hours…I dont know what else to try…maybe some other module causing this?Is it possible?
        EDIT 2: I opened the console at the developers tools inside mm and i notished that from the moment MMM-NEST-STATUS module starts spams with notifications clock and calendar modules like that
        clock received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
        calendar received a module notification: MMM_NEST_STATUS_UPDATE from sender: mmm-nest-status
        until it stops and stop updating the nest status also.Is that normal?
        michael5rM 1 Reply Last reply Reply Quote 0
          costascontis
          @michael5r after hours of tests i found out that if i use default clock and calendar module then after a few minutes nest module stop updating.If i dont use clock/calendar and comment them at config.js then nest module is working fine for days.I am not a developer but i suspect that has something to do with notifications between these modules…
          • michael5rM
            @costascontis said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
            Yes, that’s totally normal. The mmm-nest-status module is broadcasting a notification to all modules saying that data is available - it’s how the socket notification system works.
            • michael5rM
              I’ll see if I can recreate this with those modules - thanks for the doing the debugging!
                costascontis
                @michael5r just asking…why nest-status need to send notifications to other modules ?
                • michael5rM
                  mmm-nest-status isn’t sending a notification directly to other modules, it’s sending a global notification.
                  But seeing that all modules listen for these notifications, the notification will also reach modules that don’t need or use it (which is where the console log you showed comes from - it’s basically all modules saying “I received a socket notification”, but it doesn’t mean they actually do anything with it).
                  That’s just how the magic mirror socket system works - every module that broadcasts data or status does this.
                  • N
                    numb3rs
                    With the sell of Nest to Google, is this module still working at all?
                    • michael5rM
                      michael5r Module Developer @numb3rs
                      @numb3rs It works just fine if you have an existing Nest developer account, but as I also posted in the repo for the module, there’s currently no way for new users to use the module.
                      Still waiting on Google to open their Individual Device Access program:
                      https://developers.google.com/nest/device-access
                      • K
                        kash @michael5r
                        @michael5r
                        i have not migrated to a google account yet and still have a existing developers account. how do i get the token?
                        • F
                          fordi
                          spectacular!!!
                          • michael5rM
                            michael5r Module Developer @kash
                            @kash said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                            @michael5r
                            Download the previous version of the module:
                            https://github.com/michael5r/mmm-nest-status/tree/fcbf291a26374e32901e993f9e109465819f59bf
                            It has the shell script that allows you to get a token.
                            • F
                              fordi
                              I dont have a developers account but could do with one. It’s so frustrating now i want to add modules to my mirror.
                                JohnBachini @michael5r
                                @michael5r
                                Is this the same token obtained doing this .??
                                https://github.com/USA-RedDragon/badnest
                                • michael5rM
                                  michael5r Module Developer @JohnBachini
                                  @JohnBachini said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                                  @michael5r
                                  No - the token my module needs is the old “Works with Nest API”-token.
                                    robertybob
                                    This works great! I’m so glad I haven’t migrated my account
                                    • H
                                      humdinger44 @michael5r
                                      @michael5r Any word on an update with the new google smart device management api?
                                        costascontis @humdinger44
                                        are there any news about this nice module?The new Google nest api is out for a while,Will this module be updated to work with it?
                                          sdetweil @costascontis
                                          @costascontis best to ask in an issue for the module on github
                                          • 3 / 4
