    Strange line in the middle of the monitor
    4 Posts 2 Posters 1.1k Views 2 Watching
    • V Offline
      Vauxdvihl
      Hi friends,
      has anybody an idea were this line comes from?
      thanks
      Regards
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      				/*{//MMM-MVG-LocalTransport
      				  module: 'MMM-MVG-LocalTransport',
      				  position: 'top_left',
      				  header: '
      				{//MM-WeatherBackground
      				   disabled: false,
      						module: "MMM-WeatherBackground",
      						opacity: "0.3" //This is the color behind the modules so you can see them better.   Higher the number the darker the color
      						//  default in module is set to 0.4
      				{//MMM-NOAAA3
      							module: 'MMM-NOAA3',
      							position: 'top_right',
      										provider: "openweather", 							// From list above
      										apiKey: ,        // From one of the providers listed above
      										airKey: "
      										css: "NOAA4",                   				// THIS MUST CONTAIN A CSS STYLE NAME
      										userlat: "
      										userlon:
      				/*{//MMM-WunderGround
      						module: 'MMM-WunderGround',
      							apikey: 'xxxx,
      							pws: 'pws:xxx
      							hourly: '3',
      							fctext: '1',
      							fcdaycount: "2",
      							fcdaystart: "0",
      							hourlyinterval: "3",
      							hourlycount: "2",
      							alerttime: 10000,
      							lang: "de",
      							alerttruncatestring: "english:",
      							coloricon: true,
      						roundTmpDecs: 1,
      						UseCardinals: 0,
      						layout: "horizontal",
      						iconset: "VCloudsWeatherIcons",
      						sysstat: 0
      				{//MMM-Timetable
      							  //disabled:true,
      							  module: "MMM-Timetable",
      							  position: "top_center",
      								timeFormat: "HH:mm",
      								height: "520px",
      								width: "180px",
      								mode: "5days", // "today", "5days", "7days"
      								refreshInterval: 1000*60,
      								displayEndTime:false, //whether display endTime on timeline or not.
      								schedules: [ //array of schedules
      				{//MMM-PublicTransportHafas
      				  module: "MMM-PublicTransportHafas",
      					stationID: "xxx",                   // Replace with your stationID!
      					stationName: "xxx",   // Replace with your station name!
      					direction: "xxx",            // Show only departures heading to this station. (A station ID.)
      					ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
      					excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
      					timeToStation: 5,                // How long do you need to walk to the next Station?
      					timeInFuture: 120,                 // Show departures for the next *timeInFuture* minutes.
      					showColoredLineSymbols: true,     // Want colored line symbols?
      					useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
      					showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
      					maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
      					maxReachableDepartures: 3,        // How many reachable departures should be shown?
      					customLineStyles: "leipzig",      // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
      					showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
      					stationName: "Possenhofen S-Bahn",   // Replace with your station name!
      					direction: "xxxx",                    // Show only departures heading to this station. (A station ID.)
      					timeInFuture: 90,                 // Show departures for the next *timeInFuture* minutes.
      				{//MMM-Calendar
      				module: 'MMM-CalendarExt',
      				position: "lower_third", //anywhere. It is not related to real position of view
      				config: { // Read below
      				system: {
      				  show: [/*'current','upcoming',*/'weeks'],
      				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
      				  showEmptyView: 0,
      				  fullDayEventLocalize: 1,
      				  redrawInterval: 30*60*1000, //minimum 60000
      				  useProfileConfig: 0,
      				  startProfile: ''
      				 views: {
      						current: {
      						  title: "Heute",
      						  limit: 2,
      						upcoming: {
      						  title: "Demnächst",
      						  limit: 2,
      						weeks: {
      						  position: "bottom_bar",
      						  title: "Überblick",
      						  counts: 2,
      					url: "webcal://www.ecoline-media.de/ics/bayern_gf.ics",
      					styleName: "style1",
      					symbol: 'de@em',
      				    maxEntries: 50,
      					maxDays:365,
      					interval: 24*60*60*1000,
      					url: "http://localhost:8080/modules/abfallkalender.ics",
      					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
      					symbol: 'put_litter_in_its_place@em',
      					maxEntries: 50,
      					maxDays:365,
      					url: xxx
      					styleName: "style19",
      					symbol: 'guitar@em',
      				    maxEntries: 50,
      					maxDays:365,
      					url: xxx
      					styleName: "style6",
      					symbol: 'man-woman-boy-boy@em',
      				    maxEntries: 50,
      					maxDays:365,
      					url: xxx
      					styleName: "style11",
      					symbol: 'bike@em',
      				    maxEntries: 50,
      					maxDays:365,
      					url: xxxx
      					styleName: "style12",
      					symbol: 'birthday@em',
      				    maxEntries: 50,
      					maxDays:365,
      					url: xxxx,
      					symbol: 'crown@em',
      				    maxEntries: 50,
      					maxDays:365,
      					url: "xxxx,
      					symbol: 'baby@em',
      				    maxEntries: 50,
      					maxDays:365,
      • ejay-ibmE Offline
        ejay-ibm Project Sponsor Module Developer
        I would suggest to comment your modules one by one to find out the culprit .
        Once target found it will be easier to debug .
        • V Offline
          Vauxdvihl
          It comes from “calendar ext”
          If i remove this module the line is not there anymore
          ejay-ibmE 1 Reply Last reply Reply Quote 0
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @Vauxdvihl
            @Vauxdvihl then I would simply raise a git issue to the dev.
            I don’t know this module, but I would say at first it come from the css, I might be worng.
            Other user of the module can probably help better , but I think the dev can figure this out quickly
            Ejay
